Show Off your Track Training and Racing Bikes (2014+)
#426
You should've gone with a 58. This bike is built along similar lines to older steel bikes. There is nothing funky about it's geometry, like trying to make is similar to modern compacts. 56cm frames have always tended to be "square". In other words, 56cm frames have a 56cm ST, along with a 56cm TT, or they are very close. Below this, the TT is proportionately longer, and above this the TT is shorter.
#427
Quoted: 26 Post(s)
If durability is a concern, I'd probably get a quill with a rising extension rather than a threadless adapter. Should improve strength for the same reasons and would keep the build simple.
#429
That setup looks worse than it may be because of the type of stem you have - if you get a 1"-to-1-1/8"converter and mount a more modern stem (pictured) it won't seem as severe and will have greater strength/safety than an old 22.2 quill jacked up that high... In the days of old I saw a stems like that break when the guy had it out of the frame that high - basically the internal expander bolt will be the only thing saving your bacon at that point, with basically no steering left.
#430
Elitist
Quoted: 1386 Post(s)
Liked 92 Times
I might take my chances. It's a heavy part in an ancient product line made specifically for ridiculous height by a reputable manufacturer, and I'm not even close to its specified limits.
#431
edit:
Here's the current stem setup.
And here's what the bike came with.
(Although I suppose the force is more perpendicular in the new case, probably offsetting the benefit of a shorter lever.)
#434
Lapped 3x
#436
By the way you guys are right, I'm dumb.
I rotated the fit forward. Saddle position is extremely close to not being UCI legal, heheh... but it seems to work, and is much more track-bike-ish than before.
Likes For HTupolev:
#442
Bikes: DeRosa EL Fixed Gear '93, DeRosa EL Road '95, Ibis Bowtie MTB
Actually I did, but this thread is co-titled "training". My apologies if my bars are inappropriate for this forum area.
#443
Bikes: S-1 :-D
Quoted: 17 Post(s)
Classy frame, personally I'm much rather see it looking something like this. But I am a bit of a traditionalist.
#445
Lapped 3x
Nothing wrong with the bike at all. Just realize that if you're racing on the track (and in some places training in groups), you will only be allowed to ride the track with those bars if it's a Time Trial. Group racing (and training at most tracks) requires that you have drop bars mounted.
#446
Elitist
Liked 92 Times
Scotti, technically, those bars are legal for time trials only. Not group races or even group warmup. Basically, anywhere you will see modern aero bars.
#447
Anyway, I appreciate the advice. Jealous of you guys (gals)!
#449
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1337 Post(s)
Liked 765 Times
The Visp in racing trim
Threw on my old racing wheels, so I can use it tomorrow at my state masters track championship. It's still pretty heavy, but I'm going mainly to show support for the promoter who is including older age groups. Also, the junior and youth championships are on a separate date, so I don't have to worry about some squirrely kid taking me out while I warm up on the track. I've geared it pretty low (47 x 15) for the standing 500m TT so I don't blow out my aging knees. I haven't ridden the track in three years, so hopefully I'll remember how to turn left.
