Red Specialized Sirrus
Old 07-01-09, 09:36 AM
sjpitts
Bikes: 90 Bridgestone MB2/3, 97 Lemond Zurich, 97 Waterford 2200, 95 Mondonico Futura Leggero
Quoted: 5 Post(s)
I picked up a 60cm Red Specialized Sirrus yesterday. I bought it for a friend of mine. He has been looking at newer bikes, mostly aluminum with brifters, but has had a hard time finding a decent one in his size. I paid 70 bucks for it, so even if he decides not to keep he should be able to get his money out of it. With any luck I can convince him that old steel is better than new aluminum.
I am pretty sure this is one of the older, more desirable Sirrus bikes. My guess is an 87 or 88. Anybody know for sure?
My understanding is that the frames have the same geometry as the Allez of that era. But I am not sure of the tubing. Does anybody know what the tubing was for this frame, and how it compares to the Allez of the same time?
I would like to see the specialized catalog with this bike, but I can't find one online. Anyone have an 87 or 88 specialized catalog?
Most of the components are 105's. The rear hub is a 105 six speed, and it appears to be the freehub variety. The front rim is a Saturae (a specialized house brand). The front hub is also a 105, but clearly from a different year, as it has a different finish. The front rim is a wobler.
I think I will ditch the yellow bar tape and just go with black. I also think I will try and find some black hoods. Do you think that would look ok on such a red bike? Does anyone have a set they want to part with?
More pictures are here:
https://s624.photobucket.com/albums/t...ized%20Sirrus/
sjpitts is offline
Old 07-01-09, 10:06 AM
wrk101
Thrifty Bill
wrk101's Avatar
Quoted: 1236 Post(s)
Liked 964 Times in 628 Posts
Just go to the vintage Trek site and look up the component codes for the date. Just pick a component or two that you think is original to the bike. Everything from brake calipers and seat posts to derailleurs and crankarms will have these codes.
wrk101 is offline
Old 07-01-09, 04:31 PM
T-Mar
Quoted: 4722 Post(s)
Liked 3,038 Times in 1,876 Posts
+1. 1987 or 1988, based on the components.
T-Mar is offline
Old 07-01-09, 05:49 PM
rufus
Yep, but not necessarily more desirable. Most likely out of the Giant factory, and it's a nice frame, with good geometry, and handling, but nothing really special or collectable about it. Just a good solid bike.
Not like one of the early Stumpjumpers, or 3Rensho-built Allez.
I'd say '87, cause I think the frame colors in 1988 were blue/white, and a teal color.
rufus is offline
Old 07-01-09, 05:52 PM
mainducoyote
Bikes: 3Rensho Aero with 10 speed Centaure / Record , Lecroco , whatever bike I have for sale at the moment
Black hoods for these levers are still being made. I was quite amazed to find some at my lbs for 4$ !!! The packaging was branded Babac which is a distributor.
mainducoyote is offline
Old 07-01-09, 06:33 PM
Sirrus Rider
Velocommuter Commando
Sirrus Rider's Avatar
Bikes: '88 Specialized Sirrus, '89 Alpine Monitor Pass, two '70 Raligh Twenties, '07 Schwinn Town & Country Trike, '07 Specialized Sirrus Hybrid
Quoted: 23 Post(s)
Liked 36 Times in 11 Posts
It's an '87.. '88 and '89 went to the aqua and white (Red and white alternate depending on year) with very bold graphics.
Sirrus Rider is offline
Old 07-01-09, 08:12 PM
T-Mar
Sole component difference between 1987 & 1988 are the rims. Wolber Alpines were spec for 1987 with Wolber GTX spec'd for 1988. The only geomtery difference listed between years and models are the chainstay length: '87 Sirrus was 40.8cm, '87 Allez was 40.9mm, both '88 models listed as 41cm.
SBI promoted the tubing as their design. They didn't like to disclose the grade and some years even the manufacturer was in question. It was quite common to cut costs by making two models from the fsame rame, so I certainly wouldn't dismiss the possibility of them having identical tubing. However, the only way to be sure would be two have a Sirrus and Allez of the same size and year, strip them to the bare frame and weigh them with a good scale.
Givent the prices and competing models from the era, the tubing should be comparable to Tange 2. Even if we assume that the Allez used something comparable to Tange 1, you're only talking a weight advantage of about 50-70g.
T-Mar is offline
Old 07-01-09, 10:43 PM
Sirrus Rider
Quoted: 23 Post(s)
In '88 they didn't always use Wolber on the Sirrus, they also used their own house brand 'Saturae'. My '88 has Saturae.
This is an '88 the '89 had a unicrown front fork and red replaced the aqua in the color scheme and '89 went 7 speed 105. It was also the first year of the sport Triple.
Old 07-02-09, 12:52 AM
williamshildebr
I had an allez frame that looked just the same, but dark blue with orange grraphics. It had saturae rims and suntour sprint. Tried to ask specialized about it but they said they had no info pre '91.
The mention of such small differences in chainstay length made me wonder how to measure that with horizontal dropouts.
williamshildebr is offline
Old 07-02-09, 04:37 AM
T-Mar
In '88 they didn't always use Wolber on the Sirrus, they also used their own house brand 'Saturae'....
What I've quoted are from the spec sheets, which would be from late in the previous calendar year. Saturae may have been introduced part way through the year. And before anybody asks, no I don't have any pics, just the spec sheets.
When I saw the 1mm difference in chainstay length for '87 and no other geometry differences, I thought it might be a publisher's error. In fact, the 1988 might be the same frame, with the spec just rounded up to the nearest centimeter. There's certainly very little between them.
Chainstay length is measured at point where the centerline of the seatstay intersects with the centerline of the axle slot.
