Are Drop bars just an illusion for most?
#651
Quoted: 1218 Post(s)
Liked 298 Times
I'm simply astounded that you don't know that your ability to look over your shoulder is much better in a more upright position. Nothing wrong with my neck, just the simple fact that the more I'm leaning forward, the less useful information I can get from turning my head.
It's like fitness. A cyclist either has physical fitness, or he can fitness whole pizza in his mouth. LOL
#652
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
It takes two to argue. As long as you keep throwing softballs, I'll keep knocking them out of the park.
Further nonsense. You conveniently ignore the probability of an emergency event. This was one of those "higher probability" times:
It was dark (reduced vision distance), it was just after twilight (time when deer are on the move), it was in an area where deer had been sighted (history). The prudent choice was to ride in the drops, with fingers covering the brake levers. That prudence was rewarded.
Again, you conveniently conflate the advice from experts with the stupid risks that pros take while racing. Listen to the experts, don't emulate risky pro racer behavior.
False, I never made that assertion. That's your invention from whole cloth.
Effective braking can be done from the hoods, but more effective braking can be done from the drops.
Sorry for giving you the benefit of the doubt by inferring that you had knew about sprinting technique. I won't make that mistake twice.
You’ve told us that no one can brake effectively from the hoods which implies that no one should ride on the hoods.
Pay attention. I said that if I moved hand position to the drops, I’d lose a sprint. The loss wouldn’t be because of the technique, it would be because of the time taken to shift hand positions. If nothing else, shifting hand positions would be a signal to an opponent that you are going to sprint.
#653
climber has-been
Liked 3,567 Times
That left tire track is also nice because debris there gets swept constantly by car tires, so you're less likely to slip out on junk there.
Likes For terrymorse:
#654
Liked 298 Times
Out of all of the Pro riders, Who focuses solely on cyclocross and then applied to all of cycling? Was it Cyccommute?
Likes For badger1:
#656
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
I finally figured out what the real issue is --at least two of the posters here can't master using the hoods properly, have problems keeping a grip, can't work the brake levers with their weak puny fingers, and don't take advantage of the full range of visual scanning afforded to someone riding the hoods.
There comes a point where one realizes one is arguing with fanatics who long ago left their relationship with reality at the side of the road somewhere. I'm out of this thread, let them enjoy their delusions of superiority.
#657
Quoted: 4227 Post(s)
Liked 2,488 Times
Any person who is fit and healthy should be able to fitness the whole pizza in their mouth and wash it down with beer and still be able to maintain their fitness and be lean.
#658
Been Around Awhile
Bikes: Vaterland and Ragazzi
Quoted: 12 Post(s)
Liked 1,538 Times
Also note that people who are mentally fit and healthy would not have a need to divide groups of cyclists( or any other groups of people) into only two choices, either like themselves (Good, fit or healthy) or not (unfit, unhealthy, ignorant)categories.
Likes For I-Like-To-Bike:
#659
Liked 298 Times
there is ALSO more than a half a dozen post in this thread pointing out, BY the POSTER themselves, that is was their belly in the way of using the drops.
#660
Liked 298 Times
So "should" is just wishful thinking. It's like riding on the Hoods when they should be in the drops and hoping for the best outcome.
#661
Liked 298 Times
The steps towards being able to reach and use your drops on a drop bar.
1. being able to see your toes while standing up straight
2. trying to touch your toes multiple times, multiple times a day.
#662
Mad bike riding scientist
Quoted: 6222 Post(s)
Liked 4,222 Times
I wear a helmet in the event of an emergency for which I can’t plan. I wear a seat belt for the same reason. I wash my hands to prevent catching a disease which isn’t necessarily an emergency situation.
Were you there? Were you in the guy’s head? The video that you are referencing didn’t even appear to have any large object that I could see. He appeared to have a momentary lapse that caused him to lose his grip. Maybe he was thinking of a cold one after the ride or he was just tired or about a thousand other reasons. You are speculating that he slipped because he wasn’t in the drops. But, as with Morse, are you suggesting that all riders should ride only in the drops 100% of the time? Or should there be a speed limit above which you should use the drops.
