Go Back  Bike Forums > The Racer's Forum > Track Cycling: Velodrome Racing and Training Area
Ask your small, random, track-related questions here
Track Cycling: Velodrome Racing and Training Area Looking to enter into the realm of track racing? Want to share your experiences and tactics for riding on a velodrome? The Track Cycling forums is for you! Come in and discuss training/racing, equipment, and current track cycling events.
Old 12-19-17, 05:06 AM
  #4676
Morelock
Morelock's Avatar
Quoted: 282 Post(s)
Liked 50 Times in 37 Posts
I don't have experience with this method, but I've glued a good number of tubulars, here's what I think. (take for granted there is some speculation)
In theory, if you were methodical in doing it and you used good glue, you'd probably be alright riding a tyre glued like this on "normal" roads or on a keirin track. (pretty shallow banks) In my mind, I'm gluing my tyres with the "worst case" scenario in mind, not "normal conditions."
I wouldn't want to glue my cyclocross tyres like that. (or my track tyres that I expected to bomb sharply off the top of the boards on)
*I do think most people (myself included) use much more glue than is necessary (I glue my own 2 coats on the tyre, 2 on the rim with a days drying between each coat, then a final wet layer on the rim, mount, although I've done 1/2 coats within a day when in a hurry for a race before with no ill effect. *for a road tt)
Morelock is offline
Old 12-19-17, 06:44 AM
  #4677
Godsight
Bikes: Felt TK FRD
Quoted: 59 Post(s)
Regarding pump for high pressure tubular, the best design I found is the Silca pumps. The cheapest and travel friendly Pista work wells and they also make a locking adapter for disc called the hiro side-lever chuck. They are not cheap but with parts still available for 25+ year old silca pump, it is a decent long term investment.
Godsight is offline
Old 12-19-17, 08:06 AM
  #4678
topflightpro
topflightpro's Avatar
Quoted: 1852 Post(s)
Liked 679 Times in 430 Posts
I have an old Silca pump. It has been a nightmare. I've replaced the gasket more times than I can count, and it never works well.
But I realize my experience tends to be the exception.
topflightpro is offline
Old 12-19-17, 08:07 AM
  #4679
JimiMimni
Quoted: 30 Post(s)
Originally Posted by gycho77
https://youtu.be/URZEK3-DIfQ
So he is Keirin racer in Korea so he speaks in Korean, but my question is do you think this is save way of glueing tubular tire?
He only put one heavy coat of glue and wait 24 hours.
He uses this method to glue his race wheel and other.
What do you think about this?
His step.
1) remove old tire
2) stretch tire
3) put tire
4) put really heavy coat of glue without removing the tire
5) pump the tire
6) clean excess glue with finger
7) look for gaps and add glue
8) wait a day
There is some more discussion about tubular gluing in the track tires sticky, I think.
The common dogma I was taught regarding track tubs is that high pressure in the tires does as much, or more, than the glue.
I personally do two layers on rim and tire with a wet mounting layer. I run through the whole process in one sitting. Normally I do a wheel, a tire, the other wheel, and the other tire. By the time I've come back to the start of the cycle, the first layer of glue is dry and I apply another. When the second round is finished, it's mounting time. This doesn't count stretching the tires, which is either superfluous, or SUPER necessary (Continentals!! ).
Several others I've spoken with wait entire days between layers, and when I worked in a shop this is how we glued tubs. This is one of those black voodoo things in gluing tubs. There isn't any real hard evidence on the effect of waiting vs. not.
Do good work, make your layers nice and even, and you should be fine. Treat it like painting a picture, not just slobbing glue on.
JimiMimni is offline
Old 12-19-17, 11:54 AM
  #4680
rensho3
Bikes: Fuji Elite, 3Rensho track, Trek Madone 6.9, Specialized MTB, GT MTB, Cannondale Cad3 fixie
Quoted: 72 Post(s)
I am very happy using the Lezyne pump for my track tires. It gets and holds 180 psi without problem.
rensho3 is offline
Old 12-19-17, 04:44 PM
  #4681
1incpa
Quoted: 49 Post(s)
Liked 22 Times in 14 Posts
I use an old Silica pump that I put the Hirame head on: Hirame / Kuwahara pump head / (Presta/French) adapter + 3 pack of seals - Staff Picks
The pump easily reaches 200psi, and the head stays put. This head has the added benefit of fitting in the hole in my disc. No more crack pipe.
PI
1incpa is offline
Old 12-19-17, 06:56 PM
  #4682
700wheel
Quoted: 144 Post(s)
Liked 14 Times in 11 Posts
I have used my Lezyne high pressure pump (220 psi) for around ten years. It has a screw-on chuck.
The o-ring seal on my pump still good (although I have replaced the seal using a Home Depot o-ring a couple of times on a Lezyne pump at my local track but then maybe it gets lots of abuse).
700wheel is offline
Old 12-19-17, 10:36 PM
  #4683
gycho77
Bikes: Serotta steel track bike, Specialized MTB
Quoted: 99 Post(s)
Liked 4 Times in 3 Posts
Thank you.
