#5651
Bikes: 79 Trek 930 is back on the road, 80 Trek 414, 84 Schwinn Letour Luxe,87 Schwinn Prelude, 92 Schwinn Paramount PDG 5
Quoted: 3214 Post(s)
Liked 1,864 Times
Yesterday I put my 79 Trek 930 back together, in order to try out a set of bars I've had for ten years or so and never mounted. It needed only wheels and brake levers/cables. The bars were a fail, but I may go ahead and put another set on it and ride it awhile.
Likes For jim dandy:
#5653
Quoted: 1609 Post(s)
Liked 2,216 Times
I needed a humble nut for a Campagnolo SL pedal that was also missing a cap. @jethin generously send me the pedal shown on the left.
GransSportBentc on Flickr
After a lot of clean up with disassembly and assembly, the pedals are done.
NRFrejus1 on Flickr
Since I have not taken a pedal apart like this, it was a great learning experience, including what is not readily available and what is, you pay a dear price for (dust caps, still needed). I decided to see if I could use my HF bearing pullers to remove the cup in the GS pedal.
GransSport2 on Flickr
It is a different cup from what is used in the SL pedal.
Next was to see if I could straighten out that nasty dent. I failed to take pics of the process while in process but here are the pics. You can figure it out.
GransSportVice on Flickr
GransSportViceClamp4 on Flickr
GransSportViceClamp1 on Flickr
End result.
GransSport1 on Flickr
I can hear it now, "Its aluminum! It's not supposed to behave like steel!"
It works with handle bars too.
P1030009 on Flickr
Don't try this at home and don't use the parts! Too many stress risers to contribute to physical mutilation.
NRFrejus1 on Flickr
End result.
P1030009 on Flickr
Likes For SJX426:
#5654
Bikes: Motobecane C41, Matsu$hita Nashonaru
Quoted: 215 Post(s)
Liked 438 Times
Got some new (old) stuff delivered today, so now I'm sitting with a nice mug of coffee and tinkering.
Today I'm focusing on the Cyclone. For now I'm only after some bolts and jockey wheels for an older, 1975 one I overhauled recently, but I'm going to rebuild this one at some point, so I thought I might as well take it apart and prepare it for cleaning. Something for a nice, relaxing Monday evening. Though I will still probably end up covered in grease. The plan is to replace Huret Success Titane on my 1979 Moto (yesterday replaced the shifters with Suntour Power Shifters). Not sure if the swap is going to be permanent, but I do like the look of Cyclone and I'm keen to try it. Looks like jockey wheels on this one below ctually have sealed bearings, so they must be a later replacement, but they are not very worn out and spin nicely.
Likes For VintageSteelEU:
#5655
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3898 Post(s)
Liked 6,501 Times
Was riding my '72 Torpado the other day, coasting along all nice like and then found myself spinning out of gear. What the? Upshifted and still spinning out. Oh, the freewheel pawls aren't locking. I stopped, back-pedaled, and it worked again. Hurried home.
So I needed to disassemble its IRD freewheel and understand what was going on. There was a lot of grime around the pawls where one side just wasn't springing up at all. I flushed it out with WD-40 and also made sure the spring, which is basically just a circular piece of metal, was in the right position. It's not a full, connected circle, so it has to be set in just the perfect position, else it will prevent the pawls from springing up.
It was a little difficult to get the lock ring off, but I did manage to open a similar Sunrace freewheel to see how its pawls are oriented. The innerds of these two freewheels are very similar in construction, like they're made by the same factory. Apart from the vastly different cogset, the IRD is a little bit nicer in material, like with the shiny lower race.
With the pawls being the same between the two freewheels, I decided to use the newer Sunrace paws in the nicer looking IRD. I probably didn't have to do this, because I think most of the problem was the IRD's spring just wasn't in the right position. Anyway, both freewheels are now working great. <knock wood>
This is the only IRD freewheel I have in service right now. They're very nice looking, but it's the third IRD that (halfway) failed on me. Not fun.
@pastorbobnlnh would be so proud. I didn't replace any grease around the spring/pawls. Hope that's correct.
Likes For SurferRosa:
#5656
Quoted: 4520 Post(s)
Liked 6,407 Times
NRFrejus1 on Flickr
End result.
P1030009 on Flickr
NRFrejus1 on Flickr
End result.
P1030009 on Flickr
#5657
Cantilever believer
Quoted: 546 Post(s)
Liked 1,891 Times
My primary wrench-twisting for the past several days has been to fix up a bunch of bikes that will be donated by our church as part of the Christmas season help to those in need. The bikes were contributed by the Recycle Your Bicycle program from bikes available after all the foster kids' needs were filled. I just provide the repair work (and a lot of scrubbing) to get them ready for more adventures. Mostly singlespeed coaster brake bikes, but some with derailleur drivetrains - and more than a few of them with dry chains and finicky hub cones. Also, two of the bikes initially had utterly gunked-up Rapidfire shifters, which I was able to pull and clean in the ultrasonic cleaner, and reinstalled they happily click easily from gear to gear. And the Schwinn cruiser in back had a DOA shifter for the Nexus 7 hub, for which I was able to order a replacement after several patient weeks of waiting as it made its way across the ocean.
The gaggle of finished bikes so far:
I'll see if I can get one or two more done before they have to be dropped off in a couple of hours...
Likes For RCMoeur:
#5658
Quoted: 939 Post(s)
Liked 2,969 Times
I finally carved out enough time to finish the build on the Ted Williams Free Spirit frame I bought from @nlerner. There was some trial and error, especially with the drivetrain. Except for the new Tekro long reach brakes and VO levers everything is from my parts, the C&V Box o' Crap or other list members sales. It was too wet to do a shakedown ride today so I hope to do that tomorrow and on Monday I'll bring it back to Manhattan for my son.
The saddle and bars will come down for my son, I'm much taller.
The Microshift is a great derailleur. Neal, if you spread the frame, thanks for saving me the trouble. Dropouts needed a touch of aligning but otherwise it's perfect.
The wheelset included a dynamo hub and front/rear lights.
The lights are very similar to B&M, but with plastic bodies.
Tiagra front, and I've held this Maxy crankset for 10 years. I pulled it off a 24" wheeled Junior Raleigh Grand Prix that my old teacher included when he gave me his PX-10. It shifts ok but I'm a little concerned about how it will fare with the narrow 10-speed chain, the gaps are big and the chain was dropping between rings a bit. I think it looks great though, and the compact range is perfect.
Cockpit view.
Bringing up the rear.
I provided the revised BOC label redesign so I'm tickled to have a build that I can display it on!
Cockpit view.
#5659
Bikes: BMC Road V2; '17 Marin Pine Mountain 2; '91 Marinoni Special TSX; '89 Specialized Stumpjumper Comp; '98 Salsa La Cruz; '79 Centurion Pro Tour; '77 Romic custom sport-tour; '77 Centurion Semi-Pro; '23 Kona Sutra LTD
Quoted: 62 Post(s)
Liked 220 Times
Starting up a new wheelset:
FH: Dura Ace 7400, low flange, 28H, Salsa Ti skewer
RH: Ultegra 6500, low flange, 32H, Ultegra skewer
Rims: H+Son TB14, 28/32
Spokes: Wheelsmith DB14
Nipples: Brass for the rear; Alloy for the front
The hubs are both in excellent condition, and just needed a nice cleaning/repacking. I'm really enjoying the quality of the H+Son rims, even if they're a little heavy. I expect these to be long-lasting, light touring/long distance style wheels for mixed surfaces. The full build should come in at about 1,900g
Edit: without QR skewers, the wheelset comes in at 1,862g; 9g lighter than an Ultegra 6700/Mavic Open Pro wheelset I also threw on the stand to tighten up.
Likes For fvernon:
#5660
Bikes: I hate bikes!
Quoted: 431 Post(s)
Liked 710 Times
Cockpit view.
Cockpit view.
#5661
Quoted: 939 Post(s)
Liked 2,969 Times
Accepting candidates! If I'd had one I surely would have included it.
Likes For ascherer:
#5662
Bikes: '92 MX Leader, 84 Colnago Mexico, 85 Recherche, 86 Panasonic ATB Pro, 88 Roberts, 80 moser... ect
Quoted: 68 Post(s)
Liked 136 Times
Almost there... started with this.. 1972 Harry Hall
Yes, I took a lot of pictures, but I'll skip some.
I took the bicycle apart, cleaned, greased, ect... It was in very good shape under the dust.
Now waiting for toe straps to finish.
The bike is 120mm rear spacing. I don't want to do anything to the original wheels other than save them. I put a set of clinchers on to ride.
I think the campy 1060 vertical ends are pretty cool.
Likes For uncleivan:
#5663
Bikes: 1993 Diamond Back Sorrento, 1965 Schwinn Racer 3-speed, 1987 Schwinn High Sierra, 1990 Specialized Sirrus, 2020 Specialized Sirrus 3.0, 2013 Giant Seek 1
Quoted: 87 Post(s)
Liked 776 Times
Took my High Sierra down for an overhaul. Frame is now cleaned/polished, reassembly will start soon. Everything is in good shape component-wise, new cables/housings will go on though.
Likes For zookster:
#5664
señor miembro
Liked 6,501 Times
I was disappointed to find the rim labels backwards on the $10 wheelset I got off Craig's the other day. I've seen a lot of old wheels like this. It bugs me.
