Rim brake touring bikes extinct?
Clark W. Griswold
Quoted: 4359 Post(s)
Liked 3,998 Times
Apparently it does.
Rim brakes will be dead when Paul stops making them and eeBrakes stop existing until then rim brakes are still around even if a lot of folks are moving to discs (which is not a bad thing).
Quoted: 3462 Post(s)
Liked 1,468 Times
Send bikes direct an e-mail and ask if they might ever get another Windor Tourist in your size again.
Save Up to 60% Off Touring Bikes | Commuting | Commuter Bikes | Windsor Bikes - Tourist
I really think that canti brakes are very unlikely to cause your breakdown. And it has to be pretty steep downhill to need both front and rear brakes.
Bikes: 1989 Miyata 618GT, 1986 Fuji Sagres
Quoted: 22 Post(s)
Liked 16 Times
I second the suggestion to look for used, maybe even vintage, depending on your preferences. Lots of great canti brake bikes out there in good condition and often underpriced precisely because they don’t have discs.
The Surly LHTs seem to still command a premium for some reason, but other comparable bikes often do not.
PS it looks like Fuji still sells their touring bike in a rim brake version if you want something new
Thanks. I'm actually fairly rich in that department. I have a '89 Miyata 618GT (next model down from the 1000) that took me cross-country; it takes a 35mm tire (maybe 38). And last year I picked up an almost never used Fuji Touring Series III on eBay. But neither of those bikes will haul a load without twitching like the Surly would, or take as big a tire. I've had my fill of "shimmy" bikes for loaded touring. But if I decided to go with a lighter kit or ditch camping altogether, I guess I'd be OK with what I've got.
Bikes: 2014 Trek Allant drop bar conversion, modified Schwinn MTN commuter, 2015 Trek 520, Soma ES, Salsa Journeyman, 1980 Trek 414
Quoted: 178 Post(s)
Liked 355 Times
Soma still makes the Pescadero and Grand Randonneur framesets.
Maybe check out the New Albion Privateer
I just picked up a LHT from Hoopdriver Bicycles in Toronto Canada. Last time I checked stock, they had a few 58 cm (26" wheel) LHTs (complete bikes though). His biggest LHT frame only was 54 cm unfortunately.
Martin is the owner there, he's a good dude to deal with.
I don't know if he'd ship international and getting over the boarder right now (if you are close enough) is not possible thanks to COVID. But if you want one bad enough perhaps you can make it happen.
Good luck.
Good luck.
Sunshine
Quoted: 10966 Post(s)
Liked 7,493 Times
https://www.ebay.com/itm/SOMA-FABRIC...cAAOSw~jlgPrKk
https://blackmtncycles.com/shop/fram...v5-5-frameset/
The first is a lightly used Soma Saga frame.
The second is technically a gravel/monstercross/doitall frame.
I have a Black Mountain MC frame that was built up for gravel riding for a handful of years and is now my touring/commuting bike. Its a 65cm size and there is no twisting or shimmy on it, so a smaller frame size shouldnt shimmy either.
There are proper mounting points for front and rear racks, 3 bottle mounts, you can fit up to a 50mm tire if you want, and the chainstays can be up to 450mm long. Its heat treated double butted 8/5/8 tubing and has a killer fork crown.
58 and 60 sizes are available in olive oil and 58 is available in bright blue.
I have set mine up with fenders and a rear rack in the past and currently have it set up with fenders and a front rack. Its stable either way.
As an added bonus, the guy who owns the brand, Mike, is really helpful and seems like someone who is doing good in this hobby. He has decades of experience with frame design and spec, and has run his own shop for the past 12 or so years.
Sunshine
Liked 7,493 Times
It exists and is a great bike. My parts hybrid is a Privateer frame and it has been fantastic over the years highly recommend it.
Shimano may still make Ultegra caliper rim brakes, TRP may still make long reach caliper rim brakes, Tektro may still make 710 and 720 brakes- but rim brakes are dead once CC no longer makes eeBrakes for the 6 people that buy them each year?
Your elitism becomes more difficult to mask by the day.
Bikes: 2019 Trek Stash 7, 1994 Specialized Epic 1986 Diamondback Ascent 1996 Klein Pulse Comp, 2006 Specialized Sequoia Elite
Quoted: 418 Post(s)
Liked 523 Times
I read through all the posts to see if anyone recommended buying a vintage mountain bike frame as an option. If you can find a good rigid mtb frame in your size, you could build it up into a very capable touring bike.
Quoted: 22 Post(s)
Liked 16 Times
I like the Black Mountain-- looks as strong as the Surly and not much more expensive. Seems to check all the boxes. Thanks for the recommendation.