I think I will justbstick with multiple layers of glue.
gycho77 is offline
Old 12-19-17, 11:13 PM
  #4684
700wheel
Quoted: 144 Post(s)
Thank you.
Gycho77, Did you ever take delivery of your custom track frame and if so how do you like it?
700wheel is offline
Old 12-19-17, 11:51 PM
  #4685
gycho77
Quoted: 99 Post(s)
Oh...
beause I don’t have that much time I just decided to buy Dixie Flyer.
But he will be preparing for NAHBS but not this year.
gycho77 is offline
Old 12-20-17, 02:45 AM
  #4686
Baby Puke
Bikes: Marin Stelvio, Pogliaghi SL, Panasonic NJS, Dolan DF4, Intense Pro24 BMX
Quoted: 365 Post(s)
Liked 87 Times in 58 Posts
Oh...
Let's see that Dixie then!
Baby Puke is offline
Old 12-20-17, 09:56 AM
  #4687
southernfox
Quoted: 194 Post(s)
Liked 2 Times in 1 Post
Here's a thing I'm struggling with right now. I think the power is there to do much better times for 200m and 500m (I can hold 1000w for 20s, 850w for 30s), but I really struggle getting cadences over 110-120 in race gears. For example, I'm hitting turn 3 in 500m starts at 118rpm, but that's just not fast enough. I have a similar problem in 200m starts: I jump from 90-95rpm, but I just can't get it up over 120 by the time I'm hitting corner 1.
So how do you translate power into *speed* and cadence in race gears?
(And yes I have a coach, and yes we've talked about this...but I'd like more help.)
southernfox is offline
Old 12-20-17, 10:07 AM
  #4688
queerpunk
aka mattio
queerpunk's Avatar
Bikes: yes
Quoted: 344 Post(s)
Liked 58 Times in 35 Posts
That's pretty common when roadies transition to track racing. My coach rolls his eyes at training power ("yeah, anyone can do XXX watts at 60rpm - the hard part is doing it at 120 rpm"), and closer to the season, we do a lot of work to make sure that I'm putting down power at speed. We call it "activation."
You have a few other options. You can use big gears - that's what a lot of people do. The drawback to big gears is that while they tend to be good for qualifying, they can be pretty rough in sprint rounds.
But really you just need to train power application at those cadences. There are a few components of this. You need to be generally comfortable at higher cadences, and this comes from prolonged intervals at higher cadences than you'd ever do on the road. Then, you need to have the neuromuscular ability to apply lower torque faster faster - and that means overcadence spinups. The final piece of the puzzle is pulling those together into actual power application at the cadences. A lot of sprint work is focused just on hitting cadence targets; once the max creeps up, it's time to gear up. That's when you're truly applying power at race-appropriate cadences.
This is the time when I point out that if your coach doesn't understand the specific demands of track racing then you might not be getting what you need given your goals. I've seen road coaches try to train track athletes and grope blindly in the dark because there is stuff that they just don't get.
queerpunk is offline
Old 12-20-17, 10:17 AM
  #4689
southernfox
Quoted: 194 Post(s)
(FWIW, these power numbers are usually 120-130rpm)
Oh my coach is track-specific and is decently well-known. We're doing all the things you list.
I can put down good power at 150rpm, and all my power PBs are 120-130rpm. But I struggle getting past 120rpm when I have to go spin up in a single gear (without shifting on the road bike, for example). My peak cadence is 210rpm, so the issue isn't that I can't hit cadences with low power. We do a lot of sprints where I roll at 20mph at 90-110rpm then sprint aiming to peak at 150-160rpm and then hold it for however long (often 10s but up to 20s).
Old 12-20-17, 10:24 AM
  #4690
carleton
Elitist
carleton's Avatar
Quoted: 1386 Post(s)
Liked 92 Times in 77 Posts
Train to cadence and increase gears as you go. Don't put on your race gear for next summer and train until you spin it fast enough.
As you advance as a racer: Cadences stay the same. Gears get bigger.
This happens at a meso level (the gears you use in your winter and early season training phases into your race season and your peak) AND at the macro level (as you become a local, regional, national, and international standout).
I can show you that cadences used in the Team Sprint or 500M at a local velodrome championship are the same that are used at the World Championships...across genders.
The gears that top racers use at the beginning of the season are smaller than those they use at the peak of the season...but the cadences are the same.
+1 on everything, especially about the coach.
As mentioned before, a lot of road coaches think that training for track is easy, "How hard can it be?! They don't even have hills or gears." There is so much nuance.
carleton is offline
Old 12-20-17, 10:26 AM
  #4691
southernfox
Quoted: 194 Post(s)
So maybe that's an idea: train on smaller gears hitting the cadences.
Old 12-20-17, 10:28 AM
  #4692
queerpunk
aka mattio
queerpunk's Avatar
Bikes: yes
Quoted: 344 Post(s)
Ah, gotcha. Yeah, that's a different issue that what I interpreted at first.
