Changing crank gear size
#51
Quoted: 1324 Post(s)
Liked 927 Times
I'm a new rider, over 50, about 265lbs. I have Trek Verve 2, crank gears are 48/38/28. On the hills I'm running out of power to keep going. I'm wondering if I can get mountain bike crank with 42/34/24 gears to swap out. What all would be i need to get? Will any crank work? I would think I need a new crank and a chain, but what else?
If there is a bicycle co-op near you they will have both the tools needed and the expertise to show you how to do it.
Good luck and cheers
#52
Bikes: Soma Double Cross Disc (2017), red Hardrock FS (circa 1996)
Quoted: 217 Post(s)
Liked 155 Times
You may need to shorten the chain if you go from 48 to 44 or 42, search for the "big-big +1 chain sizing method"; otherwise it may be slack in some gears. Make sure to not make it too short, otherwise shifting to the big-big will destroy at least the rear derailleur + hanger.
You front derailleur may be not ideal, they are optimised for some different between the big and the middle, in your case it is 48-38=10. If you go to 42/34/24, it is 42-34=8. It may work. You can also go to 42/32/22.
Most likely your crank uses square taper bottom bracket, they can have different spindle length. Square tapered cranks for 8 speed do not cost a fortune; e.g., https://www.jensonusa.com/Shimano-Al...Square-Crankst
Assuming it is square taper and both cranksets need more or less the same spindle length, you will need a crank bolt wrench and a crank puller to do the swap:
https://www.parktool.com/product/cra...-cranks-ccp-22
https://www.parktool.com/product/crank-wrench-ccw-5
Some 9 speed cranksets (44/32/22) may also work. Higher end ones will use a different bottom bracket system (Hollowtech II).
#53
Wow there’s a lot of dick waving and bee itching here. Grow up people.
As to the original question. There’s two trains of thought as you have seen. Try and ride it out and build muscle to negate the need for any modifications. This is more cost effective and cheaper. But if not done right can be frustrating and even can cause some injuries.
The second is what your were asking is to change gearing on your bike to make things a bit easier at the cost of speed. This options may negate the frustrations and chance of any injury. But it’s an expense and could end up being unneeded in the future.
The correct option is what you feel is going to get you out riding more. No one on the internet can tell you what’s best. Only you can tell what will get you out riding more. And riding is the only thing that matters. Your not out there to prove anything to anyone. Just get out ride and have fun if that means training or modifications then that’s the right option for you.
Enjoy the journey.
Enjoy the journey.
#54
Liked 927 Times
Ah, I forgot about front derailleur cage shape being different for a crank designed for a 24-28-48 set up and one designed for a 22-42 setup. I'd try a 24 chainring in place of the 28 one first. Then if you still need lower gearing I'd get a rear cluster with a larger cog. If your rear derailleur doesn't work with it you can a rear derailleur hanger extender that's inexpensive and will allow you to use your existing rear derailleur.
Cheers
Cheers
#56
Simply put, low gears can lessen the chance of injury as your giving yourself more mechanical advantage And thus lowering the stress to your body and joints.
Something I did myself. I kept pushing to hard too soon. I was young NEW and didn’t know any better. Torn meniscus in my knee. Not a bad injury and healed fairly quickly. But it was an annoyance and I learned from it. Now that bike had lower gears I just was trying to push too hard a gear for the trail conditions. This was rider error. Something else more prevalent in newer riders.
#57
Mad bike riding scientist
Quoted: 6220 Post(s)
Liked 4,221 Times
Depending on the bolt circle diameter of your present crank, you might NOT need a new crankset. You might be able to put new chainrings on your existing crank. I had an MTB that I used for dirt road touring in Northern Ontario Canada. I needed a lower gear for the hills I encountered there. I ended up just putting a 24 teeth ring where the 28 teeth ring was. Later I put a freewheel with a low cog of 34 teeth on instead of the one with the 32 teeth that came with the bike. That worked for me.
Cheers
Cheers
Stuart Black
Stuart Black
#59
Bikes: Masi, Giant TCR, Eisentraut (retired), Jamis Aurora Elite, Zullo, Cannondale, 84 & 93 Stumpjumpers, Waterford, Tern D8, Bianchi, Gunner Roadie, Serotta, Serotta Duette, was gifted a Diamond Back
Quoted: 305 Post(s)
Liked 2,038 Times
Im not familiar with the crankset on the OP's bike but isn't a simple solution to replace the 28T chainring with a 24T chainring?
