Bike Porn V2.0
#4451
Quoted: 16 Post(s)
Liked 43 Times
I love those type of descriptions...
Then uploads the most serious beach photoshoot this side of Sports Illustrated Swimsuit ed. for his bike.
This thing shouldn't be taken too seriously...
#4453
A little North of Hell
Quoted: 71 Post(s)
#4456
Clark W. Griswold
Quoted: 4359 Post(s)
Liked 4,000 Times
#4460
canis lupus familiaris
Bikes: En plus one
There is a pinch bolt at the bottom of the steerer tube-top of the fork crown. Basically the steerer tube is removed from the frame and the fork/truss can be removed forward.
#4461
Bikes: Handsome Fredward, Trek 1.1
Quoted: 481 Post(s)
Liked 131 Times
#4463
Quoted: 71 Post(s)
#4466
Clark W. Griswold
Liked 4,000 Times
Phil always looks good. Campy does some nice stuff but their more modern stuff has lost some of the flare and panache but Phil has stayed the same and the same is real good!
#4469
Bikes: Civilian Le Roi Le Veut, Kazane Track, Ciocc Designer '84, Serotta Colorado AL 25th anniversary, '85 Guerciotti Pista, '84 Trek 660, Volume Credence
Quoted: 399 Post(s)
Liked 274 Times
Mercian is still around and making custom frames, this one has 120mm rear spacing and despite the look it is not very old. I wonder about the choice too but original owner must've ordered it like that...and IMHO is still pr0n-worthy
#4473
Bikes: En plus one
You just pull on the cables. The ends are held in one of the stand off the housing is held in the other.
Its confusing because there is a piece of sheath (housing) in the middle so that the cable doesn't cut into your hand.
#4475
Bikes: En plus one
Good point, i guess i hand't given it much thought. I am trying to remember how to calculate the tension generated. I think it behaves like a Catenary, which has a non-linear tension to force, (like a suspension bridge) but quite frankly i have forgotten .
I have only ever seen the system on show bikes but it should work ok with the long arm calipers shown in the photo. Plus since you are closing your fist around the bar and the cable, I am guessing most people could generate a fair amount of force.