Likes For Fuji1986:
cyclotourist
Quoted: 443 Post(s)
Liked 205 Times
Those things are getting harder to find as time goes by. I have an 83 original stumpjumper, first generation mountain bike, that was used on the trails in the Canadian Rockies. I put dropped bars on it and toured several thousank kms in New Zealand. It was awesome.Then I used as a commuter, summer and winter for over 20 years. Now it is an ebike. Those were some of the most versatile bikes ever made.
Likes For skookum:
Quoted: 22 Post(s)
Liked 16 Times
Likes For Fuji1986:
Sunshine
Liked 7,493 Times
I will say that my frame was built with 9/6/9 top and down tubes since it was an early version of the largest size. All other sizes are 8/5/8 heat treated tubing for top and down tubes, so ever so slightly lighter and less stiff. At the same time, the frame size is smaller which will greatly offset the ever so slightly less stiff tubing since smaller triangles are stiffer. I mention this because I am guessing the LHT in your size is probably 9/6/9 or so. Whatever it is, its the same or thicker than the Black Mountain's tubing which simply means stiffer.
Just something to keep in mind.
In general, the stiffness talk is funny to me since I am 215# and with gear, thats 240-250# on the bike. I dont notice twist and flexing with this large diamond frame and high total weight, but others hate similar frames due to flex even though they are smaller and there is less overall weight. Preferences and what we notice is just interesting in general.
I would use a rim brake bike again, if the bike had steel wheels, so you didn't have to replace the rim after every 2 years. I can't justify, an alum. wheel, that wears away, and having to be replaced all the time. Steel wheels lasted forever, and if you keep it in good nick, wouldn't rust. But even if it did rust, it would still be working as it is intended 20 years later.
Liked 1,468 Times
Likes For Tourist in MSN:
I still have memories of braking in the rain with rims like that and the bike just kinda shrugging its shoulders and saying, "huhhh? You wanna slow down??"
and who has to change their rims every two years?
Liked 1,468 Times
Yeah, I have never completely wore out a rim brake track. I have noticeable wear on a couple rims, but still quite safe.
I build up my own wheels, so if I wore out a rim, I would complain a bit to myself, and then order a new rim to transfer the hub and spokes over to. Would have it done and all trued up in less than two hours of listening to some mindless tv show while enjoying some red wine.
A fried of mine that is a better mechanic than me thinks that his rims last much longer with Koolstop Salmon pads, I am slowly changing most of my bikes over to those pads. I hope he is right.
But, I do not commute on a bike in bad conditions, if I did I am sure my rims would have a shorter life.
Sunshine
Liked 7,493 Times
Likes For mstateglfr:
My Speedwell, lasted 40 years, a little bit of rust on the bike. The brakes were okay. I was not riding at 60km an hour, so didn't need to stop that hard. The only bad thing about that bike was it was stolen on a tour, otherwise today, another 15 years later, I would still be using it.
really, the worst case scenario for rim brakes is riding loaded on big downhills, on a wet dirt, gritty road where you just have no choice but to brake a lot.
I find commuting easy, rim life wise, just cuz if I ride in the rain, 1- Im not fully loaded riding down mountains, and 2- when I get home, I always wipe the rims with a rag and get all that accumulated gunk off right away before it dries, and do the same to the pads.
Makes a huge difference to helping rim life.
Quoted: 1182 Post(s)
Liked 833 Times
IMO opinion and experience based on using steel rims when I was a kid is that they have less stopping power, especially when wet, than alloy rims. Changing a rim at 25,000+ miles is a small price to pay. We also use KoolStop Salmon brake pads on all our bikes.
A wheel's useful life should be measured in miles not years.
Likes For Doug64:
Liked 1,468 Times
I did not put new pads on my bike before I rode Pacific Coast, but i was surprised how many times each day I would have an 8 percent downhill grade followed by the uphill for a couple hundred feet of elevation every time I passed another creek flowing to the ocean. I brought one spare set of pads for one wheel in my spares bag, but did not get to the point where I needed them.
At the end of the trip, I am sure that there was more wear on the rims, but I could not see it or feel it when rubbing my fingers on the brake track.
But the pads were toast at the end of that trip.
The grooves between the blocks were gone, but during the last half of that trip we never got any rain so the lack of the grooves did not impair braking. Every few weeks on that trip I would inspect the pads and clean them a bit, dig any debris out of the pads, etc.
This was the trip I had a bike with bad shimmy and defective frame that Surly refused to warranty. Thus I used a lot more brake pad than I otherwise might have used because I had to brake harder to keep speed lower on descents. The bike frame went into the metal recycling bin when I got home. That was seven years ago. The rear wheel from that trip is still in use on my rando bike. Still have the front wheel but that wheel lacks a dynohub and is in semi-retirement.
