Bicycle MechanicsBroken bottom bracket? Tacoed wheel? If you're having problems with your bicycle, or just need help fixing a flat, drop in here for the latest on bicycle mechanics & bicycle maintenance.
You can take apart the gauge and put a mark on the scale with a felt pen at the pressure you usually use.
I was looking at my Road Morph pump gauge and can't see a way to take it apart without potentially destroying the plastic parts. Could you expand on how you took it apart?
If you look at the bottom of the gauge you should see a plug that a 3mm allen wrench will fit. Unscrew the plug and remove the spring and scale.
