Help me choose a carbon seatpost
just having fun
If you're not using a $400 seat post, what are you even doing with your life?
https://www.mcfk.de/en/111/seatpost-without-offset
https://www.schmolke-carbon.com/prod...rbon-seatpost/
Bikes: Litespeed Solano, Cannondale Super Six Evo, Kona Big Kahuna, Trek Farley 9.6
I might have ordered a $400 seatpost but instead I just found and ordered a Masterpiece setback on sale for about $120 so I now have $280 more to spend on IPA!
The Masterpiece in 350mm length actually weighs less than the Cyrano, but is probably a little stiffer - with the saddles I use it shouldn't matter.
I hear you and understand what you are saying, which is what makes this so frustrating. It is one or both bolts that are actually loosening up, and not the saddle shifting. The bolt was tight to begin with (to 7N-m as recommended) and the saddle was solid on the clamp with no shifting whatsoever. The shifting seems to begin after about 10-15 miles of riding (on paved roads - nothing unusual). The saddles used so far were a Brooks C13 with carbon rails and a Selle Anatomica with carbon rails. It happened with both. The back bolt has a washer that is beveled on one side so that it fits into a slightly countersunk opening on the little cylinder that extends through the back end of the post. There is no lock nut. The torx vs. hex thing is not the issue here but rather that the clamping mechanism will not keep the saddle secure. This will either resolve with loctite or I will sell it to somebody who likes these, put a Thomson back on, and move on. Too bad since it is a brand new post.
So yours is either defective or you're not setting it up correctly. If it's defective, just return it.
J.
Advocatus Diaboli
Quoted: 4750 Post(s)
Liked 1,536 Times
Very odd. I have at least three of the Cyrano 00 seat posts and none of them slips - ever. I'm not a light rider either. I'd have to check, but I thought the spec was 8nm not 7nm (it's marked right on the seatpost) so check. And to confirm, it's a Torx bolt. That's pretty much what Fizik uses everywhere now, at least on the seat posts and stems I have.
J.
J.
Quoted: 241 Post(s)
Liked 232 Times
We just went thru this at work, we had electronic assemblies failing after the Torx screws that held the circuit board in the enclosure would fall out, short the board, and if we were lucky (we usually weren't) burn-out the board. Most of the time we ran the drive thru the endstop and sheared off the grapple. The investigation showed that the screws weren't torqued to the correct values or consistently. Most were torqued to roughly 1/2 to 2/3 the specified torque. We also noticed unusual marks in the Torx head. Worked our way back to the factory in Mexico and found that the tool they were installing the screws with was set to and was delivering the correct torque but they were using hex bit instead of a Torx bit. The Torx bits were considered too expensive and the plant manager wouldn't authorize the purchase of the correct tool. We forced them to get the correct Torx bits and had them build samples. Those samples are still being tested but they have logged 4x the hours that would cause the previous ones to shake the screws loose.
Interestingly, when we mentioned this incident to the bolt supplier's app engineer he just laughed and said they see this frequently. It is common enough that asking if the right tool was used to tighten the fastener is one of the first things they ask when they hear Torx drive screws are falling out. Try tightening with the correct tool and see what happens.
Never too late to learn something so thanks for all the suggestions. I did try a bit of loctite and was able to get a late afternoon 30 miles in without incident today. Tomorrow I will pick up a T25 Torx head that fits my torque wrench. I am also going to look for a couple of small lock washers. I would like to make this work since I can use the masterpiece post on a different bike.
To clarify.. evidently the issue isn't evidently that the saddle is slipping or moving, but more it's about that somehow the bolt is loosening by itself (which I'd guess would lead to the saddle slipping or moving around). I have 8nm engraved on my R1.. but thought I read on some product page that the R00 was 7nM. Not much difference really, and those are probably max values anyway to represent what the bolt can withstand
I've used the fsa k-force on many bikes, probably dating back 15 years. Never a problem. I don't own a tiny torque wrench and never used one to tighten any M5 bolt on a stem or seat post. Never had anything slip or loosen either. I use a screwdriver style T25 on most M5 torx head bolts.
HarborBandS
Quoted: 266 Post(s)
Liked 104 Times
I’ve also had problems with creaks coming from this seatpost, so I appreciate the comment above about disassembling everything and greasing the bolt anchors. I’ll give it a try before my next ride.
All in all, the Fizik Cyrano 00 seatpost has been pretty frustrating after 300 miles or so, but it really is very comfortable! It does seem to have some shock absorption capability. If I can silence the squeaks, I think I will be much happier with the product.
Quoted: 1529 Post(s)
Liked 718 Times
I'm guessing you've never ridden on a light carbon post. Most of the carbon posts I've come across are a fair bit beefier than my FSA post, which rides like I've got a flat tyre.
Advocatus Diaboli
Liked 1,536 Times
Likes For Kimmo:
Dead but dreaming
Location: Bay Area, CA (East Bay - Contra Costa County)
Bikes: 2020 Santa Cruz Stigmata, 2022 Cannondale Synapse
Quoted: 171 Post(s)
Liked 326 Times
I have the Ritchey WCS Carbon 1-Bolt Seatpost and its been great both on and off road.
Super solid, not a sound no matter the effort. Comes in 0 or 25mm offset and 27.2 or 31.6mm diameters.
Thread Killer
Quoted: 3165 Post(s)
Liked 1,723 Times
I’ve had this same problem with the Fizik Cyrano 00 seatpost. The seat rail clamp bolt would come loose after 10 miles or so. I just decided to max torque it at 8 N-m, which scares me a bit with a lightweight carbon part. But so far this has worked.
they’re fantastic seatposts IMO.
HarborBandS
Quoted: 266 Post(s)
Liked 104 Times
that's been my favorite seatpost for years on 4 different bikes now. A little grease on the rails stops squeaks and creaks. I did have one that I had to take apart to grease the bolt anchors. You must torque the bolt to the specified torque setting (as with any seatpost amd why they spec it).
The rails are metal on metal, so you should actually grease those with grease. The post can also creak where it mounts in the frame, and there you should use carbon paste (and re-apply on occasion). Glad you solved the problem. Really is my favorite post for getting it perfectly dialed in.
J.
HarborBandS
Quoted: 266 Post(s)
Liked 104 Times
But the Park Tool SAC-2 anti-friction paste I use is actually made for metal components too. I use it where I’m trying to avoid slippage, and use grease for bolts, bearings, or dissimilar metals.
Advocatus Diaboli
Liked 1,536 Times
+1 I use SAC2 on my R1 post (why did Fizik discontinue this model anyway?) in a Ti Frame, as well as on saddle's rails (whether metal/metal or CF/metal). Grease for bolts. Never use SAC2 on threads.
Anyhow, good to hear the problem with the seatpost has been resolved. That design works well for me - very easy to replicate a bike fit and the carbon post provides noticeable compliance.
Bikes: '23 Poseidon Redwood, '07 Specialized Roubaix Comp Triple, '12 Gravity Fixie, '21 Liv Rove 4, '06? Giant EB Spirit
Quoted: 345 Post(s)
Liked 237 Times
You might try Specialized. I've been quite happy with the one that came on my bike.
I also *highly* recommend Finish Line Fiber Grip. It has been the only thing that has prevented creaks on my seatpost. It also helps prevent moving of the seatpost as the fiber adds friction.
Method to My Madness
Quoted: 1969 Post(s)
Liked 1,489 Times
Likes For SoSmellyAir:
HarborBandS
Quoted: 266 Post(s)
Liked 104 Times
The squeaking comes from friction not from holding it tight. The reason you use the stuff with grit in it for carbon posts is because as carbon moves it produced carbon powder which behaves like a graphite lubricant. Unless you have carbon rails, all you want to do is prevent the metals sticking together which is what produces the creaking. There is little pressure for the rails to slip in the seat clamp.
I put the anti-slip on the rails to deal with the other problem--everything coming loose on rides on bumpy terrain and allowing the seat to come loose. I was trying to keep anything in that assembly from moving. I also put a dab of paste where the clamps contact the top of the carbon post.
Either way, it's hard to argue with my results. Hundreds of miles in now, and both problems have been eliminated. I was a shop mechanic for four years in the 1990's, and there was no Park Tools SAC-2 anti-friction paste at that time. We greased everything, and only dealt with aluminum seatposts and the occasional chromed steel post on a Montgomery Ward three-speed. But I am finding this paste useful in metal-on-metal situations where you don't want slippage and you want to keep your bolt torque low (like a stem to a handlebar). I actually don't like it much in the seatpost/seat tube insertion. It is TOO grippy, and makes it hard to adjust seat post height without scratching the crap out of the post.
I actually think the bolt anchors were causing the creaking. As you know (I'm just pointing this out for others reading this), they are cylindrical, and resting within the carbon body of the post head. The sound of the creaking was kind of a metal on carbon, not a metal on metal sound.
I do grease, and have for years, the seat rails in this and the other seat posts I have (Ritchey). I've never had a problem. I do torque all the bolts down to the spec that is printed by the bolt and I have never had a problem with the seats moving or the seat clamps slipping. You will have this problem if you don't torque them properly, however. I'm a clyde and this has worked for me for probably close to 30-40,000 miles so I'm pretty sure it works.
I have, on occasion, had to adjust a seat post angle on my Ritchey seatpost while out riding. I didn't have a torque wrench with me so I had to carefully tighten it. On that post, if I recall, the torque spec was something like 12nm (i.e. something fairly high). I didn't want to exceed that so I tightened it to where it didn't move anymore but to a point where I was sure it was less than the spec. Anyhow, the seat moved dramatically when I hit a bump (almost dumped me) and I tightened it again somewhat tighter until I got home. When I checked it with my torque wrench, I was at about 2nm below where the spec was. When I tightened it to the full spec, it never moved again. Point being, I guess, the number printed on the post is the torque they are expecting you to tighten to and for what it was designed to be set at for no slipping. Like any good engineer, their designers have allowed considerable margin beyond that just in case. So tighten it to the spec they print on the part and it won't slip. Pretty sure it it holds for a someone like me, it will hold for pretty much anyone.
As you note, it works with the anti-slip compound. I also would not be surprised if it damages the finish on your seat rails at some point. And I'm also sure that the designers of both the clamp and the seat rails designed it to hold without anti-slip paste and most likely would recommend against doing that. Torque it to the spec (that's why it is there) and you'll be fine.
I don't care for the anti slip compounds that have the big chunks in (Finish Line comes to mind). I use the Morgan Blue stuff that has a very fine grit in it and it doesn't seem to do anything to the seatpost. The Morgan Blue stuff has a fine grit in it that you can feel when you rub it between your fingers but it's an order of magnitude finer than the chunkier stuff that's more typical.
Wouldn't you know it - we have this discussion and then I go take my road bike out and the seatpost starts squeaking. It's been installed for 7 years without a noise after I lubed it up when I installed it. Anyhow, was a good exercise to run down the noise. It's coming from the little barrel nuts that each fo the two bolts mate to. I lubed them up with some Finish Line ceramic lube, put it all back together and it was completely silent. It's not the seat rails, it's the nuts in the mount where the metal tube nuts sit in the carbon fiber post.
