Aluminum: are there any fans left?
#51
I am potato.
Quoted: 1789 Post(s)
Liked 1,629 Times
Aluminum FAN? There is just too much involved in bicycle engineering & variation in components & design to have single minded focus on material.
Nailing any one characteristic to frame material, in isolation, is a fools errand. Bikes components (aside from the frame) are all made with a variety of materials too.
Fanaticism is dumb...As is most other -ism's.
#52
Pertinent to this thread:
https://www.sheldonbrown.com/rinard/...tigue_test.htm
The strongest, most durable and long lasting frame in the test was aluminum.
#53
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
#54
I think I know nothing.
Quoted: 233 Post(s)
Liked 290 Times
My point (after that long digression) is that steel, when it breaks, fails in a manner that rarely causes injury (barring non-heat treated nickle-plating and other known no-no's). Aluminum (and carbon fiber) do not share that, Yes, both can be made very well and strong and go a long ways, but as I said before, I ride frames I love until they break. I want them to die gently - for my health.
Ben
Ben
Likes For Thomas15:
#55
Quoted: 1944 Post(s)
Liked 2,164 Times
#56
Likes For mr_bill:
#58
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,219 Times
Ben
I've broken steel frames and parts and I've broken aluminum frames and parts. Steel has always just gone "ping!" and it's broken...think of how a spoke breaks. I've broken pedals...the spindle just sheared off without warning or bending or gentle release of energy. The spindle was attached one minute and broken in two the next. Steel frames have broken on me the same way. There's not warning. The frame is just broken. I've had a steel fork break on me which I discovered while I was changing bearings but the crack never manifested as anything that could be seen as a warning that something was wrong.
On the other hand, I've broken a fair share of aluminum parts as well. I broke a crank. When I thought back on it, the crank was making a creaking noise long before it broke. I've broken numerous rims from cracks at the spokes to cracks down the middle of the rim on the inner wall to side walls. They all made noise prior to failure. Same with frames. The frames creak and groan prior to me noticing cracks. I also broke an aluminum fork and it made a lot of noise before it broke. Often I've ignored the noise but it was there and noticeable even if I didn't note it.
This makes sense if you consider the way that both materials behave under load. Steel, being stiffer, doesn't really bend until such time as there is too little metal to hold the tube in place. When the last little bit of metal breaks it does so rapidly because the material is stiff and strong. The steel can handle bending even as the crack propagates because of the stiffness and strength.
Aluminum is strong as long as the tube is solid but when a crack develops, the crack will will open and close as the frame flexes. The ends of the crack rub against each other and the noise resonates through the metal. We just usually ignore those warnings.
But, honestly, there's nothing wrong with aluminum as a frame material. The vast majority of mountain bikes are made of aluminum. I haven't noticed piles of shattered mountain along the trails nor do I see that many aluminum mountain bikes that are broken in my local co-op...and I see a lot of bikes per year. On the other hand, I don't see a lot of broken steel bikes either. I've broken 4 frames...2 of each material...out of 39 bikes I've owned. I consider a broken frame of any material to be more of an aberration than proof that there is something wrong with the material of construction.
Finally, let me ask: If you worry so much about aluminum's failure mode, do you ride steel wheels with steel hubs? Steel cranks? Steel handlebars? If you use aluminum for any of those applications, why aren't you worried about those parts failing?
Stuart Black
Stuart Black
Likes For cyccommute:
#59
Bikes: Optima Baron LR, '14 Nishiki Maricopa,'87 Trek 330 Elance, '89 Miyata 1400, '85 Peugeot PGN10, '04 Fuji Ace, '06 Giant Rincon, '95 Giant Allegre, '83 Trek 620, '86 Schwinn High Sierra
Quoted: 225 Post(s)
Liked 163 Times
Here's a good question. How does aluminum frames hold up against areas close to salt water? I plan to ship a bike to Okinawa, as something to use when I visit my in-laws. I'm assuming for the hot, salty air there, aluminum would be the most preferred material. Am I wrong in thinking this? Steel would rust, and I don't know how well carbon fiber would do in humid heat like what we have there. .
#62
Quoted: 18420 Post(s)
Liked 15,564 Times
#63
Quoted: 4806 Post(s)
Liked 3,931 Times
As I said before - I ride bikes I like until they die. I want them to die gently so I can walk away. I"ve used up too many of my 9 lives already I probably don't have another to spare. (Well, I am getting better at retiring bikies that I know have seen damage.) Of the common bike materials, steel (until you get into the high-strength alloys) is very forginving to minor damge. (I won't own a higher grade than 531 for that reason. If I want to go lighter, I go titanium where you can have far more material. My ti bikes are conservative, not light and very strong. Built by someone with decades in the business who is local so if I have any qualms, I can get ithem checked out any time..
Ben
#64
Quoted: 2483 Post(s)
Liked 2,955 Times
It's not that aluminum frames break more often, it is the failure mode. I've heard a lot more stories of diamonds braking and causing crashes with aluminum than steel. Welds failing. Front ends detaching. In all my steel failures, the bike has remained rideable after tubes severed completely (barring that one metulurgy oops). Yes, they broke quietly. No, I hadn't been checking the frames prior except my racing bike which I knew full well was on its way and was assured that I could ride it to failure, no big deal.
By the way, I've noticed that, as a rule, C&V steel apologists seem to think that steel frames fail despite being steel, whereas aluminum frames fail because they're aluminum.