T-Mar is offline
Old 07-02-09, 05:00 AM
Exit.
No lugs? No hugs.
Exit.'s Avatar
Bikes: '85 Miyata 310, '06 GT Performer
That's a hell of a bike for $70.
Exit. is offline
Old 07-02-09, 09:51 AM
sjpitts
Quoted: 5 Post(s)
The Cranks have a date code of KI. According to vintage trek, that makes this a september 86 manufacture. That corresponds to what everyone else is saying-- it is likely an 87.
sjpitts is offline
Old 07-02-09, 09:54 AM
sjpitts
Quoted: 5 Post(s)
As I said before, the front wheel is a wolber -- a GTX. The conflicts with this being an 87. Not sure what to think about that.
The rear wheel is a Saturae.
Both have 105 hubs, but they are clearly from different years. The front has a light, almost white finish.
My guess is that the rear has been replaced. After all, it has a freehub 105 hub. Those did not come out until after 87 right?
Jared
sjpitts is offline
Old 07-02-09, 02:52 PM
Coreyk
Birotate Charioteer
Coreyk's Avatar
Bikes: 1978 Raleigh Competition GS, 1980 Raleigh DL-1, 2012 Bianchi Volpe, 1995-8 Caloi "Semi-Otto" homage thingy
Quoted: 9 Post(s)
Liked 4 Times in 1 Post
I had an identical red 56 cm Sirrus I bought in Late September 1986 that I just sold last month. Shiny 105 components and Wolber Gentleman GTX rims. That was a fast bike, and nimble.
I agree; it's a great buy for $70.
Coreyk is offline
Old 07-04-09, 12:49 AM
williamshildebr
Thanks, that makes perfect sense for measuring. That frame looks so much like my old allez, it would be interesting to do the comparison you suggested earlier.
I think that's a great deal too, and I'd be very careful about changing the fork out, seemed to me like they really dialed in the geometry on those framesets.
Old 02-02-10, 04:55 PM
frpax
Steel is real, baby!
frpax's Avatar
Bikes: 1984 Pinarello, 1986 Bianchi Portofino, 1988 Bianchi Trofeo, 1989 Specialized Allez, 1989 Specialized Hard Rock, 2001 Litespeed Tuscany
Liked 7 Times in 7 Posts
frpax is offline
Old 02-03-10, 08:03 AM
RobbieTunes
Quoted: 378 Post(s)
Liked 1,410 Times in 910 Posts
Compare it side by side with a Tange 2, 1987 frame, or a 1987 Centurion Lemans.
Then think Panasonic.
RobbieTunes is offline
Old 11-08-19, 01:44 PM
mml373
Quoted: 9 Post(s)
Bike is an '87. '87s also came in teal and white.
A new decal/paint scheme - teal and white or red and white - was available in '88.
mml373 is offline
Old 11-08-19, 02:01 PM
merziac
merziac's Avatar
Quoted: 4512 Post(s)
Liked 6,387 Times in 3,672 Posts
Be aware this is a 10 year old zombie thread, no worries, welcome aboard.
merziac is offline
Old 11-08-19, 02:46 PM
mml373
Quoted: 9 Post(s)
Yup, fully cognizant. ;-) Just wanted to correct the record.
These are lovely bikes, for sure.
mml373 is offline
Old 11-08-19, 03:31 PM
merziac
merziac's Avatar
Absolutely, I have 2 86 Merz edition Allez's.
All of these have a ton of the best builders in the business cred, Neenan, Merz, DiNucci, Tesch, Miki, Kono and many others made many of these some of the best production frames built as well as elevating the industry in Japan to a much higher level than before.
I would encourage you to include a Zombie thread alert when you post on one.
merziac is offline
Old 11-08-19, 03:48 PM
mml373
Quoted: 9 Post(s)
Heheh. After riding/racing a 58 (probably was actually a 56) in my youth - bought when we thought I'd continue growing - I finally wound up mostly with bikes the right size for me - 54s.
My bike herd consists of the following: an '87 Sirrus (aqua and white, repainted by Element 6 and refurbed), an '87 Allez SE, an '86 Merz Allez (daily ride), and an '85 Allez SE (have a 2nd frame as well). Unfortunately the '85s are a 56cm frames but still fun to ride and it will be awesome to look all American Flyers, minus the cowboy hat, after I move back to the St. Louis area next year and ride past the Arch on the bike.
The Shimano 600 parts on the '86 Merz Allez are pretty badly worn, wheels in awful condition, so that is the bike that will likely have the stays spread and new Force 22 installed unless I can find an '85 Allez SE frame, 54cm. While I generally prefer to maintain vintage looks, will lose the blue paint and decals and match paint and decals to the '85 SEs...with the Merz signature on the chainstay in black.
Projects... got 'em.
mml373 is offline
Old 11-08-19, 10:41 PM
RiddleOfSteel
Master Parts Rearranger
RiddleOfSteel's Avatar
Quoted: 1556 Post(s)
Liked 2,024 Times in 989 Posts
This thread needs more red vintage Specializeds. '85 Allez SE checking in. Bought as a frame, fork, headset, BB, and crankset. Then put newer Superbe Pro pieces on it (having collected them), a wheel build, plus some below-Superbe-Pro pieces with plenty of polish (and excellent function).
RiddleOfSteel is offline
Likes For RiddleOfSteel:
Old 11-08-19, 11:05 PM
ryansu
ryansu's Avatar
Quoted: 796 Post(s)
Liked 522 Times in 367 Posts
89 Allez checking in...
wheels have changed since I took this shot
ryansu is offline
Likes For ryansu:
Old 11-08-19, 11:24 PM
merziac
merziac's Avatar
And why pray tell would we limit it to Red ones?
merziac is offline
