How much Boeshield T-9 for one frame
Old 10-06-19, 06:39 AM
rm -rf
don't try this at home.
rm -rf's Avatar
Quoted: 974 Post(s)
Liked 512 Times in 352 Posts
Originally Posted by 3alarmer
...seems to work, takes a day or two to drain out and dry on the interior, widely available at Home Depot and Lowes, does not smell like pork chops.
That Rust Inhibitor is a clear coat. I don't find Rustoleum sprays to be very rust resistant, though. Even the "Rusty Metal Primer" isn't very good.
What does work:
Rustoleum Cold Galvanizing Compound. This is 93% zinc dust with a paint binder, in a spraypaint can. It says it's for galvanized fences, etc, but it works great on any steel surface.
I've used it on sheet steel "box gutters", the built-in gutters on old houses. I've scrubbed the minor surface rust on the sheet metal, rinsed and dried it, then sprayed. No rust for many years, even without another paint coating over it.
When dry, it's a light gray, shiny, metallic looking finish.
I've never tried it on a bike frame. It would be very messy, having to protect the threaded bottom bracket from getting clogged up, and keep the silvery paint from dripping out any vent holes -- or wipe off outside drips with a paint thinner soaked rag.
rm -rf is online now
Likes For rm -rf:
Old 10-06-19, 01:23 PM
Loose Chain
Loose Chain's Avatar
Bikes: 84 Pinarello Trevisio, 86 Guerciotti SLX, 96 Specialized Stumpjumper, 2010 Surly Cross Check, 88 Centurion Prestige, 73 Raleigh Sports, GT Force, Bridgestone MB4
Quoted: 278 Post(s)
Liked 71 Times in 56 Posts
A rust converter is not the same as a rust preventer. The Wiggles Frame Saver, Boe-Shield, Fluid Film, LPS-3 Corrosion X etc. are rust preventative coatings. The products that reform rust (FE Oxide) into a stable coating that starves the underlying oxidizing process of O2 is not appropriate for an interior frame coating unless there is an awful lot of rust, for one thing, it is heavy, for another it is meant to be top coated.
Loose Chain is offline
Old 10-12-19, 01:12 PM
Lightning Pilot
Location: Peoples Democratic Socialist Republic of Madiganistan (formerly known as Illinois)
Bikes: Lightning P-38
Quoted: 48 Post(s)
Liked 32 Times in 26 Posts
Something I forgot to mention that is very important if diluting an acid, in this case phosphoric acid:
"Do what you orter*, add acid to water!" Always add acid to water to dilute it, NEVER ADD WATER TO ACID. A steam explosion could result, spraying you and the area with hot acid.
*i.e., "ought to"
Lightning Pilot is offline
Likes For Lightning Pilot:
