Show us your vintage mountain bikes!
Old 05-03-18, 02:54 AM
  #6076
laurenholloway
They all look so awesome! How I wish I could own one of them.
laurenholloway is offline
Old 05-03-18, 07:46 AM
  #6077
lacro
Quoted: 70 Post(s)
Originally Posted by Sri Krsnadread
measure from the ground to the bottem headset with the current fork and see how much you measure with a rigid fork. some mm or 1 cm more with a rigid fork would not make so much difference in handeling.
Sri Krsnadread
I have the bike stripped to the frame, so I can't try that. Actually I don't think that would be accurate as the suspension fork would have to be loaded with rider to get correct measurement. Also, I built the bike from bare frame so the fork I used was not the original one that came on a factory built Zaskar so it may be the wrong length already.
PM sent about seat post...
lacro is offline
Old 05-03-18, 10:08 AM
  #6078
Sri Krsnadread
26.8 mm for the xtr seatoost and 27 mm for the xt seatpost. both went in and out the frame quite easy. originally it is 27 mm if I am not mistaking
Sri Krsnadread is offline
Old 05-03-18, 10:54 AM
  #6079
lacro
Quoted: 70 Post(s)
I installed the Tange Big Fork with a threaded head set I already had to see it it can work. Put the wheels on without tires, set it on the floor, and measured the head tube angle. It's 72-1/2 degrees. Does that look like it will work or is it too steep? This is for road use, and I don't want twitchy steering. Now I need to source an 1-1/8" quill stem to try it out.
lacro is offline
Old 05-03-18, 10:45 PM
  #6080
Sri Krsnadread
the top tube angle does not seem to steep , actualy quite fine
well how about €40 for the xt seat post? I have lots of parts but ( a nos Tioga avengers oversized stem as well) I understand that costs can rise as hell if you are buying all nos and near nos vintage parts.
I went all out on this GT. I have an idea how much I spent on it, but try to ignore it ( a lot ) )))
where would I have to sent the seatpost to. the €40 is without shipping costs. I will post some pics first and then deside
Sri
Old 05-03-18, 11:55 PM
  #6081
glenography
Originally Posted by Roadie Rob
1994 (?) Univega Boralyn S8.9 Metal Matrix that I picked up brand new, never built up, from a shop closing in Milwaukee a few years ago for $75 cash. Not bad for a $1,200 frame that was one of the reasons the original Univega company shut down in the mid-90's.
It's built up with modern compnonents to 21.1 lbs. I have ridden it only 3 times and it is simply a rocket with very smooth trail feel. I'd love to ride it more, but it is too pretty to risk.
OMG. What a coincidence that I was just searching up old Univegas on Google Images tonight.
glenography is offline
Old 05-04-18, 03:36 PM
  #6082
jetboy
jetboy's Avatar
Bikes: centurion cinelli equipe, look hinault 753, Zunow z-1, 83 stumpy sport
Quoted: 814 Post(s)
Liked 331 Times in 186 Posts
looks good from here. and nice looking shop! Its such a bling frame that I like the softness of the grey and black components on your original build. it would look real ncie with all grey- but thats pretty hard to find. if ti was a road bike i'd be like 8 speed Tricolor! but not sure about MTB components- if there ever was a dark anodized grey set
jetboy is offline
Old 05-04-18, 03:53 PM
  #6083
lacro
Quoted: 70 Post(s)
Sri
I tried a 27mm SP from my neighbors bike, it's a no-go. The 1" suspension post I had with the original build has an adapter that is labeled 26.8mm. My frame requires a 26.8mm SP so I can't use your 27mm XT. Thanks anyway...
lacro is offline
Old 05-04-18, 04:16 PM
  #6084
lacro
Quoted: 70 Post(s)
I need some ideas for getting my bars and seat closer to level with each other. The headset I used with the rigid fork is a vintage Tioga Avenger 1-1/8" HS with a 1" ID. I want to use a new stem with as short a reach as possible as the frame has a pretty long top tube. Also. I want to raise it a lot to match the seat height for an upright riding position. I will be using a Jones SG 2.5 Aluminum Loop H-Bar or something similar. Looking for stem or adapter plus stem suggestions that don't look too goofy.
lacro is offline
Old 05-24-18, 07:15 AM
  #6085
Skills_79
Skills_79 is offline
Old 05-24-18, 07:17 AM
  #6086
Skills_79
Love the look of this bike.
