Retro roadies- old frames with STI's or Ergos
#7126
Old Legs
Bikes: '80 Strayvaigin, '84 Ciocc Aelle-Shimano 105, '90 Concorde Astore /Campy Triple ,85 Bridgestone 500/Suntour, 2005 Jamis Quest, 2017 Raleigh Merit 1, Raleigh Carbon Clubman
Quoted: 302 Post(s)
Liked 33 Times
#7127
Bikes: BMC TeamMachine, Surly Pacer, All City Big Block
Quoted: 92 Post(s)
Liked 62 Times
I have become sufficiently jealous and inspired by this thread. The CL search begins!
A couple questions: Does anyone have experience buying a lone frameset and then a complete groupset? Of course it depends on the frame, but for vintage roadies what do you look for in a modern groupset? Also, I see a lot of threadless headsets in this thread. What is the general era that these start to pop up? I've never had one on a road bike but I think I'd like to for modern stem and bar combinations.
#7128
My 1989 Schwinn Circuit. Shimano 105
#7129
Shifting is fun!
Bikes: Yes, please.
Quoted: 2199 Post(s)
Liked 4,619 Times
Isn't it? I'm actually thinking of going totally overboard and upgrade to 18-speed!
#7130
Bikes: Yes, probably too many but still have a roving eye...
Quoted: 317 Post(s)
Liked 2,809 Times
My Brian Rourke has had an update, with some 'new' wheels, Campagnolo Chorus 10 speed hubs, Sapim spokes laced to Mavic Open Pro rims, and Vittoria Corsa G+ tyres.
#7131
Bikes: Indeed!
Quoted: 1508 Post(s)
Liked 3,481 Times
Brent
#7132
Fixie Infamous
Bikes: 2007 CAAD Optimo Track, 2012 Cannondale CAAD10, 1996 GT Force restomod, 2015 Cannondale CAADX
Quoted: 54 Post(s)
Get some downtube shifter to barrel adjust adapters. Problem Solvers sells em.
When your getting a groupset just mind how the front derailleur is attached and bottom bracket compatibility.
#7133
Quoted: 634 Post(s)
Liked 444 Times
The threadless bits you see might be threadless stems clamped to adapters that fit into threaded forks. It's the easiest way to put a modern cockpit on a vintage bike with a threaded fork and headset. You can also go the 1" threadless route, but that stuff is getting harder to find and you would need to get a new fork and headset.
#7134
Shifting is fun!
Bikes: Yes, please.
Liked 4,619 Times
Only with a with a quadruple up front, as my brifters are old 9-speeds. Who needs that many speeds anyway?
Nice bécane, BTW!
Nice bécane, BTW!
#7136
Pedalin' Erry Day
I have 5 bikes that fit this category, and only in one case did I need to "cold set" the rear triangle. That last one is a truly exceptional case because I use that frame as my main commuting bike, and my route to work is about 50% off-road trail, so I respaced the frame so that it would happily accept the 135mm MTB hubs which were part of a wheelset that was previously in use on my CX bike.
#7137
Quoted: 502 Post(s)
Liked 466 Times
My ‘87 Marinoni was built for a 130mm rear hub, but the ‘79 Miyata was re-spaced to that width. I had it done professionally, but I’ve also done a DIY re-space on a weird tandem. Twasn’t hard to do.
#7138
Quoted: 378 Post(s)
Liked 1,410 Times
None.
And that's a lot of bikes.
Only from 126 to 130, though, never from 120.
I've tried 120 to 126 once, and immediately switched back, for peace of mind.
For me, a 120 means 5 speeds, and the quotient is an even number, so I like it that way.
#7140
Quoted: 4237 Post(s)
Liked 2,949 Times
Yeah, but that's the thing about a triple. You can leave on the race-y gearing (53/42) while adding a granny. If you want to keep the race-y look of a double, you lose the race gearing. Plus 3 is more than 2 and more is moar better.
#7141
Curious as to why not more riders used the Dura-Ace 130 hub with the 'mushroom' locknut?
#7142
Quoted: 378 Post(s)
Liked 1,410 Times
Just put-it-in-the-frame and ride.
You quickly develop a technique for the rear wheel that works and saves your knuckles, too.
As for the DA 130 hub, if you mean the 8-sp with the locking cog, well, that was a problem with the cassettes, too.
I also think Shimano sort of shot themselves in the foot (feet?) from the DA 6sp freewheel right up through the 8-sp STI, with compatibility issues, and that stigma lingered a while. People just avoided Dura Ace, both for the issues and the cost. Which only benefited Ultegra even more, and still does. The R8000 is selling like crazy.
#7143
HarborBandS
Quoted: 266 Post(s)
Liked 104 Times
Unlike Robbie, I wasn't able to squeeze a 130mm hub in the Schwinn Super Sport frame pictured in this thread back in late October. The rear stays were just too rigid. So I cold set the frame using the threaded rod method that can be seen on "RJ the Bike Guy's" YouTube channel. I feel this is more gentle and safer than the old Sheldon Brown 2x4 lumber lever method.
#7144
HarborBandS
Quoted: 266 Post(s)
Liked 104 Times
I spent more on components for that build that I might re-use on a future bike (105 5800 components, seat post, wheel set, saddle, etc), but didn't put a lot of dough in the frame, headset, and fork. A lot of this stuff may end up on a nicer frame at some point in the future.
#7145
Quoted: 7353 Post(s)
Liked 2,483 Times
#7146
Hump, what hump?
Bikes: See signature
Quoted: 337 Post(s)
Liked 227 Times
Another BF'er with a Rourke. Sweet.
#7147
Quoted: 378 Post(s)
Liked 1,410 Times
You can keep your C&V 1" threaded fork, and it replaces both the headset and the steerer tube, and can vary in length. It has a 1 1/8" steerer to fit modern stems, and comes with spacers, as well. Looks good, retains the original fork.
It comes in both silver and black, and is sold by joejack951 here on BF.
This (1999) is with the OEM 1" threaded fork, and I didn't cut the steerer because the fit is dead on this way.
This (1984) is with a replacement (Performance) 1" threaded fork from a BF member. Due to the fit of the bike, I cut the steerer to create the fit I wanted.
#7148
Sempiternal Newb
Bikes: '92 Trek 750, '85 Univega Gran Turismo, '95 Stumpjumper,
Quoted: 232 Post(s)
Liked 15 Times
I put together this Black Lightning last night and took it for a ride this morning. Dura Ace 7800 shifters, 1x10 with the original Suntour Superbe Pro crank and an eBay Special chainring. Absolutely my favorite road frame so far. I did some crit practice loops in a parking lot - dang this thing can hold a line around some tight corners. It'll eventually get repainted, this thing definitely deserves some love.
#7149
Quoted: 378 Post(s)
Liked 1,410 Times
Looks fast sitting still.
#7150
Bikes: Hetchins, Dawes, Raleigh, Holdsworth, Standard Cycle Co, and others
Quoted: 34 Post(s)
Liked 6 Times
At the same time I took a frame I wanted to be good to ride, and so I selected modern components, and the only problem is I had to change the bottom bracket because I was using a triple instead of a single and I needed a longer shaft for the clearance.
The only frames I have struggled with are vintage French, because everything is different. Different threads, different diameters, and difficult to get spares.
This means that instead of replacing old parts such as a worn headset, I end up renovating and rechroming parts - very expensive.