I’m no more “Projecting” than you are. Again, were you there? Was that you? And the rider didn’t really “endo”...as in going over the bars head first. His wheel washed out on a soft patch. It happens all the time in mountain biking and is probably a very common occurrence at cyclocross events. Hand position wouldn’t have prevented it.
I’ll take back my statement about your other statement being the most ridiculous. This is the most ridiculous bar none. Who rides a mountain bike with their thumbs “unhooked”. It’s kind of how you hold onto a flat bar. There may be times when people rest their hands on the grips but, for the most part, mountain bike riders keep their hands wrapped around the bar.
And how do you save endow on a mountain bike with hooked thumbs anyway? (This pushes your previous statement to the third most ridiculous statement.) Do your thumbs counter physics? Do they twist you back over the bars and set the wheel on the ground? Do they magically levitate you back upright...kind of E.T. style?
But, again, you seem to be confusing “endo” with other types of crashes.
I have also saved 1 endo on a drop bar. Same reason, my hands were absolutely locked in and I maintained control. Meaning I kept the wheel straight and it kept rolling! Which generally takes 2 hands still on the bar. UNLIKE the guy on the gravel bike previously posted in this thread.
Assuming that you mean a wheel washout rather than a trip over the bars, I’ve saved myself from those kinds of crashes too. But it’s not because my hands are “locked in”. Keeping the bike upright when the wheel wants to slide out requires a lot of hip action and countersteer. Where your hands are and what you are doing with them has little to do with keeping the wheel from washing out.
Yes, the guy who crashed in the video you are referring to would have done better with two hands on the bars. But it wouldn’t have made any difference if his hands were on the drops or hoods. And it’s not like he could have shifted hand positions to keep from crashing. You seem to be arguing that everyone should be riding on the drops 100% of the time to be completely safe. Not that it would matter.
One of you posters have argued in this thread that the video of the gravel guy lost his grip on the hoods because his elbows were locked.
Guess what.... elbows locked while in the drops won't cause your hands to bounce out of the Drops. Drops are still superior for grip.
Boy, are you on a roll of ridiculousness. Elbows locked while gripping the bars in any position is not conducive to good bike handling.
But do you keep them in hand at all times? Always out and ready for use just in case you have to use them? I don’t consider repair equipment to be for “emergencies”. It’s for “incidents”. A helmet is more for an emergency but I’m not always crouched and ready to fall off the bike and use the helmet. But even that isn’t “planning for an emergency” in the manner meant in this thread nor even the types of random “emergencies” that can occur on a bike
Stuart Black
Stuart Black
#663
Liked 298 Times
An Endo is an Endo, Over the bars is an Over the bars. Many Over the bars is because they couldn't keep the wheel straight on the ENDO!!! Or they simply lost grip, or didn't have enough Grip/core strength to bring it back down.
On some switchbacks (MTB) it works best to intentionally endo. Which means having a Positive grip on the bar.
riding an endo is..... well watch the Video.
also while Brumotti takes many Risk, he didn't Risk GRIP or control.
as for do I ride 100% in the drops? No, I also don't ride 100% with a helmet. Like you with no accidents on the hoods, I am still alive after many rides without a helmet. Should we apply your logic of Hood riding to helmets? Or would you care to ride the drops more on descents, corners, if you didn't have a helmet to save you? I mean why do you need a helmet? You have 10,000 miles of touring on the hoods accident free?
#664
Liked 4,222 Times
Not sure to which poster you are referring, but let me be clear:
Control of flat bars vs hooks of drop bars is roughly equivalent, although it is easier to get your upper torso lower when using hooks. This can help somewhat in hard braking situations and high speed turns.
Control while using the hoods of drop bars is diminished. There is no equivalent diminished control position on flat bars.
Sprinting isn’t rocket science.
Stuart Black
Stuart Black
#665
Liked 2,488 Times
98% of people who ride drop bar bikes never use the actual drops and spent all their time riding on hoods and they end up using just that one hand position for all of their riding. So what's the point of drop bars ??.
#666
climber has-been
Liked 3,567 Times
#668
Liked 2,488 Times
#669
Liked 4,222 Times
Aas for do I ride 100% in the drops? No, I also don't ride 100% with a helmet. Like you with no accidents on the hoods, I am still alive after many rides without a helmet. Should we apply your logic of Hood riding to helmets? Or would you care to ride the drops more on descents, corners, if you didn't have a helmet to save you? I mean why do you need a helmet? You have 10,000 miles of touring on the hoods accident free?
