What would you say your ratio of flats is, front to rear?
SkinnyStrong
I've only had 3 flats since I started this sport about a year and half ago, but they've all been on the rear wheel. I can only recall my riding buddies getting flats on the rear tire as well. Why is that? Simply a matter of weight?
What would you say your ratio is?
1 front to 10 rear.
I always rotate my front tire to the rear so the newest rubber is always on the front. My hope is to get this ratio up even higher.
Bikes: S-Works Roubaix SL2^H4, Secteur Sport, TriCross, Kaffenback, Lurcher 29er
#div/0! over the past three years.
Before that, 100% rear.
Live to ride ride to live
Bikes: Calfee Tetra Pro
I use to average about 2 flats per year until I went to GP4000s and I haven't had a flat in the past two years. But, I would say for every five flat I get on the back I get one on the front.
Bikes: Ridgeback Steel Tourer,Recumbent SWB,Steel Road,,Raleigh Twenty,Elephant Bike,Pashley Pronto TNT.
Quoted: 21 Post(s)
Liked 5 Times
4 to 1 ,I think you run the obects over with the front,which stands them up to hit the back.
Portland Fred
Easily 10 to 1 or greater -- this has held for many years. But most of my miles are lugging rear panniers.
Quoted: 29 Post(s)
Liked 11 Times
I only have one bulletproof tire, on the rear, my front flats are so infrequent I don't bother. It isn't just a matter of weight, it is also that often you run over objects with the rear after you steer around them with the front.
The only 2 front flats I remember were pinch flats where I had let the front tire get low. Probably had 20 or 30 rear flats in that time (few years).
Still can't climb
Quoted: 12 Post(s)
Liked 6 Times
about even
coasting, few quotes are worthy of him, and of those, even fewer printable in a family forum......quote 3alarmer
No @coasting, you should stay 100% as you are right now, don't change a thing....quote Heathpack
Peloton Shelter Dog
Former Hoarder
I never talked about flatting because I hadn't had one in close to 3 years. Then I had 3 in a week. All rear. Same with crashes. Never talked about them because it had been over 20 years since the last "real" crash. Then I had one earlier this year...not a major bone breaker, but a damaging one nonetheless.
Back to tires...over my life, probably 5:1 favoring the rear.
55/Rad
55/Rad
Got Hills, I do!
Bikes: Trek Domane SLR 9.9 - Trek Supercaliber 9.9.
Liked 9 Times
I started riding a few years ago and in 16,000 miles I have had two flats both in the front.
Bikes: 2007 Trek Madone 5.9 (Shimano DA), 2008 Kuota Khan (SRAM Red), 2009 Giant OCR2 ( Shimano 105 ), Lynsky R340 ( SRAM Rival )
Should Be More Popular
Quoted: 22637 Post(s)
Liked 8,953 Times
1:4 f:r
SkinnyStrong
The reason I ask is because I was planning on putting a wheel in the wheel truck for a race this weekend, but I don't have a 10-speed cassette to put on this rear wheel I have. So I thought, well, I'll just put a front wheel in the truck, 50-50 chances right?
Any other theories as to why most people have more rear flats?
Bikes: CAAD9-6, 13' Dawes Haymaker 1500
Liked 6 Times
6 front 1 rear.
Put thorn resistant tubes in both tires after 1st flat(rear) first one has gone through 5 more tubes since then. The rear is still on the thorn resistant one. I just put tire liners in both tires to stop flats a couple days ago.
Looks like I am the only one with this.
Liked 8,953 Times
The last few flats I had were all in the rear. Overall it is close to 2:10 f:r.
