#9501
Bikes: Giant TCR SL3 and Trek 1.5
Quoted: 12 Post(s)
You'll get more accurate readings with it, however. If you have a sensor, it's used to calculate overall mileage using your wheel size. It will also use a sensor for speed if you have one, which is more accurate than satellite-based information.
#9504
i like having cadence and wanted an integrated HRM. It seems to me that the default speedometer data SHOULD be gathered off the sensor but I'm not sure. I liked the smaller form factor of the 500 over the 510 and I *think* I should be able to use this for running also with an armband. While cool, I knew i wouldn't use the additional features of the 510.
2014 Specialized Roubaix2003 Interloc Impala2007 ParkPre Image C6 (RIP)
#9505
Bikes: Argon18 Gallium 2016, Trek Emonda SL6 Pro 2018, Salsa Beargrease
Quoted: 8 Post(s)
I can confirm that the 500 works for running. Just put it in your pocket and run.
#9506
Tour De French Fries
Bikes: 2010 Cervelo R3 SL & 2013 Airborne Goblin
Ex Coelis
Bikes: have wheels...
Agree, if you have your wheel size entered 100% correctly which I'm sure the vast majority of people don't (including myself).
#9509
Quoted: 8 Post(s)
I had a message on my first ride with my 500 that told me it adjusted wheel size to fit the GPS numbers. So I guess 500 and 800 does it too.
#9510
Ex Coelis
BOT, I purchased two new short sleeve Wool blend jerseys from RoadHolland.
One for me
One for her
#9511
Bikes: 2011 Origin 8 Bully, 2010 Dahon Silvertip, 2016 Respect Mini Velo
Quoted: 20 Post(s)
Shimano Zee Derailleur + Shifter
Sram PG-1070 11-32 Cassette
Sram PC-1051 chain
Wippermann Connex link
Velocity Trap Bottle cage
Cateye CC-RD300W computer
Sram PC-1051 chain
#9512
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Quoted: 1126 Post(s)
Liked 253 Times
I buy stuff all the time, just don't see the point of mentioning mundane stuff. But today I bought my wife a Scott Matrix 40 bike in the female version, a cheap bike but it's what she wanted and all we could find in our area for the best deal. I wanted to buy a different bike off the internet that would have been a better deal but she wanted to test ride it, so we went to all the LBS's in town and decide on that bike. She doesn't ride much but she needed a lighter bike then an old Giant Rincon that weighs 32 pounds and she wanted a womens bike not a mans bike like the Giant was.
#9515
Ex Coelis
They do, the wifes Jersey was half price, they also throw out coupon codes quite often, this order I used a 20% off code.
#9517
Bikes: 1997 Specialized M2Pro
No more pump on my frame, everything fits in the seat pack. Quikstik should speed things up a bit.
#9520
1337
Bikes: CAAD10
Quoted: 12 Post(s)
Right, but what Cale262 is saying is that it's not nearly as accurate as manually setting it. I've found that to be true myself, which is why I always manually enter wheel size in a bike profile.
#9525
Bikes: 2011 Felt Z85 (road/commuter), 2006 Marin Pine Mountain (utility/commuter E-bike), 1995 KHS Alite 1000 (gravel grinder)
Quoted: 676 Post(s)
Liked 13 Times
um... wow. Makes me glad my InStep trailer has a beefy spring for its flex connection.
I make a mark on the garage floor with the tire valve stem at 6 o'clock. Roll the bike forward one wheel revolution and make another mark on the floor. Measure between the two to the nearest 1/32" and convert to mm, then enter into bike computer.
