What are you doing today(C&V bicycle related)?
#1251
Quoted: 1199 Post(s)
Liked 1,355 Times
The smallest details helps me see the big picture.
New O rings for the record calipers.
#1252
Quoted: 796 Post(s)
Liked 522 Times
@ryansu
Many places will not thread a steerer with a manual tool. The claim is that steerers are threaded on a lathe (true statement for new steerers), and you'll wear out the cutting tool. I thought this was the gospel, never cut the threads using a threading tool. The people that go to this church claim the manual tools are for chasing threads, not cutting new ones.
Then I took the UBI framebuilding class, and found that my frame and fork design required a longer threaded steerer than they had in stock. The head instructor found a longer threaded one, handed me the Park threading tool, and told me to have at it.
Bring me that fork, we'll chuck it with some frame clamps in a vice, and you can have at it with my tool. The thing that gets worn out are your arms...
#1253
Quoted: 4512 Post(s)
Liked 6,387 Times
#1254
Quoted: 1136 Post(s)
Liked 650 Times
@ryansu Gugie is right. I have cut steerer threads with a die and it works fine. It works especially well if you already have some pre-existing threads to start the die down - this keeps the die straight and square with the steerer when it starts doing real cutting.
The dies are made of tool steel which is quite a bit harder than the alloy steels nice forks are made. Any claims that threads can't be cut with a die is nonsense. Yes, if you are working under very tight tolerances in a machine shop, a lathe will always cut cleaner threads, but that tight of a tolerance is not even close to being needed for steerer threads.
The only time to be careful with a die is with chrome-plated steerers. The chrome is very hard and might dull the die a bit, depending on the die.
Put either the die or the fork in a vise and make sure you have good leverage on whichever is not clamped down.
#1256
Quoted: 502 Post(s)
Liked 466 Times
@ryansu
When I asked Elliott Bay Cycles to extend the treads on a replacement fork with a very long steerer tube, they said said they’d only add 1/2” maximum, while I was looking for much more (it was really long steerer, and I was putting it in a 60cm frame). I eventually found a shop that would do it with a die. It wasn’t a difficult process. @ryansu, the shop that did that extension was Alki Bike & Board, just up the street from you. But I also think @gugie would do a better job with appropriate cutting oil, etc.
However, I’ve learned why Elliott Bay would limit the thread extension - the stem expander puts high internal radial stresses on the steerer tube, and a conical-style expander concentrates those stresses in one a short length of the steerer. Imagine if that’s happening in the threaded, hence weakened, section of a steerer. I’m pretty sure that’s what happened to the steerer tube on @RiddleOfSteel’s ‘74 Paramount before his rescue and @gugie’s incredible fix. The steerer tube was broken just above the start of the threading, well below the top of the head tube. BTW, a wedge-style expander has the advantage of spreading the radial stress over a length of the steerer.
So if you do proceed with this fork with extended threads, it sure seems like a very long quill stem, such as the ever-popular Nitto Technomic, would be highly advisable, with a modified minimum insertion that keeps the expander wedge below any threads.
#1258
Liked 6,387 Times
@merziac, I am amazed that you remembered that I was involved in a steerer tube threading project!
#1259
Quoted: 472 Post(s)
Liked 1,028 Times
I was grieved to find that the chain wear on my Nishiki was over 1% as I had been doing more riding than checking. Ugh! So time for a new chain. But, oh, check the FW too. Yup the 3rd and 4th cog were shot too. Unless....... So I got out the MOACW (see the new "Mother of all Chain Whips" thread) and spun the threaded cogs off that Suntour Perfect FW. As expected #3 and 4 are splined so I could flip them over. My cog checker indicated that they'd be just fine that way. Cleaned everything and spun #5&6 back on then put it in storage. To ride another day.
New chain on the Nishiki then a test ride. Back in the rotation.
