Disc brakes are now the default on road bikes and no one cares
#301
Quoted: 8287 Post(s)
Liked 9,064 Times
#303
Quoted: 4717 Post(s)
Liked 1,882 Times
For you, discs are overkill. Even I my local area, no one needs them. 30 miles from Phoenix, and it’s not pancake flat.
#304
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,982 Times
Serious question - do they work so well that you don't even think about their being wet? With rim brakes in the rain I just adjust my thinking and technique to accommodate for what I know will be reduced performance - how much less accommodation would I be making with discs?
#305
Jedi Master
There's one hill on Sheridan road but they closed it to bikes in the 80's claiming too many bike crashes. True story.
Likes For kingston:
#306
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
#307
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
#308
Quoted: 3957 Post(s)
Liked 7,310 Times
#310
Jedi Master
Likes For noodle soup:
#312
Quoted: 12 Post(s)
I care. I recently got my first bike with hydraulic brakes, a used one I thought was a bargain, and have had so much hassle and expense getting the brakes working that I am pulling out my hair. For rim brakes all I needed was a 5 or 6 mm hex key and a 10mm spanner. Replace the cable and pads every few years for pocket change. Spit on a tissue to clean the rim and pads if they get oily from the road.
For hydraulics I had to buy the absurdly expensive Shimano oil, tubes, syringes, and then give it multiple transfusions to replace the fluid. Then replace the expensive brake pads. Then spend hours polishing and tweaking the rotors to make them flat. Then get a new expensive lockring to secure the rotor. Then get a lockring tool to attach it it. Align the brakes. All the time being paranoid about getting a drop of oil on the pads and poisoning them.
If you have a team and a sponsor to handle all that, no problem. Or if you are a yuppie and just take it to the shop and pay $100 for servicing whenever, no problem. For some of us, it is something we care about.
I'm sure bike dealers love them, more money up front and steady stream of income to maintain them.
If I was setting up a bike, I might use disk brakes to get the admittedly better wet weather performance. But definitely cables, not oil. Hydraulics are such a pain and expense to maintain. I think now probably why the original owner got rid of it, easier to by a new bike than fix. Everything else I got tuned up in an hour.
#313
Jedi Master
#315
Jedi Master
Likes For kingston:
#316
Liked 7,310 Times
If you're riding a road bike with those brakes and 40mm tires, I think the extra weight of disc brakes would be insignificant.
#317
Jedi Master
#318
Quoted: 18883 Post(s)
Liked 10,646 Times
Fair enough. You can buy a road bike with disc brakes and 30+ mm tires though, pre built and ready to test ride though. Hundreds of different models. I'm just saying the idea that discs can't be better because tires are what's important for traction - that doesn't take into account the fact that in practice discs give you more choices for tire size. I don't think bigger is necessarily better and we should do be riding 10,000 mm tires. And I recognize that not everybody needs discs, but I don't have any control over what Trek sells, so it doesn't matter what I understand.
#319
Liked 7,310 Times
A lot of people drove cars with drum brakes their whole lives without crashing, but that doesn't mean automobile drum brakes are as good as automobile disc brakes.
#320
Jedi Master
#322
Liked 7,310 Times
#323
Liked 7,310 Times
#324
Jedi Master
That would be silly. The reason I don't have disks on that bike is because they are unnecessary and the frame was built for sidepulls.
#325
Jedi Master
I have never crashed that bike so I conclude that drum brakes are good enough and they are infinitely less maintenance than any other kind of brake.
