Tubeless... Is that all?
#76
Quoted: 942 Post(s)
Liked 527 Times
Eh....
If I could actually say how I felt and not be labelled some sort of retro grouch or heretic then yes I would scream from the mountain tops that tubeless is immensely stupid... but even then I would have to preface that.
Tubeless is amazing and 100% worth it on fatbikes. The weight dropped, reduction of work involved in a flat, and the reliability makes it a perfect solution.
I can't imagine mtb with innertubes. Just doesn't make sense.
I feel the same about cross. If you can't figure out how to run tubulars then you need to be running tubeless.
It makes so much less sense for road that it's kinds ridiculous in my opinion. Sure everyone has their anecdotal justifications and reasonings that back up their own decisions on this. Keep them.
When someone who is enthusiast level or higher around here asks whether they should go tubeless it's always the same discussion, "you have a lot of flats now?" "No." "Then there's no reason."
#77
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times
You state there are reasons for going tubeless/tubular for MTB/Cross, but say it doesn't make sense for road. Wouldn't the same benefits received on the MTB/Cross also be realized on road setups....or are you saying that the benefits on road are far less critical and therefore do not drive a need as it does offroad? In my mind there is a benefit if I can improve ride quality on the road and reduce the occurrences of having to stop to fix a flat.
Tubeless tires are not as supple as tubed tires are. Not sure where that got lost in all of this. If they were they'd be popping off the rims left and right. As for total ride quality - tubular still prevails. They even have mtb tubulars but only a small handful of racers in Europe use them.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
#78
Thread Killer
Quoted: 3148 Post(s)
Liked 1,714 Times
Really? That got lost on me because I think that suppleness is in the casing construction, but that retention is to do with bead and rim design (i.e. hooked) for road tires, and that the bead shape doesn’t really have much to do with casing, which is to say that bead material and shaping doesn’t, of necessity, preclude a supple casing. Do I have that wrong? I’m interested to hear your thoughts on that.
Likes For chaadster:
#79
Quoted: 4717 Post(s)
Liked 1,882 Times
#80
Thread Killer
Liked 1,714 Times
Well I’m not saying that. I mean, casing stiffness can help with bead retention by giving the bead rigidity, but it’s not necessary for the casing to do that with proper bead and rim design. There can be shaping to the rubber material around the bead which helps it lock in the bead hook, right, like with the Mavic UST spec.
#81
The OP isn't feeling any difference because he's running his new tubeless tires at far too high of a pressure. I'm closer to 100kg, and ran my 700x23 IRC Roadlites @ 90psi. With 25s it's low 80s. Anything wider is generally minimum recommended on the sidewall.
At the same time, I don't understand the change either. I get around two tire-related "incidents" a year with tubeless. On tubes, I would get a flat every 5-7 rides. If I could be guaranteed to go 10k miles without a flat, I'd be back on tubes within the hour.
Tire pressure is key and it’s a fairly narrow band. Read Josh Poertner’s story about Zipp’s work to get carbon wheels used on the cobbles back when he was technical director at Zipp. Couldn’t get it figured out until they figured out that pump gauges are all over the place and testing they did exposed this as a 12psi variation which was larger than what they were trying to make work. So getting that right and being accurate is key. You won’t realize the performance gain if your tire pressure is either too high or too low. First suspect in figuring that out is the mechanical gauge on your pump.
J.
#82
Quoted: 6972 Post(s)
Liked 10,971 Times
^this. Completely agree.
J.
J.
But with that said, the gauges that are built into pumps tend to not match up with the readings I get from actual separate gauges.
#83
Quoted: 338 Post(s)
Liked 408 Times
I was just being snarky.
It's all personal preference. I personally like being able to run 28s at 77psi on a road bike without being slow, while enjoying what I perceive to be more comfort and more grip and without being worried about flats. I personally definitely would be worried about tubed 23s at 77psi on Illinois roads. I personally don't have hassles with getting a good tubeless setup quickly and find tubeless to be low maintenance once set up. These are all my opinions. Other opinions are just as valid as mine.
#84
It doesn’t matter if a gauge gives on “accurate“ reading or not… What matters is consistency. A given rider, with a given gauge, needs to figure out the psi that works best for him or her and then stick with it.
If you don't have both you can't use either the tables a lot of wheel/tire manufacturers supply (i.e. Enve as an example) or the high quality calculators such as Silca supply. They are going to assume repeatability but they also won't work if you don't have good accuracy. And trying to find that sweet spot experimentally is going to take a very long time and a lot of work. You basically need to ride a course, get the time/power and then let out 5psi and do it again. Then once you get it to within 5psi then you need to go at it again until you have it within about 2psi. Lots of variability in the process. Needless to say that if you then borrow an uncalibrated pump, who knows what happens.
