Head Tube Badge Creation
Randomhead
Liked 3,705 Times
Rudi, I see there are many waterslide decal papers available. Which one do you use?
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
At my office II have access to a Brother laser printer, which does color (badly), so that's the printer that I'm using; so I buy water slide paper for a laser printer.
My technique of applying the decals backwards only works with clear decal paper.
Randomhead
Liked 3,705 Times
the part I'm missing is where the glue comes from. Isn't it between the backing and decal, and so it's on the wrong side when you apply backwards?
multimodal commuter
Liked 574 Times
I've added another photo to the album....
The first few times I tried this method, I used watered down Elmer's Glue; smear it onto the frame before applying the decal, then gradually squeeze out as much of it as possible. On the Armstrong I tried simple syrup. Either way, it's a water soluble glue. Squeezing out the excess glue is the trickiest part of the job. When the decal first goes on, the layer of glue is thick enough to work as a lubricant, and the decal can slide around. But it's not very strong, so at this point it's very easy to tear the decal in half. So little by little you have to press the decal against the frame, moving the excess glue out to the edge, where you wipe it away. If the decal tears, you have to move the pieces around until the seams match up.
So, for example... here's the down tube decal on my Holdsworth. A thin layer of watered down white glue, then the decal:
With a soft cloth, I gradually work the glue out from underneath, then this happens:
The last three letters have torn away. Doh! It's pretty easy to move them back into place, and keep working... but sometimes the results are imperfect. I don't have a good photo of how this decal turned out (see below). I always print a few extras.
I think you can see that the TH did not get to quite the right place, but the R looks okay.
The Holdsworth frame is powder coated, and I did not clearcoat the decals. They've held up pretty well, but more recent photos show part of the H has gone missing.
www.rhmsaddles.com.
www.rhmsaddles.com.
Quoted: 4215 Post(s)
Liked 3,892 Times
Clear packaging tape (or helicopter tape) placed over the applied decal works well to protect the decal with little negatives.
When I first started out doing this stuff I used simple dry rub on letters available from art/graphics suppliers. Then I used them to create a mock up and had professional dry slide decals made. Later I went to a decal that was entirely rub on (from SSSInk). All of these want to have some form of a covering for long term protection. Initially that was said tape and now it's clear coating paint. But I despise powder coating for my frames so clearing over decals is the usual thing a painter does. For a PCed job one could rattle can clear or use tape. Andy
AndrewRStewart
AndrewRStewart
multimodal commuter
Liked 574 Times
^Speaking of packing tape...
The ultimate in instant decals is to print your design with a laser printer onto plain printer paper (or just cut something out of a magazine), then put high quality packing tape over it. Burnish well (rub really hard with a smooth object, such as a spoon or something) until you have completely flattened the texture of the paper; this will impress the laser toner into the gum of the tape. Then cut away the excess paper and soak the tape and remaining paper in water; then rub the paper away with your finger. The paper will abrade away in little balls. You can rub away every trace of the paper without rubbing away any of the gum. Shake the remaining water off, cut the remaining tape to size, and stick it to the bike frame. Press it down really well, and it will stick for a reasonably long time.
This method works fine, but only lasts as long as the packing tape. In my experience the gum on packing tape dries out with exposure to sunlight etc, and will peel off after a couple years. It's great for temporary applications like when you're trying out a design or figuring out the correct size and location for decals.
As an artist, I agree with you about powder coat. But my bikes are not just art projects; I ride the **** out of them, and I find powder coat to be more durable than paint.
www.rhmsaddles.com.
www.rhmsaddles.com.
Quoted: 2342 Post(s)
Liked 2,841 Times
as bob noted cloisonne is a classic jewelry technique that would produce really nice results....with a lot of work https://jewelrymakingjournal.com/the...own-cloisonne/
I think you could get close ala gugie..... 3 d print of the lines and then paint fill or for a one time...... sculpt in wax and then do lost wax casting
Repoussé and chasing
Another classic technique https://en.wikipedia.org/wiki/Repouss%C3%A9_and_chasing
you raise an area from the back side , then define it, outlining, from the front..
Bikes: Homebuilt steel
Quoted: 2201 Post(s)
Liked 426 Times
I've decided to go down the rabbit hole and try to make my own badge from copper, similar to the process employed by headbadges.com. Any suggestions on the thickness of the copper? 1/16" for two layers? That would make the final badge 1/8". Is that too thick?
Liked 3,892 Times
Depends on what kind of look you're after. The classic riveted on Raleigh badges were fairly thin sheet (probably about 28 gage or 1/64"). Very flexible and formable, to the extent of being a problem when the edges/ends got snagged on a rag when cleaning. The much thicker plastic ones that are common on Asian bikes (including the Raleighs from there) are often glued (double sticky taped) on and IMO look quite chunky. Not at all what I like on an otherwise elegant bike.
The look I was going for was much like a lug's look. My "S" is brazed on so about 1mm (or .040") thick. This is pretty close to what a finished lug's shore line is.
Of course if you're going for a 3D surface then you either will be stamping thin sheet, engraving/etching thicker plate. Andy
AndrewRStewart
AndrewRStewart
Randomhead
Liked 3,705 Times
I'm pretty sure I used 316 stainless shim stock. .030" maybe? Not sure I still have any info about it. 1/16" is really thick unless you are going to remove a lot of it somehow. I have been thinking about cnc engraving. 30 thou is plenty of material to engrave. Brazing it on adds thickness.
There is a pinstriping tool that seems like it would be useful for this, it's a handle with a small paint pot at the business end and a nozzle. Not sure who makes one, doesn't seem to be Buegler. Brian Chapman uses it in this video (obscenity laden music in the background warning): https://www.instagram.com/p/Bo2GUCel...=chapmancycles
Okay, in the comments he says that's a Kemper fluid writer, they are pretty cheap.
