Do Chain Checkers really measure the stated %0.5, %0.75 etc. ?
#101
This is how I took my latest measurement. If someone who has experience with taking consistent measurements can comment on whether this is safe and accurate way to take measurements that would be great.
#102
Quoted: 1062 Post(s)
Liked 665 Times
Looks good to me. The 0.172 figure could vary from chain to chain, but you can always re-measure it each time you check a chain.
The sources of uncertainty in a chain measurement fall into two categories: Some are constant, no matter how many links you include, for example the "slop" of the rollers and typically the precision of the measurement. Some are proportional to the number of links, such as the overall elongation. For this reason, most of the things you don't want to measure become insignificant, the more links you include.
This is why all of the measurements and gages are longer than just one or a pair of links. Six inches makes sense for go-no-go gages and inexpensive calipers that typically come in a 6" length and are a convenient size to throw in a toolbox. Twelve inches makes sense for a ruler. Anything longer gets unwieldy and might require removing the chain.
One thing I always do is double check in the following way. When I think I'm ready to replace a chain, I hang the old and new chains side by side. Over the full length of a chain, the elongation becomes pretty obvious. I keep the published limits (0.5%, 0.75%, whatever) in mind, but I might also swap a chain at the moment when it happens to be convenient, such as getting the winter bikes ready for a snowstorm that's supposed to arrive soon. A benefit of being an amateur is that we can often make decisions based on what's convenient for our schedule, rather than having to get a bike on and off the stand ASAP so another bike can be brought in.
#103
I still think it has nothing to do with the diameter of the rollers (i.e. roller wear). It has to do with the chain pitch.
If you measure a brand new chain, you might notice it having under 0.5" pitch, on average, because the factory grease won't let the inner plates get all the way to the pins - which gets sorted out after a very short ride.
If you have chain skip with an old cassette and new chain at the start of a ride, it should quit by the end of a ride, if it's just the grease that's the problem. If not, keep using the new chain until it quits skipping, if you can stand it.
#104
#105
But roller wear doesn't matter. They aren't a precision to begin with.
#106
Advocatus Diaboli
Quoted: 4737 Post(s)
Liked 1,533 Times
Actually, it's supposedly the wear inside the bushings, not the rollers.
Here's a nice article:
https://www.bikeradar.com/features/h...bicycle-chain/
#107
I didnt say they are. All im saying is rollers wear (mostly) from the inside out and contribute greatly to "apparent" chain elongation, if measured between the rollers.
Weather roller wear matters or not, i dunno, - matters how? I do know however, a chain with worn rollers doesn't ride as nice as a new one. For that reason I tend to replace the chain when the rollers have noticeable wear, no matter if the chain is truly elongated or not. Measuring between the rollers will disclose if the chain is either truly elongated, if the rollers are worn or any combination there of. That said I'm fully aware I might bin the chain somewhat prematurely if the objective is max chain and cassette life, but i just don't care that much. - I'm still on tiagra 10s, its not that expensive.
#108
#109
You are right about outer plate distance and that's why I measured it. I should have stated that 0.172 is for the 11 and 10 speed KMC chains I had, the 8 speed chain has ~0.165 distance between outer plates.
I will try to find a spot to hang almost new and measured %0.5 chains next to each other when I have the time. But there is another problem with looking at the whole chain. The chain unfortunately does not wear uniformly so even if the total wear is less than %0.5 it may be possible to have a section above that point and that begs the question does it matter to have a 5-6" section over %0.5 if the average is below that ?
#110
Campy recommends changing a chain if any of several measured areas exceeds their 132.6mm length suggestion.
It's easy to use a precision 12 inch rule in several places, if the chain is already on a bench, for a full length measurement, but there's no need for that, unless the chain is getting close to being worn out.
0.5% is not a magic number that will cause a disaster if exceeded. Supposedly, sprocket wear begins to accelerate at that point. If you're changing chains prematurely in hopes of avoiding new-chain skip, about the worst that can happen is one less chain gets used before new-chain skip occurs. If that happens, a new cassette can be used for a few hundred miles, then the old one swapped back for the remaining life of the new chain. Some other chain with some use on it can also be used on that worn cassette and it won't skip. That’s why I prefer using a chain rotation. There is no need to keep track of mileage on the chains and managing them is simple. Hang them on a peg and always use the first in line. A freshly cleaned and lubed chain goes to the back of the peg. I drape mine over the peg about in the middle rather than from the end, so it's easy to place a chain at the back of the line.
#111
Campys 132.6 mm recommendation cant* be measured with a precision rule, you need a calliper. Look at post 52 to see for yourself.
Id argue the 132.6 mm rule only apply to campy chains or is simply wrong altogether.
*EDIT
*EDIT
#112
I also noted the new SRAM AXS are showing this type of wear. I'll be checking roller spacing with calipers, side clearance wear with feeler gages and full length elongation on the eight chains I have. When I use a 12 inch rule, it's done as I described earlier - from the edge of a pin to the very end of the rule. The pin at the far end will be completely covered with a new chain. If half of that pin is exposed, its a little over .5% elongation.
