#3001
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 532 Post(s)
Liked 1,007 Times
I have been working on the repaint of this Fuji S12-S LTD that I bought last fall. It had a rough respray and homemade decals, so don't worry about ruining the originality. When I receive the decals, I'll need to apply the clear coat. Also, it was missing a lot of original parts, so I have collecting parts to get it reassembled. Some of the parts were being used on other bikes, so I switched some things around to acquire what I needed. The bike felt good when I took it on an initial shakedown shortly after I bought it, so I am looking forward to getting it back on the road.
1981 Fuji S12-S LTD
1981 Fuji S12-S LTD
#3002
Not lost wanderer.
Quoted: 886 Post(s)
Liked 998 Times
A local guy whose wife works with my wife asked for a bike, here is a parts bin bike I built for him.
Likes For bwilli88:
#3003
Quoted: 1372 Post(s)
Liked 1,752 Times
Will start breathing life back into this sixties something Torpado Professional today and, with hope, taking it out for a short (and darn cold) test ride this afternoon. Man, is it good to have SOMETHING to do! This one will be a knock the dirt off, grease er up and ride the bike's patina into tomorrow build. Oh, ya - on the lookout for a proper fork (here we go again)...
#3004
Quoted: 7349 Post(s)
Liked 2,474 Times
I really like that Torpado, @randyjawa. I would definitely ride it. Are you back in Thunder Bay now?
#3005
...addicted...
Tom,and Rocks in head,
That brush doesn't clean the inside of the seat tube very well. I have made a tool that does a great clean up that gets right down to the steel. I figure that I am going to slather a bunch of grease back in the tube before reassembling so likely no rust or corrosion. The tool is simple. This one is a six inch long 1/4" bolt with the head dremeled off and a slot cut into the bolt lengthwise about two inches deep. An extension for the drill, and a sheet of sand paper cut into two inch strips and would around the bolt until the proper diameter is reached. Then use just like a power ream inside the seat tube. The picture is after cleaning a Raleigh out last week, so you can see the material it removes. If it clogs up just add more sand paper and go after it again. HTH, MH
tool and drill bit extension
the tool after cleaning the Raleigh
the method of winding the paper in the slot
Since snapping this shot I dug a hole in the end of the cork and glued in the swaged flange end of the spoke.
#3006
Bikes: Numerous
Quoted: 1678 Post(s)
Liked 3,098 Times
Drilled out a stuck dropout screw on my waiting to be built Paletti. It came with the NDS screw sheared of at the outside of the dropout. The inner portion of the screw was intact. After some PBlaster soak I started to remove the screw and what I thought was the screw turning was really the head shearing off! I tried a few tricks over a couple of days to back the screw out but no dice, so today I drilled. Here’s my ghetto upright drill press made from my Dremel press, part of my camera tripod, and some VO pedal straps. The screw was really seized in there so after drilling it out I had to spend about 30 minutes carefully tapping it, afraid I was going to break the tap off in the hole. It came out very nicely and a new screw threads in smoothly.
Likes For Spaghetti Legs:
#3007
Quoted: 767 Post(s)
Liked 1,898 Times
Is there a thread on that Paletti? I like that paint job.
#3008
Shifting is fun!
Bikes: Yes, please.
Quoted: 2198 Post(s)
Liked 4,602 Times
Wrenching would be too big a word, probably, but I did mount a pair of new tires on a Shimano/Mavic wheelset I had today for mrs non-fixie. She thought her new-to-her RIH felt a bit slow, and the 35 year-old tires that were on it before were definitely well past their prime. So I ordered a pair of Panaracer tires I hadn't tried before, but looked good on paper: the RACE C EVO 4. Nice and light, and with the tried and trusted ProTite belt.
I hope she likes them, and the new wheels. At least they look pretty good, IMO:
*** note to self: remove the plastic before taking pictures! ***
Likes For non-fixie:
#3009
Edumacator
Quoted: 2440 Post(s)
Liked 3,130 Times
Mega wheeled bike storage
Not finished...needs shelving inside and potential peg board or storage for repair stand and pump on one side or an upright hook set for mountain bike...a seventh. Access to shelves on this side. And needs finishing with briwax.
Likes For jdawginsc:
#3010
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3889 Post(s)
Liked 6,488 Times
https://www.ebay.com/itm/PANARACER-R...sAAOSw4n1eDOqP
#3011
I'm also in the middle of building up mine that thats been collecting dust in the rafters for many years, it did not have an easy life previously. Now cobbling together a bunch of parts that have been sitting in boxes to turn into a bar hopper. I spent time rebuilding and restoring some very dirty rusty Mafac Racer center pull brakes to reach the 700c 9sp Shim/Campy wheelset that I have. Having to rebuild everything, realign and dish and with RD extender to make that happen, finger crossed and still a long way to go. Will use a flat bar with rear XT thumshifter and 9sp Dura Ace rear derailuer, Campy single chainwheel up front.
Will update with photo when done
Before:
After:
Likes For mr_macgee:
#3012
Shifting is fun!
