Bah! Torx bolts used in bike parts
The only case when the head becomes the limiting factor is when one uses incorrectly sized tools.
With a mighty wind
Quoted: 1088 Post(s)
Liked 862 Times
So I've never stripped an Allen bolt head. I've come across ones that had been wrenched on with the wrong standard and gotten close. Still managed to get them replaced before stripping.
I'm not sure that stripping heads is a reason to change the standard. It's never been a problem and likely never would have become one.
I certainly think torx heads make a bike look both higher end and more burly. Is that it? Appearance? Same thing automakers do with superfluous rivets and diamond tread?
It could be worse, imagine a bike on which every fastener used a different standard: https://en.m.wikipedia.org/wiki/List_of_screw_drives
Half way there
Quoted: 987 Post(s)
Liked 880 Times
But then again, one or two torx keys would not be a big deal. I bought a track hub that had a 15mm axle nut on one side and a 14mm on the other ... that was a bigger deal.
