Just started training with Power? Post your questions/comments here!
#7251
Has a magic bike
Quoted: 4456 Post(s)
Liked 425 Times
@Edonis13, what do you make of the fact that you lose power but not cadence? That's strange to me because when the power meter fails, you usually lose both.
#7252
Bikes: S-Works SL3 Tarmac, Allez E5, Leader 735TT, others
#7253
Has a magic bike
Liked 425 Times
Interesting that your experience is different, I don't know what to make of that.
#7254
Quoted: 842 Post(s)
Liked 469 Times
I get data drops on my Garmin when I'm near utility / electric poles.
My experience with Garmin has been good (although I busted a pod on my Vectors). Being a reader of their forums it seems like they have poor quality control and there are a lot of bad units out there.
Speaking of which, I just got an Egde 1000 for the advanced metrics for Vector Pedals. So far I like it, until I remember how much it cost (also definitely not something to race with).
#7255
Quoted: 417 Post(s)
I had two data drop with my Power2Max and Garmin 810 recently on a 18+% grade while doing repeats. I had done lots of similar climbs during that ride including 5x up a 20% grade, but these are the only two drops:
Since you're a local guy, this is on the New York Bump in Fair Oaks.
Mine drops are pretty similar, but with 2-3 per repeat. I'll have to go back and check to see if I've had any with the power2max on the TT bike. I don't recall having any, but not sure.
#7256
HED Belgium Wheelset w/ Powertap decent deal?
#7258
Bikes: road and track
#7259
Ninny
Quoted: 686 Post(s)
@Edonis13, many power meters will read zero if cadence drops too low. Power = torque x cadence so if the cadence drops low enough that the device is trying to calculate multiple power data points without getting an updated cadence value, the output would be meaningless. Maybe that's what happened on your hill. Depending on how cadence is being calculated, the device may have reported some minimum cadence value, or a doubled value, rather than reporting zero cadence along with zero power.
#7262
#7263
Ninny
Quoted: 686 Post(s)
Not saying this is what happened, but it's possible an actual cadence of 30 was reported as 60 with no power calculation. I have seen that on steep climbs on my SS.
#7264
Quoted: 417 Post(s)
Updated my firmware from 3.4 to 3.5 on my 510 and did some efforts on my ride yesterday where I was getting power drops on previous rides. No identified power drops, but I'll keep an eye on it. My 510 is an out of warranty refurb replacement (my first 510 got ran over when it fell into the street), so not sure if that is part of the problem or not.
#7265
Bikes: Canyon Aeroad, Ridley Fenix
Quoted: 22 Post(s)
If buying a used SRM, would it be a good idea to get it serviced by SRM? Are there any compromises with an FSA SRM over, say, a DA9000 unit (besides battery life)?
#7266
Bikes: Yes
Quoted: 9 Post(s)
The FSA crank is heavier and uses older electronics to keep the cost down, but it's still an SRM. It's a good crank, though. I have the same crank with a Stages that I will occasionally swap onto my race bike with Di2, shifts fine.
#7267
My idea of fun
Bikes: '06 Litespeed Tuscany, '02 Kona Lavadome, '07 Giant TCR Advanced, '07 Karate Monkey
Quoted: 41 Post(s)
Liked 59 Times
My Quarq died today. But they have great customer service.
#7268
Quoted: 31 Post(s)
tongue and cheek, but they do have great customer service. i have been on a quarq since late 2009, when my cinqo died in 2012<?>, it was replaced with a riken. when that riken died last week, it was replaced with another riken. turnaround time door to door was 6 days. with warranty and service like that, despite whether it should have died or not, once you're "in" on a quarq, it's hard to get "out."
did you try to reboot? if it's a riken, you just take out the battery, put in a couple pennies, close the battery compartment, wait about 5 seconds, then open up and replace coins with battery and try again.
#7269
My idea of fun
Quoted: 41 Post(s)
Liked 59 Times
The best customer service is the one you never use. I've done the swap out dance with them 4 or 5 times in the past, but this one has gone "strong" since 2012. Granted, I only ride a fraction of the hours I used to ride.
I'll try the penny trick, but it was also really humid this morning, and as I recall, water was the thing that made those things fail.
#7272