As for riding in the drops, you seem to be saying that we should always be in the drops because we’d be prepared for problems and would have greatly superior braking power there. So why don’t you ride 100% in the drops? It’s so superior for all conditions. And how often do you ride the hoods? 5%?
25%? 75%? Or like most people I see, about 99% of the time?
Stuart Black
Stuart Black
#670
Liked 298 Times
You can show them a video of what is actually wrong with hoods, and they still won't see it.
You can show them pictures, and you have. Yet they still won't see it.
What I know to be fact is experience. I am just Glad that I was in the drops, when I came around the curve and hit road Kill on the road at 20 mph in the dark!
Likes For Metieval:
#671
Quoted: 2236 Post(s)
Liked 1,314 Times
I don't think Terry is a troll by any means, just someone who believes what he believes - which is cool even if I don't see things the same way.
And while I sometimes don't see things the same as Stuart as well, I respect that he's not afraid to have a real life presence on the board so that I at least know his opinions are based on actual experience. Like me, not perfect but what you see is pretty well what you get. It's honest.
But the other poster here, who loves to denigrate other people for being unfit and unhealthy is pretty well a troll imo. Vague, anonymous, no pics of him or his bike to substantiate how uber fit and awesome he is in comparison, he just puts people down from the shadows of obscurity. No honesty.
#672
Liked 298 Times
You really don’t have a clue, do you? “Endo” is short for end-over-end...AKA “a header” or “a face plant” or even “over the bars”. What you are describing is a nose wheelie. The cyclocross rider that you were referring to wasn’t trying to do a nose wheelie nor was he even in danger of going over the bars. His wheel washed out and those are difficult to recover from. They are even worse in soft conditions.
Yep. It requires a good grip on the bar but that has nothing to do with “saving yourself from an endo”. Even if a nose wheelie was going to result in an endo, hand grip isn’t going to keep the endo from happening. Getting off the brake and trying to push the CG rearward would but grip would do exactly nothing.
You better tell that to all of the Videos teaching MTB how to Purposefully ENDO as a useful skill on the trails! and no they are not teaching people how to CRASH. or uhh what did you say it was? nose wheelie. I am Pretty sure I do have a clue. Trying to Insult me isn't helping your argument any.
Y
the argument is grip, superior braking....... What I do, what I don't do is irrelevant!
E.G. I say being employed helps pay the bills. Yet If I am unemployed. does that change my statement to being FALSE? NO it does not.
Now I understand why so much of what is being said to you is coming back twisted. Drop bars, grips, braking, which way is better. and you want to make it about me and what I do? what I do is irrelevant. what some pro cyclocross rider does is irrelevant.
what Th Pros say as a group on high speed descents is relevant. Well apparently it isn't relevant to YOU. Fine, but that doesn't change what it is.
Is poison still poison , if you don't eat/drink it? YES it is!!!!
the same with braking from the drops is superior, regardless of if you or I or anyone does, or does not do it that way.
Control is superior from the drops, regardless of who is or who is not using the drops.
quit making it about what people do. Vs what is, regardless of what people do.
I mean for **** sake, they drank from pewter and killed them selves with lead forever. 1 example of 1,000 that people do stuff wrong as a GROUP often!!!! Your arguments are all based on what people do. vs What is, regardless of what people do.
#673
so they are called nose wheelies??? You are being 100% serious?
People aren't taught to purposely do endos. Endos, by their very definition, result in a crash. If you didn't crash, you simply avoided an endo.
This is basic MTB stuff.
Likes For ab_antiquo:
#675
Liked 298 Times
point is you don't do it by resting your thumb, fingers, and hand on the top of the bar. You grab the bar with your thumbs under the bar!! The only way your hand will come off the bar is if you let go. or if your hands slides 5" out and off the end of the bar.
To get the same thumb grip on a Drop bar you do it in the drops. as your hand can only slide down or up. the only way it comes off is about 6" backwards. or letting go.
anatomy will not allow you the same grip on the hoods.
yet you all want to squabble over semantics.... Knowing that the "endo" term is used loosely. even by Major MTB networks that have MANY VIDEOS!!! The BikeForum general section population needs to go School them aye?