#1260
Quoted: 1143 Post(s)
Liked 1,749 Times
@ryansu, Davidson is not the place to go to, He usually does not do repairs or resto. He will but when he does it's usually for his own productions. R&E or Cyclefab are more go to places for this type of service needed.
#1261
Quoted: 796 Post(s)
Liked 522 Times
I had the same sense from Davidson that perhaps the piece work is not where they wanted to spend their time which is fair.
#1262
Quoted: 7350 Post(s)
Liked 2,475 Times
@ryansu, that might be an opportunity to use a 1" threadless headset and stem.
#1263
Quoted: 796 Post(s)
Liked 522 Times
#1264
Quoted: 9 Post(s)
Liked 9 Times
Arranging delivery of my recent find, a 1993 Bridgestone RB 1 in yellow with Ritchey designed biplane fork. Hoping my short reach brake calipers will work when I build it up with Shimano 600EX parts.
#1265
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3889 Post(s)
Liked 6,488 Times
Finally did something for the Crescent in overhauling these power shifters ...
And they're still working!
#1267
Liked 2,475 Times
Thank you for the exploded view, @SurferRosa. I've never taken those apart. I really like them.
#1268
señor miembro
Liked 6,488 Times
#1269
Quoted: 1611 Post(s)
Liked 2,593 Times
Curtis is getting a new fishing bike.
https://baynature.org/article/a-fishing-expedition/
I stop and talk to him whenever I'm riding down that way and need to pay him for all the fish stories, lol.
#1270
Hump, what hump?
Bikes: See signature
Quoted: 337 Post(s)
Liked 227 Times
Today I'm looking at my '82 Basso Gap and planning a ride. There's a Trek 400 Elance nearby, awaiting disassembly.
#1271
Quoted: 2324 Post(s)
Liked 4,992 Times
Today will be about test riding. I want to see how the Evans bike I picked up recently feels and then I want to do a shakedown on the NOS mid 90s Vitus Argal that was finished yesterday.
Steel is real...and comfy.
#1272
52psi
Quoted: 790 Post(s)
Liked 802 Times
Trying (again) to solve the sometimes-there tik-tik-tik in my SS drivetrain. Pedals have been eliminated as the source. Today I'm pulling the beat-to-hell 600 arabesque crankset and installing an 80s Cyclone I have laying around.
#1273
1/2 as far in 2x the time
Bikes: Yes, Please.
Quoted: 499 Post(s)
Liked 285 Times
Yeah there's still some winter dust. But adjusted and rideable. Some Cable housings are too long but shifts 7 gears liked a dream. Not sure why not 8, but I'm old and don't use the bottom cog anyway.
Here's my favorite new ride, with a modern version of one of my old team jerseys. Pretty decent color match, wait till you see what's under the jersey. Period correct, I think.
I am at home today with a sick daughter, who just needs reassurance that I'm around, so I'm doing a little spring cleaning, and stand-testing bikes before I ride them around the block. I hope to have N-3 rideable today, maybe even N-2 by tonight. Fun stuff! (Not so much for my daughter, but it's nothing serious). Finally happy with the bike/wheel pairings. I'm a wheel nut and it's taken a while, I've decided about saddles and bar tape mostly too, at least for now
#1274
I solved my gearing problem. I love riding my Trek 750 with last generation Super Record, but trying to ride around SW Wisconsin with 42x24 granny gear just doesn't work anymore. It is do-able, but just not a good idea. So I stumbled across a TA Carmina crank. These are the cranks that let you install your own spider and run just about any combination of rings and sizes. Peter White Cycles has lots of TA stuff in stock so I got a 110 spider and a couple of TA Zephyr rings, and now I have gear inches (48/34 rings) compatible with my terrain and age. I used the existing Campy spindle and get almost the same chain line - the right crank leaves room for a third ring so it kicks the chain line out a few mm. It shifts the front really well, in part because the modern TA rings have ramps. They look pretty good on a CV also.
#1275
Bikes: Yes, Please.
Quoted: 499 Post(s)
Liked 285 Times