You'll need to train to apply power through a cadence range, and you can do that on the track or on the road with rolling accelerations that start at 60rpm and take you above 120. You'll have to find the right gear that gets you what you want. The important part here, too, is steady power duration more so than spikes; you need to be able to still be applying that peak power 10+ seconds into the effort so that you can continue to accelerate past your former stall points. For top-end speed, the power you do at 15-20 seconds in to the effort is a lot more important than the first 5 or 10 seconds.
Separately but related, I was reading a report from an acquaintance who was training with Jair Tjon En Fa - doing solo top end accelerations followed by dropping behind the motor and accelerating again. Jair would hit 70kph on his own and then accelerate up to 90kph behind the motor.
A mix of smaller gears and full gearing - the top-end cadence isn't the problem, it's getting there after spending time applying power through the lower ranges. So improve the power application through that range (full gearing), AND improve your ability to climb out of it (undergearing).
As with a lot of sprint work, this should be done when fresh, with full rest between, and absolutely stop an effort once you start bogging down. Max power only. Do these wkos 2x/week and in a month, PBs will start pouring from the sky*.
*results not guaranteed.
Old 12-20-17, 10:32 AM
  #4693
southernfox
Quoted: 194 Post(s)
Most of my long power PRs are during standing starts, and I'm really consistently applying power the whole time until I hit my max cadence, then power drops to 500-600w for the rest of the effort.
Also: holy sh**.
Old 12-20-17, 10:33 AM
  #4694
southernfox
Quoted: 194 Post(s)
That is EXACTLY the issue, yes. And I do the efforts fresh, usually doing 4-6 with 15-20min rests between. And as soon as I see peak power decline ~10% I shut it down and go home.
Old 12-20-17, 10:38 AM
  #4695
sarals
Idiot Emeritus
sarals's Avatar
Bikes: Yes.
Quoted: 331 Post(s)
Liked 13 Times in 4 Posts
Here's a follow on to Southernfox's line of questions:
Start with smaller gearing, hit cadence and then start to build gearing as the season progresses. I get that part. However, what is the best way to increase gearing? Start with a small chainring and reduce sprocket size (say 48/15 then go to 47/14 - 86 to 88 inches), or leave the sprocket alone and increase the chainring size (48/15 to 50/15 and up)? I'm sure it has a lot to do with physiology, but is there a rule of thumb?
"Can you add a signature line please? The lack of words makes me think you are being held hostage and being told to be quiet"
sarals is offline
Old 12-20-17, 10:41 AM
  #4696
carleton
Elitist
carleton's Avatar
Also: holy sh**.
Long power PRs that have the standing start are simply skewed by the power spike. You wouldn't see the same avg over time if you did a rolling or flying start, which is a better metric.
Cadence is the best metric.
Cadence is king. ALL HAIL CADENCE!!
carleton is offline
Old 12-20-17, 10:46 AM
  #4697
queerpunk
aka mattio
queerpunk's Avatar
Bikes: yes
Quoted: 344 Post(s)
Also: holy sh**.
if i were in your shoes i'd fine tune my gearing so that i could drag out that max power as long as possible, and shut it off when the power drops; aim for stretching the duration of that length of max power. a lot of people don't do full efforts until race day. till then it's all about the components.
at conventional combinations, 1 chainring tooth is a much smaller difference than 1 sprocket tooth. if you want to REALLY finetune the differences, change both. a gearing chart can help you see what gear combinations make how much of a difference over where you started.
Old 12-20-17, 10:48 AM
  #4698
southernfox
Quoted: 194 Post(s)
My 30s PB was a hill sprint (out of the saddle at 120rpm the whole way). I don't seem to have huge peaks (my pmax is only 1400). *shrug*
Old 12-20-17, 10:58 AM
  #4699
sarals
Idiot Emeritus
sarals's Avatar
Bikes: Yes.
Quoted: 331 Post(s)
Thanks! My question should be that I'm curious as to what would be, well, gentler progression. Is it "easier" to spin up a smaller chainring vs. a larger one? From my RPE point of view, the few times I rode a 48T (15 sprocket) and then bumped to a 50T in the same workout (simulated match sprint rolling jumps with 100M sprints) my cadence was slightly lower with the 50T but I felt "torquier", if you know what I mean. I'm asking as an older athlete, of course.
sarals is offline
Old 12-20-17, 11:11 AM
  #4700
carleton
Elitist
carleton's Avatar
I wouldn't compare any metrics (speed, power, cadence) from road workouts to track workouts.
Indeed, progress is progress. Numbers going up are always good.
I'm not sure you'd ever do 30s at 120RPM on the track.
Not to mention road bike crank length, power meter differences, terrain, hoods, etc...There are a lot of factors.
A power meter (or simply speed and cadence meter) on the track is a lot more controlled environment. I wouldn't expect the same numbers on the track....ask anyone who's done a Kilo on a road bike on the road then a Kilo the track
carleton is offline