Old 05-24-18, 07:20 AM
  #6087
Skills_79
cool!
Old 05-24-18, 07:21 AM
  #6088
Skills_79
Love this color!
  #6089
Skills_79
So clean!
Old 05-24-18, 07:36 AM
  #6090
John Nolan
Bikes: Raleigh Classic 15, 84; Miyata 912, 85; Miyata Ridge Runner SE, 85; Miyata 610, 86; Miyata 100M, 86; Miyata Valley Runner, 88; Miyata Triple Cross, 89; GT Karakoram, 90; Miyata Elevation 300, 91; Marinoni Touring, 95; Long Haul Trucker, 2013
Quoted: 159 Post(s)
Liked 133 Times in 80 Posts
Originally Posted by tiredhands
I built up an ~’88 Rockhopper Comp for a friend to their specifications using parts from my bins, mostly early 90s DX and XT. I found the frame in a junkyard so I got to have fun with paint and tried my hand at tie-dying bar tape again.
How did you manage bar ends and those type of levers?
What handlebars are those? What brake levers?
John Nolan is offline
Old 05-24-18, 07:48 AM
  #6091
tiredhands
Sempiternal Newb
tiredhands's Avatar
Bikes: '92 Trek 750, '85 Univega Gran Turismo, '95 Stumpjumper,
Quoted: 232 Post(s)
Liked 15 Times in 11 Posts
The bars are Soma Oxford, and the brake levers are Shimano Deore XT M732. You can kinda see in this photo how the shifter cable lays against the brake lever clamp (on the left side):
tiredhands is offline
Old 05-24-18, 08:11 AM
  #6092
John Nolan
Quoted: 159 Post(s)
Thanks!
Old 05-24-18, 08:31 AM
  #6093
bikemig
bikemig's Avatar
Quoted: 5888 Post(s)
Liked 3,471 Times in 2,079 Posts
Love these old MTBs. Lately my 1993 Bridgestone MB 1 has been seeing a lot of use:
bikemig is offline
Old 05-28-18, 08:58 AM
  #6094
Skills_79
Old 05-28-18, 09:00 AM
  #6095
Skills_79
So here's a before and after of a '93 Ocelot.
Just cleaned it up, new seat and replaced the "flat-out" foam tires for a softer ride.
Old 06-12-18, 11:57 PM
  #6096
fleslider
fleslider's Avatar
Quoted: 477 Post(s)
Liked 179 Times in 91 Posts
Just found this guy. A Meridia made 1986 Trek 850. its in great shape and just needed some tlc.
interesting enough is the color Yellow/Blue not in the catalog, not sure what happened there..
Suntour XC Sport Components with a Roller Cam rear Brake and the coveted Specialized Cranks.
I have it torn down to a frame and am cleaning up and reassemble
All the bits released of their 32 years of gunk
fleslider is offline
Old 06-13-18, 05:55 AM
  #6097
2cam16
2cam16's Avatar
Bikes: TRIMMED DOWN THE HERD
Quoted: 1092 Post(s)
Liked 936 Times in 601 Posts
Nice! Looks like the same era as my Muddy Fox. Maybe the colors were offered in another country?
2cam16 is offline
Old 06-13-18, 01:30 PM
  #6098
fleslider
fleslider's Avatar
Quoted: 477 Post(s)
Possible, a quick google search i see a couple in that color, but not sure. maybe a difference between Wis made 850's (were there any?) and Meridia made.
Old 06-13-18, 03:35 PM
  #6099
The Golden Boy
Extraordinary Magnitude
The Golden Boy's Avatar
Quoted: 2608 Post(s)
Liked 1,703 Times in 937 Posts
Great shot Miguel!!!
Commence to jigglin’ huh?!?!
The Golden Boy is offline
Old 06-13-18, 04:03 PM
  #6100
bikemig
bikemig's Avatar
Thanks! I'm a terrible photographer and that's a cell phone pic but the lighting was good and that is a heck of a fun bike. What's not to like about 26 x 2.0 inch skinwall tires?
bikemig is offline
