ISO and for trade thread part 5
#2501
Quoted: 535 Post(s)
Liked 346 Times
ISO: Shimano bottom bracket cup with an o-ring style dust seal
I just discovered that my DA 7400 fixed cup is missing its dust seal. I’m attaching a couple of photos of the adjustable cup for a reference to the style of fixed cup I’m looking for.
Notice that the seal is just slightly smaller in diameter than the cup spindle hole. And it sits in channel between the inner and outer flat surfaces of the cup.
Condition and thread pitch of the cup itself doesn’t matter. I only need it for its dust seal.
• Would prefer to cash out, but trades might be doable too.
#2502
www.theheadbadge.com
Quoted: 2424 Post(s)
Liked 4,407 Times
#2503
verktyg
Quoted: 1036 Post(s)
Liked 1,239 Times
ISO: Shimano DuraAce FC-7400 LH Crank Arm FOUND
Found, sort of... but still looking.
Thanks for all the looks...
I bought a NOS 165mm Shimano FC-7400 LH crank arm on eBay that I'm going to try out.
165mm is only 5mm shorter than a standard 170mm crank arm: 5mm = 0.197" - that's less than 1/4". Road tar (or dog doodoo) on on the bottom of your shoe!
Over the past 45 years I discovered several bikes that I'd been riding that had mismatched crank arm lengths: 170mm & 172.5mm, 170mm & 175mm. I never noticed the difference!
In 1976 I built myself a lugged frame for 700c wheels with a BB height of almost 12" to use off road with 180mm TA cranks. It made a noticeable difference with 26T x 34T gearing.
Looking for a DuraAce FC-7400 Left Hand crank arm in nice condition. 170mm/172.5mm/175mm OK.
verktyg
verktyg
Chas. ;-)
Chas. ;-)
#2504
verktyg
Liked 1,239 Times
ISO: 1960's Peugeot PX-10 Blue/Yellow Lugs
Looking for an early 60's blue and yellow Peugeot PX-10, 54cm to 57cm C-t-T in reasonable condition. Looking for a complete bike. Patina OK but NO RUST or dents.
Restored 1959 bike:
Something like this 1962 PX-10 would be great!
verktyg
Restored 1959 bike:
verktyg
Chas. ;-)
Chas. ;-)
Likes For verktyg:
#2505
Liked 4,407 Times
ISO: Long-lever Sturmey-Archer 3-speed shifter from the 1950's. Can be cosmetically rough.
I'm really surprised there hasn't been an explosion of people taking 1970's PX10s and repainting them as tributes to the 1960's variants. The blue and yellow is so much nicer to look at. Exciting.
-Kurt
-Kurt
#2506
Quoted: 1324 Post(s)
Liked 927 Times
Cheers
Edit. No charge for the seal or for sending it to you.
#2507
Quoted: 535 Post(s)
Liked 346 Times
I’m under the assumption that the seal might be a shared part across Shimano cups of different groups within the era, but I’m in no way certain.
This is the type of problem that’d I’d usually solve with a trip to the co-op. But our co-op is still closed until further in relation to Covid-19.
Here’s a few pics of the seal. I’ll add that it’s approximately 2.5 ml thick at its center. If you have one that looks like it might be a direct replacement, or a suitable substitute, I’d love to give it a go.
#2508
Liked 927 Times
To deux jambes
I have three different seals that I'l put into an envelope for you if you want me to. Be aware tht the post is low and it might take close to two weeks for these to reach you.
If that's acceptable to you then PM or email your address and I'll get them out to you asap at no charge to you.
Cheers
Cheers
Likes For Miele Man:
#2510
Old fart
Quoted: 3599 Post(s)
Liked 3,424 Times
Not sure if they're available separately anywhere.
#2511
Quoted: 1204 Post(s)
Liked 1,364 Times
My father aways said to search high and low, what you're looking for is there because I saw it 5 minutes ago.
As a last resort if none of the BF members seals don't workout heres one I found pricey but new.
https://www.loosescrews.com/product/...-7400-bb-cups/
deux jambes
deux jambes
2015 Bianchi Intenso
#2512
deux jambes
deux jambes
https://www.ebay.com/itm/Shimano-Rub...-/254508077232
#2513
Liked 1,364 Times
If you buy it from their ebay store, you get free shipping.
Sweet. I didn't think to look on fleebay. Hope these help deux jambes
#2514
Old fart
Liked 3,424 Times
Likes For JohnDThompson:
#2515
Quoted: 535 Post(s)
Liked 346 Times
deux jambes
deux jambes
On a side note: I did find out that the seal from a 6400 is usable, but not perfectly interchangeable... whatever that means.
#2516
Bikes: 2017 Salsa Carbon Mukluk frame built with XT, 2018 Kona Rove NRB build with Sram Apex 1,2008 Salsa El Mariachi, 1986 Centurion Ironman
Quoted: 286 Post(s)
Liked 100 Times
ISO JIS Square Taper Spindle for 73mm bb
Hi, all. I'm building up a 1995 Stumpjumper frame. I have bb cups and lock ring, but u am in need of a 73mm JIS spindle, 125mm give or take. Anyone have something that would do in a bin?
Don't complain about the weather and cower in fear. It's all good weather. Just different.
#2517
Liked 4,407 Times
Have:
Lots of stuff I don't want (or could get me further to what I need):
FRAMES
Want:
I do know that I will only trade the Nuovo and Super headsets for English Nuovo headsets.