After removing the kinda ugly plastic rim tape on the rear, I found something worse, the ds spokes are way too long. No wonder he used plastic to protect the tube.
So what to do? I removed a ds spoke and compared it to some in my stash. I found just the right number (18) that were a more appropriate length, about 4mm shorter, and decided to rebuild the wheel with the rim label in the proper position. What the hell. It's winter.
And at least I don't have to worry about polishing the Miche hub. It's in great shape.
The thing is, now I've gotta rebuild the front too so the labels match. Because I don't have to switch out any front spokes, I think I'll try to tape the front spokes together so I can just loosen the nipples, flip the rim around, and put everything back together. Might save a little bit of time anyway.
#5665
Just finished a overhaul on a Centurion Le Mans 12 for a guy at work.
Likes For Wright Bros:
#5666
señor miembro
Liked 6,501 Times
Got the rear all the way laced up just to find all my leading spokes are too long on both sides now?? Wait. Was this thing 4-cross? This thing was 4-cross! Who builds a 36h wheel 4-cross??!!
Guess I'm leaving it that way. Finally fixed. Whew. That was a first. Now I know to always check the pattern. Seemed weird the ds spokes were well over 300mm. With a $10 wheelset, there's always a catch...
#5667
https://www.bikeforums.net/classic-v...r-1-700-a.html
Post #6
cheers -m
Likes For steine13:
#5668
Cantilever believer
Quoted: 546 Post(s)
Liked 1,891 Times
Working on a couple of unusual* conveyances this afternoon on behalf of Recycle Your Bicycle - a Sbyke skateboardish scooter with a 16" front wheel, and a Mobo Tri-ton 3-wheeler with a direct drive 20" front wheel and two 16" wheels. The Mobo is fun once you get used to it, although the 20" 'gear' does limit one's top speed on level ground.
*Doctor: "You have Tom Jones disease."
Patient: "Is that rare?"
Doctor: "It's not unusual."
Likes For RCMoeur:
#5669
Cantilever believer
Quoted: 546 Post(s)
Liked 1,891 Times
I've built quite a few 36-spoke wheels with a 4-cross pattern earlier in my wheelbuilding days, although all of them have been either 27" or 700C.
#5670
señor miembro
Liked 6,501 Times
#5671
Quoted: 1079 Post(s)
Liked 1,900 Times
I thought the spokes looked close to the neighbouring heads when you first posted them up, but I was too shy to say anything.
Likes For P!N20:
#5672
Quoted: 215 Post(s)
Liked 438 Times
I think I'm addicted to derailleurs these days. On one Moto I've replaced Huret Success Titane with Suntour Cyclone, which of course needed cleaning (and still needs some fine tuning) and since I couldn't find Suntour Cyclone front derailleur (MK 1), I got Suntour Blue Line which will go on the bicycle soon.
For my other Moto, which currently has Shimano 600EX SIS RD and FD, I got Compe V for the front and Suntour VX-S for the back. Compe V is NOS, so won't require much work. The VX-S was of course filthy when I got it, so I had to disassemble it, clean it properly, give it a bit of light polishing, load it with grease, oil the pivot bolts and put the whole thing together. Luckily, the pulley wheels are in acceptable shape. Busings a bit mangled, as usual in old derailleurs, but I've seen worse. Overall, a very nice derailleur. I'm quite impressed how sturdy this thing feels after well over 40 years! OK, at 215g it's heftier than Cyclone, but I think I actually prefer it over Cyclone when it comes to the way it looks as well. VX-S has a sort of Art-Deco feel to it. Of course, all the nice grooves I like are going to attract grime like nobody's business, but I guess it's not too difficult to clean with a small brush if need be. Love the cage, it seems I will be able to get the chain on without the need for opening the quick link.
Tomorrow I think I'm going find a moment to put it on the bicycle and see whether I can get it working with indexed Shimano shifters.
Nice and clean
Perhaps one day I will find time to give it mirror polish, but for now this should suffice
Nice and clean
#5673
Quoted: 215 Post(s)
Liked 438 Times
Do you mean the hub labels? I'd leave it as it is - you can justify it each way; either it can be read from the front of the bike or from the rider's POV when you're sprinting in the drops.
As for hub labels / markings, that might vary. I have a wheelset with Ultegra Tricolor hubs where hub labels are facing NDS for some inexplicable reason. Seriously considering getting new decals and getting this right
Likes For P!N20:
#5675
Cantilever believer
Quoted: 546 Post(s)
Liked 1,891 Times
"In those days of legend, it was the way of our people. But such wisdom has vanished from these lands."
Likes For RCMoeur:
