Question on 5speed Freewheel upgrade
Quoted: 4528 Post(s)
Liked 6,424 Times
Closing up that gap on the dropout is easily done with an 8" crescent wrench. I imagine in Chile you can find a 200mm model. The trick is to use the hole on the end (typically used to hang the wrench off of a hook.) Use the open area of the hole in the wrench to catch the stop on the derailleur hanger.
Red arrow points to the stop:
8"/200mm adjustable wrenches have a "just right" hole at the end. Smaller or larger adjustable wrenches don't have the right hole size to do this.
Just tug on tne wrench carefully, a bit at a time until the two faces are parallel.
One you do that, getting the dropout faces parallel and derailleur hanger aligned properly are next. Sheldon Brown
Quoted: 813 Post(s)
Liked 1,033 Times
My opinion is that you have a good hub @Fkirschfink . You can use Hyperglide gears if you do some filing or grinding. These hubs are great for changing gear ratio. You or a good bike mechanic will have to work on the rear drop out. As far as the derailleur goes, just keep an eye out for something better, You also may need a longer cage to cover your new gear range.
It sure does look like you got some hills there. 13 - 21 would be tough in your neighborhood. You need some bigger gears.
I thought @mpetry912 was mistaken. 5 cross spokes. I looked at the picture and he may be right. If it works keep riding. Nice bike. Welcome to Bike Forums.