As for the rest...what do you have? When I wrote this, I was thinking about what I have that I don't have an immediate use for, rather than what I'm ISO. (I do need three 26.8 matching non-fluted seatposts, come to think of it).
Interested?
Send me a PM. I don't usually check this thread.
-Kurt
FRAMES
- An early 1970's Carlton Kermesse frame in bare steel, 60 or 61cm IIRC, with original chrome fork. Seatlug ears needed some serious work and a stainless tube was brazed in, but not enough brass was used to fill it. The ears are in really bad shape and the whole mess should be cut off and replacement ears like these brazed on.
- A Spin Gen 2 (ex-dockless rental) frameset w/ bottom bracket and chainguard - no fork. Made for 26x1-3/8" wheels. Wheels were shot and I had to use the fork to salvage another Gen 2.
- A matching pair of Mavic Ksyrium wheels. Same era as the DA7900 group (see below); need to check the model.
- One Sturmey-Archer 40 hole 27" 630mm steel rim hoop from a Raleigh Sprite. Very nice condition. Sorry, don't have the front.
- One Raleigh Twenty / Chopper rear wheel. Original w/AW hub, AW hub does not engage. Straight, good chrome, galvanized spokes.
- One Raleigh Twenty / Chopper rear rim / hoop. Straight, decent chrome.
- A 36h 1975(? - need to verify) Sturmey AW I had hoped to lace into the Raleigh Twenty rear rim above.
- A Raleigh 90mm front hub, 36h. This was also sourced from a Twenty, if I'm not mistaken.
- A dual-wall 559mm something-or-other 1990's MTB rim with a rough brushed aluminum finish. I think it came off of a ProFlex 753, IIRC. I'll find out what it is in the morning. Solid, but stickers are faded.
- Quite a few used, solid rubber 26x1-3/8" EA3 tires. Yes, English EA3. They're from the Spin Gen 2's.
- Dura-Ace 7900 brifters, crankset, and brakeset. Crankset has some rash, probably needs new rings.
- NIB Orgin 8 XLT Road Standard crankset w/bottom bracket, black. 53/39t, 172.5mm.
- Some rear brake linkage doo-dads from said ProFlex 753.
- A really scratched up SR Custom / Nuovo Record two-bolt seatpost in 27.0mm. Needs replacement upper bolts, and polishing - or good for a beater or for a bike where it's going to be installed almost up to the seatlug.
- Campagnolo Super Record single-bolt, short-flute 26.8 seatpost
- Nuovo Record Italian-threaded headset - decent enough, but top nut is meh.
- Super Record Italian-threaded headset - wrench flats are meh.
- Brand-new, basic dual-leg kickstands suitable for 26" and some 27" bicycles with kickstand plates. No bolt, but conventional threads (can measure). These are from the Spins.
Want:
Interested?
-Kurt
#2518
Bikes: Yes
Quoted: 3235 Post(s)
Liked 3,882 Times
ISO the cone nut for the end of a SunTour Superbe brake center bolt, as much like the one pictured here as possible:
I've got a Dia Compe brake that I could use as a donor for a similar look, but I'm hoping to find something closer. Right now the front brake on the bike above has an acorn nut where the cone should be.
My Bikes
My Bikes
#2519
verktyg
Liked 1,239 Times
Blue and Yellow Early 60's PX-10s
"Originally Posted by verktyg View Post
"Looking for an early 60's blue and yellow Peugeot PX-10, 54cm to 57cm C-t-T in reasonable condition. Looking for a complete bike. Patina OK but NO RUST or dents."
I'm really surprised there hasn't been an explosion of people taking 1970's PX10s and repainting them as tributes to the 1960's variants. The blue and yellow is so much nicer to look at. Exciting. -Kurt
Many of the Gitane Tour de France bikes were upgraded by their owners with saddles being the first thing to go followed by derailleurs then brakes.
In contrast, there were a lot of PX-10s sold in our market place but surprisingly few owners ever changed or upgraded the components. Even the few who raced on them continued to use the Delrin Simplex derailleurs and Mafac brakes that came on their bikes???
I first saw a blue and mustard yellow Peugeot about 10-12 years ago. As Kurt said, it was exciting to look at especially compared to the frumpy all white PX-10s from BITD.
Peugeot, Raleigh and Motobecane were competitors to the bikes we sold so I was very familiar with all the features and shortcomings of those brands. I now have as many Peugeots, Motos and Raleighs as I do Gitanes and Bertins. Funny how things work out...
I have an almost NOS 1989 Peugeot Chorus 753 with a Campy Chorus gruppo that I need to put together. It's anything but frumpy!
Here's one of those frames that Hillary Stone from the UK had for sale. This shows the Chorus colors.
verktyg
Chas. ;-)
Chas. ;-)
Likes For verktyg:
#2520
Quoted: 535 Post(s)
Liked 346 Times
#2521
Liked 1,364 Times
verktyg I know its not your size but just for kicks thought I'd post it.
Check out this Peugeot PLX 10 1955-58 Reynolds for $1200 on OfferUp https://offerup.co/lAgJ4xCqM6
#2522
Bikes: Yes
Liked 3,882 Times
Yes, I believe that would work. Thank you. PM me and we can see if I have anything you need.
My Bikes
My Bikes
Likes For malcala622:
#2525
Quoted: 206 Post(s)
Liked 102 Times
Before I head to eBay, I figured I’d check here to see if anyone might have a reasonably priced vintage bottom bracket cable guide similar to the obe pictured here. I’m getting close to being done with a project and realized I need one if these. Let me know if you have something.
Some days, it's not even worth gnawing through the restraints.