I have thought about getting a graver and trying my hand at engraving
Liked 426 Times
Thanks guys. I'll look for 1/32" or 1mm thick sheet. I'm going to have to engrave some of the lettering so that's going to be interesting. I've got no fallacy that the first try will be presentable so this will be one of those learning curve situations.
Liked 3,892 Times
I'll just add a comment about making badges. That's the forming them to fit a tube if they were flat to start with. The thicker (or stronger) the material you use the less easily the forming will be. My "S", which is SS plate about .040" thick, has the vertical portions of the letter that are about .160" wide. These portions are near impossible for my simple forming tools to end up curved. For my needs this still flat portion is no problem, they still silver braze well enough and I can file them to emulate the horizontal portions (that do form easily enough). As I have no surface details this filing is no big deal and the whole "S" gets polished anyways.
I use a male/female sandwich of thick walled tubing and a solid bar as my forming tools, squeezed in a vice, I usually will undersize the forming and somewhat need to spread out the final "S" to the head tube's actual curve. Keeping the "S" aligned during this can be tricky and I've reflattened then reformed a few when they end up a tad crooked. Andy (Whose two current frame builds are nearing this step, meaning the frames are almost done)
AndrewRStewart
AndrewRStewart
using a mound of something like pitch or wax to imbed the curved piece in it
to have it in a situation solidly fixed so you can clamp it firmly
to resist, pushing against it your engraving tool may be beneficial
[Non ferrous/steel]
an annealed metal, like brass, bronze
can be bent easier in that state, once,
the act of bending it work hardens it , then gets re annealed , etc, etc..
[Non ferrous/steel]
Liked 426 Times
I've decided to try my hand at acid etching to create the badge. Ordered some peel and print blue paper and some ferric chloride etching solution, along with some copper sheet. Now I need to figure out how to clean up my logo design and create a nice sharp digital image because sharp definition is needed in order to create the mask. Good fun.
Quoted: 18395 Post(s)
Liked 4,521 Times
If you are just doing one badge, you could probably cut your pattern out with an exacto knife in about an hour. No need to do any more work on your drawing. Just be careful as you work.
I've wanted to try a laser cutter sometime (cut paper, plastic, tape, but also etch but not cut metal). but haven't sprung for one yet. The low power units aren't that expensive.
Liked 426 Times
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4687 Post(s)
Liked 5,832 Times
Here's a badge Rudi made for me using the aforementioned 3D print in wax + lost wax casting, this one in brass:
It was silver brazed on. There was the appearance of a crack there, so I added a thinner band of brass to complete the circle. So it's a frame band-aid done with style.
Randomhead
Liked 3,705 Times
nice.
I'm working on the design for a brass head badge. I have some more work to do. I took some line art in bitmap form, traced it in Inkscape. From Inkscape, I saved as an SVG. I imported that into Fusion 360 and made a 3d object out of the outlines. It isn't very expensive. I suppose it depends on how comfortable you are with 3d parametric cad.
I hadn't thought about brazing it on. I was even thinking about putting screw holes in the design.
You might try the toner transfer method. Print the pattern using a LaserJet printer on inkjet photo paper. Use a clothes iron to melt the plastic toner onto the copper plate. Ferric chloride bath for about 3 hours and backfill the recesses with auto touch up paint .
Randomhead
Liked 3,705 Times
I thought about doing that, but my method will cost $13 + shipping. I think getting set up to etch would cost more than that. I got rid of my etchant supplies a long time ago. There is another etchant that works better than ferric chloride, I don't remember what it is now though.
I always wanted to do screen printing. I have also thought about hand cutting masks. I have done a lot of similar work covering RC airplanes. The secret to that is to buy a large quantity of #11 exacto knife blades and discard a blade at the first sign of dullness.
multimodal commuter
Liked 574 Times
I have over a dozen sheets of Techniks "Press-n-Peel PCB Transfer Film," which can be used for etching head badges. I have used the stuff successfully, but it is tricky and I have had plenty of failures.
Anyway, if anyone wants a sheet or two at my cost ($2 per sheet, plus shipping), please send me a private message.
www.rhmsaddles.com.
www.rhmsaddles.com.
Liked 426 Times
I've read where guys use a laser printer on something like transparency paper instead of the P-n-P film but the film is made for the purpose and cheap enough so what's a few bucks in the grand scheme?
I've been watching tutorials on Youtube trying to learn GIMP so my badge image can be cleaned up. Main problem I'm having is blurry edge lines, particularly on the font. I may have to delete the font in the current artwork and recreate it. Not sure yet, still learning. Open to suggestions of course...
Bikes: 2021 S-Works Turbo Creo SL, 2020 Specialized Roubaix Expert
Quoted: 765 Post(s)
Liked 4,053 Times
Now you tell me...
Some vector apps have functionality that lets you import a bitmap image and convert it to vector, but I've rarely found a setting that did so acceptably, especially with smallish artwork. Depending on the complexity of your design, you might be better off starting from scratch in a vector app.
-Matt
Randomhead
Liked 3,705 Times
Inkscape does a creditable job of converting bitmap to vector. And it's free. I'm not that great of an artist, but I can manipulate Bezier curves all day until they look good (at least to me). What I found in Fusion 360 was that scaling might mess up some of the Bezier curves that Inkscape produces. So it's best to scale in Inkscape. Lots of people use Inkscape for engraving and cnc routing.
Which reminds me, i have a small cnc router that I want to use for making headbadges. But even one of the Chinese spindles is not in the budget right now.