Bikes: Yes, please.
Liked 4,602 Times
Nice looking tires. Do the 26mm measure true to size? I'll keep my eye out for some. A little spendier than Paselas at about $50/ea right now:
| paid about €35, but just saw them in another web shop for €27.96, which is Pasela money: https://r2-bike.com/PANARACER-Tire-RACE-C-EVO4-700-x-26C-Skinwall. They come in 23 and 28 mm as well at the same price.
#3013
Bikes: Numerous
Liked 3,098 Times
As always, sorry about that sideways load.
#3014
Quoted: 767 Post(s)
Liked 1,898 Times
Spaghetti Legs , thanks for the pics! Beautiful frameset! I look forward to the thread.
#3015
Bikes: 1986 KHS Fiero, 1989 Trek 950, 1990 Trek 7000, 1991 Gary Fisher Hoo Koo E Koo, 1992 Trek 1400, 1997 Cannondale CAD2 R300, 1998 Cannondale CAD2 R200, 2002 Marin San Rafael, 2006 Cannondale CAAD8 R1000, 2010 Performance Access XCL9R
Quoted: 284 Post(s)
Liked 385 Times
I like this a lot! Maybe a couple shelves for shoes and helmets and such, as well as the pegboard on one side.
#3016
Quoted: 1952 Post(s)
Liked 2,013 Times
Wow! And you used a "regular" drop out screw after all that drilling and tapping? What size tap? I've got a couple bent screws that I'm afraid to straighten because of the, "Oh Sh'?"
#3017
Sophomore Member
Quoted: 1628 Post(s)
Liked 1,059 Times
I posted these two Battaglin frames on the "Are You Looking for One of These" CL thread. The ad had been sitting for months. I don't think anyone saw it because it was listed in the "Bicycle Parts For Sale" section of Craigslist. The frames looked too big for me in the pics, but i got bored one day and drove over and looked at them. To my surprise, they were both within my size range. Got a great price on both frames.
The ride reminds me much of my Bottecchia that was stolen a few years back, I forgot how good Italians are at fine tuning a bicycle frame. Very light very lively frames. These have a very steep head tube angle of 74.5 or so, and I absolutely love it. You just think to steer, and it steers. Rides no hands like no one's business. Very stiff frame that doesn't wobble when ridden one-handed. And that's just the "cheap" frame, can't wait to try out the EL one.
The blue one is a 57 cm made with Columbus Brain, and the red one appears to be Columbus EL in 58 cm. The fork on the red one won't clear anything larger than a 23 mm tire! That's some extremely tight geometry. The frame barely clears 23's in the back, look how close the tire sits to the seat tube.
Tip of the day: Always check the "Bicycle Parts For Sale" section on CL. Occasional great deals on frames there.
The bad part is, now i gotta go shopping for Campy parts. Shimano stuff looks awful on these frames.
#3018
Bikes: Numerous
Liked 3,098 Times
#3019
92 Diamondback Ascent Ex LTD
Got it on Craigslist for 140 bucks. Should have talked him down after I had to replace nearly everything except rims and drivetrain. All bearings too. But, it's fun and the Black Tiger paint scheme is pretty unique
#3020
Quoted: 227 Post(s)
Liked 390 Times
After removing the paint from this Giant Innova, not hard since it was the thinnest paint ever and not even any undercoat. I then had to be brutal with the wire wheel to remove the rust over the whole frame. Almost ready for undercoat just one dent in the down tube to fix then clean it. As shiny as the metal seems it's filthy with contaminates.
Likes For jbchybridrider:
#3022
2-Wheeled Fool
Bikes: Surly Ogre, Brompton
Quoted: 1385 Post(s)
Liked 677 Times
I'll post pics when finished, but I've been renovating my shop. I've been painting the rafters and ceiling, and its not an easy job. I'm adding hard foam insulation as I go, and sealing, and caulking. Messy. Renovations ALWAYS take longer that fresh new construction. I did reach a major milestone yesterday, which was to finish installing nine new lights. Its like daylight in there now! Like I said, I'll post pics when finished. I'll be ready to show it off by then!
#3023
I spent some time on the Phil bottom bracket. It came in the box of parts when I bought my Holdsworth last summer. It is worth more than I paid for the bike.
If wasn't spinning freely and the bearings seemed to be dry. I popped of the seals,sprayed the bearings with White Lightning de-greaser and took a tooth brush to it. It cleaned up well. I then re-greased it with marine grease and cleaned up the shell some. It now spins as smooth as butter.
#3024
Bikes: '72 Fuji Newest, '79 Fuji Royale Gravel Grinder; '84 Schwinn High Sierra BMX Cruiser; '97 Huffy Tremor BMX
Quoted: 33 Post(s)
Liked 134 Times
Mighty Competition Cranks
Just got this in to clean and install on my '72 Fuji The Newest project!
Likes For FujiSam:
#3025
Quoted: 4512 Post(s)
Liked 6,387 Times
Likes For merziac:
