Let's see your vintage Schwinn Cimarron
#251
Quoted: 231 Post(s)
Liked 10 Times
finally......
Heres mine. Just took it out for about a mile ride after getting to together.....and staring at it for years.
I put a new deore/mavic wheelset (disc) on it along with some 26x1.25 passelas. Drop bars and suntour barcons, 9 speed. XT front and rear mech, Sugino AT triple crankset, Cane Creek (tektro) levers. I went disc because of the great deal i got on the new wheelset and figured i could use them for another project if this one didnt work out. It rides great. This one doesnt have the fork tube braze-ons which is a bummer. I want to do a front rack and that limits me. I have had 2 touring bikes in the past and both had no front fork eyelets. Some day i will find one that does.
Next step is to shore everything up, swap out pedals and small bits to get it dialed in for proper fit. I have a rack for the rear and a set of ortliebs im going to try on it. My fear is that my feet are going on hit....but i havent tried it yet. So far i love it. It has quite the reach even with the taller short stem. It feels a bit stretched out in the drops but i am hoping i can dial that in a bit too by moving the saddle a bit forward and maybe switching to a 0 seback post. On the hoods feels fine. I am excited to finally have it together.
I cant wait to get the rack mounted and try that. I might also switch out to wider tires for a bit of offroading in the future. Its all city streets around here. 4 bottle cage mounts in case i get thirsty.
#252
Cool Cimarron. On the reach issue, those bars have a pretty massive drop. You might look into something like Midge or Woodchippers if those don't work out. I have had to go with a zer setback post on a couple conversions. I like the Origin8 one and it's quite affordable.
#253
Quoted: 231 Post(s)
Liked 10 Times
I do have a set of woodchippers here somewhere. They are extremely wide and feel like your driving an 18 wheeler. Not sure how they would be with barcons. maybe ill try and swap them over just to see. I think the bars on it now are only 40cm wide.
#254
Bikes: 69 Raleigh Sports, 69 Dunelt 3spd, 84 Raleigh Tamarack, 86 Dahon Classic III, 87 Schwinn Cimarron, 88 Peugeot Anjou, 89 Bridgestone MB-4, 93 Bridgestone XO-5, 93 Schwinn Criss Cross, 95 Cignal Melbourne Express Tandem
Quoted: 5 Post(s)
Better late than never...
Here are some not so great pics I took of my 87 and 89. Sorry for the links, for some reason I just can not get pics to show up and I've posted pictures before so it's making me a little insane as to why they won't show up now.
https://www.flickr.com/photos/146702...7683497660220/
#255
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Try bracketing each link with the HTML tags; the [img] goes before the link and the [/img] goes after. The first one below has the tags and the rest don't. Hmmmm, may not have worked. Okay, you're on your own. Nice Cim, by the way.
#256
Quoted: 231 Post(s)
Liked 10 Times
Thank you for posting the pictures of this for me.
Here is how i ended up. New BB but threw a ~3mm spacer under the drive side to move the drive side out a bit from the stays and allow for the inner most chain ring clearance.. This did move the non drive side in a bit and it is close but it "should" be ok.
Truth be told......i could remove the smallest chainring and run a double and be fine. IF i load up for touring, that small ring might come in handy but boy is it geared low. I can see absolutely no other use ever for that thing.
#257
Standover for the smallest Cimarron frame?
I'm looking for a very small frame to build a bike for my daughter, who is just under 5' tall. I may have a line on a "16.5 inch" Cimarron frame, which I think is probably what Schwinn called a 17 inch. AFAIK this was the smallest Cimarron frame, but if there were smaller ones I'd like to know.
Does anyone have a standover measurement for a 17" frame? As I said , my daughter is short, and even some 47 cm road bikes seem a little big for her.
#258
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
Frame is too big. Typically a 17 inch MTB is for someone 5-6 to maybe 5-8. MTB rider sizing is usually quite a bit smaller than road bike sizing. Long top tubes makes stand over less than meaningful. I always run into problems with TT length long before stand over becomes an issue.
There are plenty of smaller MTBs out there, just not Cimarron. My wife has a 1994 Trek 950, which came in a 14.5 inch size that year. The other one I have for her is a 1992 Paramount Series 70, which came in a 15 inch size.
Please don't confuse ebay "asking" prices with "selling" prices. Many sellers never get their ask price. some are far from it. Value is determined once an item actually SELLS. Its easy enough to check SOLD prices.
#259
Here's the CL link in case you're near Raleigh and your Cimarron jones needs a fix: https://raleigh.craigslist.org/bik/6182782822.html
#260
Quoted: 231 Post(s)
Liked 10 Times
and i think it is done.......
Just mounted the front rack. It is heavy but i dont care. A touring bike isnt supposed to be light. I wonder how it will handle with bags on it?
#261
Quoted: 5 Post(s)
What to do with my 89.
Looks great! I have an 89 in pieces right now while I figure out what to do with it. It's a little big for me to be my mountain bike (not much clearance over the top tube for my bits) but it's a great size for the road. I'm stuck between drop bars or albatross. And I too wonder how it'll handle with some bags and weight especially with some of the weight up front. I might need to make a sperate post but curious if anyone has done Compass RTPs with fenders on these or if the tires don't leave enough room?
#262
rain dog
Quoted: 16 Post(s)
Liked 8 Times
Bottom bracket cable routing
Is anyone using a cable housing liner or other solution to reduce friction for the cables under the bottom bracket?
Over many miles, I've had the cables wear through the paint and I've had some issues that I think are related to increased cable friction there.
Also, for the later cimarrons with indexed shifting, or for anyone that has converted theirs: have you noticed any issues due to frame flex or bb friction, or have you done anything to resolve that?
#263
Just stumbled across a mint condition powder blue '85 back in my home town with a price tag of $1250 on it. Wow!
#264
I'm currently trying to put together parts for a drop bar conversion but can't seem to find bar end shifters that work with the stock drivetrain for a decent price..any advice?
#266
I've been reading this thread for years and have been watching for a Cimarron ever since. I recently acquired a 21" frame without a date stamp on the headbadge carrying the 85-87 decals. The stamp on the bottom of the BB shell is SF653321. Does anyone have any idea when this was made?
The biggest problem I have now is there weren't any forks with the frame so my first priority is to find a replacement. I figured the best way to start would be to ask here if anyone has measured the forks on their 21" bicycle? It would be an enormous help if I had some idea about the lengths and the rake of the front fork for my search. Thanks in advance for any assistance.
#267
#268
Thanks for the reply. I wasn't sure on the decoding since we usually have the headbadge stamp. Since the sun was out I took another close look at the badge and there is no stamping for sure. When I pull it I will take it to the magnifying light and see if anything possibly shows up. Thanks again.
#269
Here's my '85 with new Fat Franks. I switched to the trekking bars late last fall and like them a lot.
Nothing compares to the simple pleasure of a bike ride - JFK
Likes For badger_biker:
#271
Quoted: 213 Post(s)
Liked 1,509 Times
I have had 2 red Cimarron's both 1987, I think.
The first one was pretty rough but this 2nd one was pretty nice.
Both have moved to new owners.
#273
Bikes: All 80s Schwinns: 88Prologue, 88Circuit, 88Ontare, 88KOM, 86SS, 88Tempo, 88V'ger, 80V'ger, 88LeTour, 82LTLuxeMixte, 87 Cimarron, 86H.Sierra, 92Paramount9c
Quoted: 188 Post(s)
Awesome Cims Badger & Cooper!
I've been keeping my eye out for a couple of years now for Cimarron to build as a all terrain touring (but mostly road), finally found one just in frame form (ok since I was going to likely build it up with different components anyway). For road bikes I fit 21-23" schwinns, my Voyageur fits nicely at 21" with its short top tube. I figured I'd need to go down a couple inches for an ATB, and have been looking for a 19" but saw this 20" and thought maybe it'd work with a very short stem, etc. But when I received it and measured, it was a bit off from what the seller said. It's a 21" frame, and that long top tube puts it longer than even my 23" road bikes. Hmmm.
For my build I was going to try VO Crazy bars, so I'd need a threadless adapter or a MTB quill with removable faceplate that is super short if I am going to attempt this. Anyone know of a super short stem that looks more vintage than this: https://www.ebay.com/itm/New-Uno-MTB...53.m1438.l2649
I think that is going to look super bulky on a quill adapter plus shimming back to 25.4 Maybe I'll have to give up on the thought of using Crazy bars and get something I can feed through a Nitto Technomic. Or maybe get a Thomson offset seat post and turn it around so its offset forward... that has worked well for me on road bikes but not sure how it will affect the handling of a tourer atb build designed to carry loads (likely have f/r panniers). I know it'll look goofy though.
#274
Liked 2,446 Times
#275
rain dog
Quoted: 16 Post(s)
Liked 8 Times
If you're looking for a quill with a removeable faceplate, nashbar makes a 1" quill/25.4mm clamp stem in three lengths for cheap. You could buy all three lengths and swap them out easily to see what fits best.