#60
Old and in the way.
I think swapping the chain ring is a great idea. I mean you can ride it with a 28, but you are more likely to enjoy it with a 24, so ride the 24 and if it gets to easy switch back. The more you enjoy it the more you ride the faster you get in shape.
I mean I CAN do roofing with a jewelry hammer, but its a lot faster and more enjoyable with a roofing hammer.
#61
Liked 927 Times
CoffeeDrinkerNC can't change rings. The crank on the Verve has riveted rings.
The shape of the front derailer isn't as much of an issue as people make it out to be. The chainring size range that a front derailer will handle is rather broad with the cheaper Shimano units being far more forgiving than the more expensive ones. The derailer will have to be lowered to accommodate a 44 or 42 (I'd suggest the 44 to maintain a little higher high range) but that's trivial. The rear derailer will handle any kind of change easily. The chain might need to be shortened by a couple of links, however.
Cheers
#62
Liked 4,221 Times
However, the problem you are describing can’t really happen. If all someone has done is to change the inner ring, the position of the derailer is exactly the same. The height of the derailer is set to clear the largest ring but has little to do with the inner chainring. If the radius of the derailer is meant for a 52 tooth gear and a 48 (46 or 44) tooth ring is used, the tail of the derailer would set further back from the crank than it would for a larger chainring. There’s no way it could snag on the crank. It might hit the frame but it won’t interfere with the crankset.
Stuart Black
Stuart Black
#63
Liked 927 Times
Gee, I guess I was imagining things then. LOL VBEG
What I SAW, was this. The shape of the front derailleur cage on the derailleur designed to be used with a 28 ring had a far more gradual curve to it and a longer curve than did a derailleur designed for a 22 ring. Thus when the crank with the 22 ring was installed the rear of the derailleur cage would catch the on top of the chain and jam when trying to shift up from that 22 ring. That's precisely why derailleurs designed for use with a 22 rung have a different cage shape than one designed for use with a 28 ring.
Cheers
Cheers
#64
Liked 4,221 Times
Cheers
Cheers
The Verve that CoffeeDrinkerNC has is equipped with a Shimano Tourney TY710 front derailer. It’s a mountain bike front derailer and Shimano mountain shifters. Shimano doesn't make derailers for 48/38/28 and another for 44/34/22 cranksets. They make derailers for mountain cranksets, period.
Stuart Black
Stuart Black
#65
Liked 927 Times
As for “imagining” things, you must think I’m imagining things as well (or instead). I have a 46/34/20 with an 11-36 cassette that I shift with a front derailer designed for a road 50/39/30 crankset. It’s capacity is supposed to be 20 teeth and I’m pushing it to 26 teeth. It has never jammed or even had problems making a shift in roughly 10,000 miles of use on a loaded touring bike.
CHeers
#66
Señor Member
Quoted: 649 Post(s)
Liked 292 Times
How can we be sure the OP needs lower gears? The OP said they need lower gears, that's how. Suggesting that they just HTFU and learn to mash away in too high of a gear is insulting and ignorant.
#67
If you are a NEW rider, you have plenty of gear. Keep riding, working on developing your cycling abilities. Later you find you have enough gear as your legs get stronger.
When I started, a one mile 5% hill was killer on the same gears. After I got a few miles under my belt, developed my legs a bit, I was riding up much easier in bigger gears.
I see the Verve has an 11/32 in the rear, I believe you have enough gears to climb a wall. I'm guessing it's about developing the legs as most NEW riders will.
#68
Bikes: Modified 26 inch frame Schwinn Varsity with 700c wheels and 10 speed cassette hub. Ryan Vanguard recumbent. 67cm 27"x1 1/4" Schwinn Sports Tourer from the 1980's. 1980's 68cm Nishiki Sebring with 700c aero wheels, 30 speeds, flat bar bicycle.
Quoted: 131 Post(s)
Liked 141 Times
I'm really not at liberty to admit how low or high my bicycles are geared.