If you read the blog post, the engineers at Zipp built a manifold and put several pumps at time on it is so all the pumps all saw the same pressure at the same time. The accuracy was spread over 12psi. In their case, that contributed to breaking carbon rims and until the resolved it, they couldn't get the whole thing figured out. Separately, Lennard Zinn looked at it in a recent column and found that to be a similar problem with mechanical gauges on pumps (even supposedly quality pumps) but that digital gauges tended to be much more accurate with repeatability.
Correct pressure is a pretty narrow band but the results are worth it in ride quality and overall efficiency. Here's the Silca calculator which comes from their experience in advising and testing with World Tour teams. I've found this to work pretty well for me.
J.
#85
Liked 1,882 Times
Likes For noodle soup:
#86
Liked 10,971 Times
“Repeatable“ is what I meant by “consistent.“ I found Silca’s table doesn’t work for me. This is why I think that each person needs to find their optimum psi and then stick to it… And as long as your gauge gives consistent readings, you can do that. It’s sort of like the old saying about how a man who owns one watch knows the time… A man with two watches never knows.
#87
Quoted: 338 Post(s)
Liked 408 Times
Yeah, given the margin of error on pump manometers, a part of people shouting past each other could be that one pump could very well show 10 psi more or less than another pump, which is a big difference in feel.
#88
It's still a giant PITA to start off and try it all by yourself.
And, using your method instead of calibrating your pump and having an accurate gauge, is you cannot use any other pump. That's the problem with not knowing the accuracy of your gauge and presuming it's accurate is a fools errand. Repeatable but not accurate is only slightly better but still in the PITA category.
So in large part, we disagree.
J.
#89
Liked 10,971 Times
The Silca calculator was a touch high for me but very effective because I started out in the vicinity. For someone who rode 23c tires at 100 psi (as did many of us), it's a LOT of work to go from there down to 58/62psi (F/R) going 5 psi at a time. To be fair, would have been starting at 80psi for the tires I was using at the time but still. The reason it was a touch high was that our "old asphalt" is somewhat better than what they describe - but still, it's pretty close. It was about 5psi high.
J.
J.
I tried the Silca calculator. It recommended pressures a bit lower than I had already settled on. I'm glad you like the calculators and find them useful, but a little online research combined with a little bit of experimentation easily got my psi where it works best for me...And I had gotten there before these calculators were on the 'net.
#90
I eat carbide.
Liked 1,306 Times
Tubeless is really about flats. If you're not having them then there's no real point in switching on the road.
#91
Advocatus Diaboli
Quoted: 4739 Post(s)
Liked 1,533 Times
Apologies on the bead retention. Early on with tubeless sidewall stiffness was a factor as bead and rim designs were so poor and inconsistent. In general tubeless tires have a much heavier casing and lower TPI. It's across the board. They are not as supple as tubed tires and aren't even in the same class as high end tubulars (300+TPI vs 60 or 120TPI for most tubeless).
#93
Advocatus Diaboli
Liked 1,533 Times
#95
Advocatus Diaboli
Liked 1,533 Times
#97
Quoted: 20810 Post(s)
Liked 9,456 Times
Do you make proper use the relief channel in the middle of the rim bed? Any of my early challenges with un/mounting tires on tubeless rims, tubeless tire or not, were solved by being more deliberate in that regard (also ending at the valve when mounting). No tire has been particularly difficult since and I've never needed a lever or other tool to mount.
Likes For WhyFi:
#98
Bikes: Speedvagen Steel
Quoted: 429 Post(s)
Liked 248 Times
it could be the combo of my wheels and tires, I haven’t put them
on my alloy I9 wheels yet since I threw some old specialized turbo tubeless that I had on them but will need to replace those soon.
The Conti’s are the bane of my existence when it comes to mounting for the first time
#99
Liked 9,456 Times
One guy in my club, upon his first tubeless foray, was so frustrated with trying to mount the Conti to his Ardennes that he gave up and went back to tubes. I never did get a crack at helping him, but they may still be around... Another club member, a short time after, had no issue mounting his new GP5Ks and razzed the first guy when he heard about the troubles.
Likes For WhyFi:
#100
Liked 1,882 Times
No, and I won't be any time soon - my current wheels are not compatible.
@WhyFi Please continue to shame your friend that gave up.