#113
132,6 implies there is zero initial slop in the rollers and/or the rollers are bigger that KMC and Shimano. I cant believe any of this is true and in the absence of actual posted dimensions, i remain convinced something is up with that particular recommendation. In any case it does NOT apply to either KMC or Shimano, - You be binning your chains waay prematurely. Might as well simply bin it every 1500 mi, and be done with it.
#114
To use calipers, you have to also be smart enough to first measure a clean new chain, then add at least .5% to that length. That measurement will still be incorrect, because it adds roller wear to actual elongation. To measure only elongation, you should also measure the roller spacing on a new chain and subtract any increase from a worn chain measurement. Then you're measuring only elongation. A 12 inch precision rule is a lot easier to use.
I've explained why Campy suggests their method, but it's really only relevant to their chains. I never claimed it should be used for other brands. A well maintained Campy chain will elongate very little, even after 6,000 miles, but if only one chain is used for that long, it will cause new-chain skip.
#115
Quoted: 980 Post(s)
Liked 584 Times
Chains hanging from nails on a level line
Worn chain on the left
Three chain-check tools. The Shimano tool (right) is supposedly not influenced by roller wear.
Likes For sweeks:
#116
I used to be a machinist too. I know how to use a calliper, and most other measuring tools related to that trade. Measuring a new chain I exactly what I did and thats the reason I know the 132.6 mm figure makes very little sense. Obviously, if a campy chain is completely different from a Shimano or KMC chain it might make sense in that context, but since no one posted the "new chain" dimensions of a campy chain I remain unconvinced its even a reasonable figure for a campy chain. Why dont you measure one and post the numbers?
#117
Dude, lol!
#118
When the 132.6 measurement was first posted, I did the calculations and it doesn't seem off to me. I didn't do any actual measuring, so this is completely theoretical based on what the dimensions should be. They tell you to measure over 6 outer links which means a chain length of 5.5" (139.7mm), and because they are telling you to measure the interior distance between the rollers, you need to subtract half of the roller diameter at each end for a total of 5/16" (7.9375mm). That brings the new chain length to 131.7625mm. As I said, that is all calculated assuming all dimensions are perfect and there is no initial play between parts, but with that calculation you end up with 132.6mm being 0.64% stretch. If you see anything flawed with my calculations I'd love to know what it is.
#119
I appreciate you effort but you need to measure a real chain to account for actual roller diameter and slop in the rollers. Its there even if the chain is brand new and the rollers cant be assumed to adhere to any posted standard. If memory serves me right a new KMC 10s roller more like 7.65 mm. That is a significant difference form any nominal diameter, if the difference between a OK or Worn out chain is only a few 1/10 mms.
#120
If I had a Campy chain to measure roller diameter I would, but without one all I can go by is nominal measurements based on the standard. Obviously any deviations from the nominal dimensions would become very significant when dealing with such precise measurements. And there must initially be some slop in the rollers or they would be completely bound up. But it seems to me that that calculation is likely where they came up with their 132.6mm number.
#121
Since bike chains are based on English units of measure, I prefer to use inch measurements. Campy's 132.6mm dimension converts to 5.220 inches. With the maximum allowed roller diameter of .306, .305 is a common size, but you may find some as small as .303. Take the .500 nominal pitch and subtract one roller diameter to get the nominal space between the rollers. That comes to .195 inch, if there was no clearance between the hole in the roller and the pin. My calipers find this dimension to be .205 inch, so that means that the holes are .010 inch larger than the pin. A new chain should measure about 5.205 inches between the rollers, which makes the 5.220 dimension only .3% longer. .5% would be 5.231 and .6% would be 5.236. My no-go gage made from a 6mm hex wrench measures an increase in the roller spacing of about .5%. By this time, the side clearance on the chain will be a lot greater than a new one. A new chain will usually have .004-.008 inch of clearance between the inner and outer plates. Twice the original clearance indicates a lot of wear.
Personally, I've never paid any attention to the Campy dimension after using Campy chains for 25 years. I did learn that these chains do not elongate very much, whether measured with a precision 12 inch rule or a full length measurement, so checking elongation is usually worthless. I have had others report significant elongation, but you never know how well maintained the chain is or what kind of conditions it was used in. I learned to measure the change in the roller spacing and the side clearance wear to decide when to change a chain, since the elongation measure was always under .25% on my chains.
I'm into a whole new ball game with SRAM AXS chains, but they aren't much different. They follow the #40 chain standard, with 5/16 (.3125) maximum sized rollers on the same .5 inch pitch. I've used them on cassettes and chain rings made for the #41 chains and haven't had a problem yet.
#122
#123
That's what I'll be doing with the axs chain. It only measures a few thousandths of an inch less than a #41 chain, between the rollers. I'll check roller spacing with calipers and elongation full length, since it shows an increase sooner.
#124
Quoted: 2604 Post(s)
Liked 1,933 Times
I would be SO dead if I tried that! But it looks like a fairly easy way to check the chain -- aside from taking it off the bike to measure.
