Are there better rando rack solutions\ for my Voyageur?
Bikes: 87 Marinoni SLX Sports Tourer, 79 Miyata 912 by Gugificazione
Quoted: 502 Post(s)
Liked 466 Times
pcb Thanks for the response! You're right, even if i were able to bend this to get it lower, it would bring it forward a lot more, and that's no good. Much more and it'll be further out than the end of the fender. As for the Nitto M18, would it not be able to attach to the low rider eyelets on the forks instead of using p-clamps?
like here:
like here:
Likes For Dfrost:
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,802 Times
I believe gugie has modified those racks to fit better, but that might have involved sawing and torch work.
As others have said, you can get your rack lower by bending the struts. I've bent both the struts and the older/original non-adjustable through-tang. Not an easy bend, but the tubing feels pretty thick, so I don't think there's much chance you'd compromise strength/durability. In my case I'm mostly using small front rack bags, not large rando bags, so unless I'm hauling gold bars or filling the bag with ball bearings, I can't get much weight in there
Final analysis, though-----custom front rack FTW!
My "zero" bike, which is parked in Berkeley, CA, where it never rains, so they warn you.
Likes For gugie:
You certainly should be able to use lowrider mounts instead of p-clamps, if your fork has them. Didn't realize the Voyager has 'em. As long as the struts are long enough, should work a treat. If they're not, you _might_ be able to get longer replacement struts made for other Nitto racks? Not positive on that, but there might be another adjustable Nitto rack that uses longer struts?
And apologies for overlooking Salamandrine mentioning the VO Constructeur front rack earlier. I ignored his contribution and expended many unnecessary electrons. I am grateful for this opportunity for self criticism.
Such as in this example. Mine appear to sit a little lower than these but if the struts start out long enough before being cut it should work, right?
Fuggedaboutit!
Fuggedaboutit!
Likes For pcb:
Holy Hannah! And I also missed natterberry already posting about longer struts for the Nitto rack. When will it end? I need to shut up and go play with a bike.....
[snip]
If they're not [long enough], you _might_ be able to get longer replacement struts made for other Nitto racks? Not positive on that, but there might be another adjustable Nitto rack that uses longer struts?
Fuggedaboutit!
Fuggedaboutit!
Likes For pcb:
FWIW I also have a Nitto M18 rack, but I haven't used it yet. It could fit just about anything. Longer struts for them and other Nitto racks are available. I think Ben's has them IIRC.
Edit: Also, I doubled up on struts. The M1 has that option over the M18 I believe.
Not lost wanderer.
Quoted: 886 Post(s)
Liked 1,000 Times
Likes For bwilli88:
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,703 Times
What a timely thread...
I think I'm going to be re-evaluating the front rack on my Trek 620.
Commence to jigglin huh?!?!
Likes For The Golden Boy:
Not lost wanderer.
Quoted: 886 Post(s)
Liked 1,000 Times
I forgot this, just give in to the force, full gugificatizion
Likes For bwilli88:
Quoted: 838 Post(s)
Liked 1,082 Times
Update: The M18 has arrived. It's not as pretty as the VO rack but still looks good and is clearly well made. That being said, the struts do not reach the mid fork eyelets. It's close, about a 3/4 an inch off. Frustrating! Looks like I'll be ordering longer ones if they make them.
Quoted: 502 Post(s)
Liked 466 Times
https://www.rivbike.com/products/nit...uts-pair-20077
Quoted: 7351 Post(s)
Liked 2,478 Times
You could level that rack out if you used a longer bolt at the fork crown. Put some spacers between the fork crown and the rack.
When man invented the bicycle he reached the peak of his attainments. Elizabeth West, US author
Likes For noglider:
Quoted: 838 Post(s)
Liked 1,082 Times
The new Nitto struts have arrived and I've got some updates, a question, and a conundrum...
Here is the rack installed, I haven't cut the struts yet.
Does it sit lower than the VO rack did? Yeah, it does. Is it enough to warrant the purchase? Probably not, but aesthetically I'm glad to now have the bag sitting below the flat of the handlebar, as this is a "compact bag" and I wanted it to appear as such.
Is it level? Yep, the struts make it very easy to level it exactly the way you want it. However, as noglider mentioned above, I probably could get the VO rack more level eventually, but it still sits higher than I like.
How do I feel about struts attached to the forks rather than small ones attached to the brakes? I'm not sure yet. Obviously canti post mounting is cleaner and less cumbersome, but I don't currently use low ride panniers and it is nice to get some use out of the fork eyelets, although it is clearly a bit more cluttered, but I also like the somewhat utilitarian look.
Forward positioning: This is as far back as the rack can be pushed with the hardware available. The VO rack sat a little closer to the head tube, which I definitely preferred, especially since the Nitto rack almost passes the fender. That being said, the fender is currently mounted with an L bracket. If I mounted it with a daruma underneath the fork crown, which I prefer anyways, it would push the fender forward a bit and solve this problem
My question: I mounted the struts to the forks using the hardware that is already pre-installed on the forks, and I left the mounts on (I hate the idea of losing these so I don't take them off). Assuming I stick with this installation, would you recommend washers be used at the fork eyelets with this setup?
Ultimately either setup will work. It's a small bag up front that won't be carrying a heavy load. This is mostly a question of aesthetics. Any comments or opinions welcome!
Looks good. You could probably make your own L-bracket for the rack to make it fit better fairly easily.
Quoted: 502 Post(s)
Liked 466 Times
About forward positioning: I used an M18 rack briefly, and drilled another hole in the L-bracket to move the rack closer to the HT. The limit was the front brake. The material used for that L-bracket is good stuff and not easy to drill. But it needs to be relatively stout.
I’d recommend using the mid-fork mounts, since they move less due to fork flex.
Always use a washer at a bolted joint.
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
I've got M18 racks on two bikes, one of which is the rack I bought from @Dfrost as previously mentioned.
You've got a couple of advantages over my setup. First, the cantilever brakes give you more flexibility to lower the rack. Both of mine need to have an L-bracket that clears the front brake. Second, at least currently, you appear to be using a bag that doesn't require a decaleur. The M18 has an absurdly big tombstone, and I find my forward positioning is limited by needing to align the decaleur with the tombstone. You can't see it in the second picture, but it has even less clearance than the first. My bag didn't have a loop to go around the tombstone, so I added a bit of Velcro, which lets me wrap it around the tombstone after the bag is in place. I'm mentioning this, because if you ever switch to a more traditional bag, you might have this problem with the M18.
I think your setup looks good. I'd keep it with the mid-fork mounts. FWIW, the struts are available in a variety of sizes. You might be able to get a set that extend past the rack less if you'd want that.
My Bikes
My Bikes
Quoted: 472 Post(s)
Liked 1,028 Times
What unique possibilities are there?
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
If you want a cleaner non-velcro option to attach the bag to the rack I can certainly suggest the Grand Bois Velo du Reve EB carrier holder.
I've used them on my Batavus Randonneur GL with VO campeur rack.
Bikes: Raleigh Competition GS, Freschi Supreme, Miyata 1000, Trek 520, Marin Pine Mountain, Specialized RockCombo, Soma Smoothie, Surly Cross-Check
Quoted: 99 Post(s)
Liked 267 Times
Thanks for starting this thread polymorphself! It inspired me to revisit my rack setup and I'm much happier after a bit of tweaking. I have the Velo Orange Rando Rack with integrated decaleur and had the same issue of it being too high and close to my handlebars. I removed the rack, gently bent the canti struts, realigned the fork attachment, and presto! Now it sits lower and further out and it's just perfect, hooray!!