If anyone has wondered why aluminum took over the market from steel so quickly (despite the understandable initial reluctance of bike companies to invest in such a massive transposition), one clue comes from a chance conversation I had with a Trek sales rep in the early '90s. I asked what the effect of introducing their aluminum frames had had on Trek. The rep immediately said, "Warranty costs are down. We're spending much less money replacing frames under warranty because the failure rate is much lower with our aluminum frames."
#66
Quoted: 663 Post(s)
Liked 496 Times
One problem I see with carbon composite is, so far anyway, it is not recycleable. At the end of it's useful life, so far anyway, it becomes a pile of trash. Even a beer can can be recycleable. Even the ullitmate output of beer is recycled.
#67
Likes For General Geoff:
#68
Bikes: MBK Super Mirage 1991, CAAD10, Yuba Mundo Lux, and a Cannondale Criterium Single Speed
Quoted: 344 Post(s)
Liked 297 Times
I absolutely love my CAAD10. I tried cf bikes and steel bikes while shopping for it, but no other frame had the bang-for-buck that my CAAD had.
I feel no desire to ever buy a road bike again. The next bike I buy will be an offroad machine of some capacity. It will, most likely, be aluminium.
#69
Quoted: 1743 Post(s)
Liked 1,281 Times
I was out today on my CAAD 12 and I love this thing. As much as my Guru Sidero (steel). And, I love my Guru.
#70
As of a few years ago, I had an aluminum hybrid bike that was awful. It was joyless and dull to ride and for about a decade I thought I just hated bicycling. And then I had a series of epiphanies that led to me buying a 1982 Bianchi road bike. It was zippy and just wanted to go fast. In a single summer, I went from not having biked more than a few blocks in years to riding a century. So that was my experience in 2018: aluminum = joyless, steel = joyful. Last year I decided that I wanted a bicycle more suited to the riding I wanted to do. The Bianchi was designed for racing and it was a little too small for me anyway. So I looked and I eventually settled on an aluminum Cannondale Synapse 105, and I LOVE it. Cannondale makes a big deal about it's "SAVE" frame architecture that builds some resilience into the frame. Whatever it is, it does not feel anything like the aluminum hybrid bike I used to own. Perhaps I would have preferred the CF, but the aluminum version was about as much money as I'm willing to spend on a bike. I have kids to put through college. Anyway, yeah. I'm a fan. If properly designed, aluminum bikes are an affordable and even elegant material for bicycle frames.
Likes For Mogens:
#71
Quoted: 1218 Post(s)
Liked 298 Times
I don't know if it's just me or that it's actually become a thing to crap all over aluminum recently, but if these great forums of ours are anything to go by, most everyone seems to be riding aluminum not because they want to, but because they feel like they have to.
Everywhere you look around the forums, people seem to be pining for something other than aluminum: there are the fanatical steel purists who talk down to you because... nostalgia and this whole "nothing rides better" business.
There are the cost-no-object carbon bros who seem to believe that the fact that they could afford, bought, and paid for carbon fiber somehow gives them the right - nay, the obligation - to crap on the "lesser beings" around here as their second favorite pastime.
Then there are the titanium elitists, whose other favorite sport seems to be crapping on other titanium elitists because... only they have the birthright to ride titanium? Or something - whatever.
And the bamboo people? There seems to be too few of them around here to cause any major controversy, aside from the possibly occasional you're-killing-the-planet-and-we're-saving-it mantra.
So, where are the aluminum fans in all of this? Are there any of them actually left? It's been a long time since I've seen anyone (dare to) say that they actually prefer aluminum to any other material, even though they could easily afford to ride carbon, steel or titanium. After having been dubbed "the material of the future" at some point in the history of cycling, how did aluminum fall from grace like this, to the point where it almost became "the material of the dumb?"
I love aluminum, just not the way they are designed now. Leaving the Down tube open ended with a raw edge at the BB... is a huge no for me.
Hydroforming AL, is so awesome, and then.. frame makers go and half ass the frames. I am pretty sure that was 1 engineer, and then it just got copied by many manufactures.
Really is no different than Gerard Vroomen making an Awesome Cervelo, and then some Twiddle dumb butt engineer comes along later and changes the tolerances on the Cervelo Blueprints for the BB, so they don't reject so many frames in manufacturing.... which leads to all kinds of trouble for the end users. (no names here, but that engineer now works for Cannondale, which also Explains why so many BB30 C'Dale frames have issues with the BB **CLUE!!!!!!**)
Anyways Aluminum has potential, but when treated like an entry level material, we the Cyclict, will get entry level engineering.
Likes For Metieval:
#72
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,994 Times
I just did a google search, tons of aluminum fans! Are you looking for a ceiling fan or something on the floor or something different?
I personally like the Dyson fan, very quiet and good airflow. Though I think the actual fan is plastic. Would be cool to do a Lexan or other plexiglass version with a brass inner fan so you could see the workings and because brass fans look cool.
#73
AFAIK this is one of the oldest mass produced specimens of aluminum bikes on the planet. I think it's great. Light & fast. A great ride.
Likes For ramzilla:
#74
I only had this one a couple of days. But, it was a really good riding machine.
Raleigh Revenio 1.0
Raleigh Revenio 1.0
#75
Quoted: 671 Post(s)
Liked 49 Times
I think an aluminum frame plus a (nice) suspension fork & suspension seat-post would make a much better touring bike than currently popular steel:
--Same weight or even lighter
--more comfortable ride even with narrower faster tires
--better handling by obviating the need for frame geometry to absorb bumps
