34/24 crank fine for a touring bike?
Not a newbie to cycling
Bikes: Omnium Cargo Ti with Rohloff, Bullitt Milk Plus, Dahon Smooth Hound
Quoted: 356 Post(s)
Liked 323 Times
You can't stay upright at 3.5 mph? Do you jump on your bike while walking briskly? I can easily do that - even on my Bullitt (the longest bike I own), so I can't fathom how you can't do that on a normal bike.
just another gosling
Quoted: 3895 Post(s)
Liked 1,945 Times
There are gear calculators on-line where you can enter your chainring and sprocket sizes to see what the gear ratio is for each possible gear. From that you can see if there are any redundant gears, etc. I can't suggest any because I use my own spreadsheet for that, perhaps others will see this note and suggest a website with a calculator?
Keep any chainlinks you remove, just in case you want to add them back later.
Nice, easy to use graphical user interface.
Results matter
Results matter
Quoted: 3462 Post(s)
Liked 1,470 Times
When I built up my Rohloff bike, I had to decide what chainring sizes to use, as your chainring choice with an internally geared hub sets the entire gear range.
For around town riding with an unladen bike I knew what I wanted for highest and lowest gears from riding my other bikes on the up and downhills, so it was easy to calculate the chainring that would give me the ideal range of gears for that kind of riding.
But I knew for touring with a heavy load that I would want the lowest practical gear that I could get that was not too low. I did some hill climbing on a different bike and carefully watched my speed while trying to decide what the slowest speed was that I could maintain vertical and directional stability without a lot of oversteer, and that speed was 3.5 mpg. And the slowest cadence that I felt was quite smooth and not jerky was 72 rpm. Then did some calculating and found the chainring size that would give me a lowest gear with a speed of 3.5 mph and cadence of 72 on 57mm wide 26 inch tires, that is 16.2 gear inches. And after several tours I have concluded that in fact is the perfect lowest gear for me.
At times I wished I had a higher highest gear to avoid spinning out on shallow long downhills, but not at the cost of giving up my lowest gear.
The stock sprocket that comes with a Rohloff hub was 16T when I bought the hub. For around town riding with an unladen bike I use a 44T chainring, for heavy loads when touring I use a 36T chainring. And either add or subtract 4 links when I change chainrings.
I am at an age where I should avoid exertion that pushes my heart rate too high. So, if the hill is too steep to keep my heart rate at a good rate while pedaling up a steep hill, I get off the bike and push at a slower speed.
Just in case others that are setting up a Rohloff read this later, I should point out that Rohloff has established minimum chainring to sprocket ratios to avoid over-torquing the parts in the hub, so anyone sizing their chainring(s) like I did should check Rohloff minimum ratios. My ratio of 2.25 for my weight is within their specifications,
Quoted: 356 Post(s)
Liked 323 Times
I have a 39T front sprocket (belt, so "sprocket" is correct), and a 22T rear sprocket on my Rohloff, running on 26" wheels. The actual gear inches change if I use a Kojak 1.35 vs a 1.8 Naches Pass.
I can keep my balance on this long bike almost to a stand still. Sometimes, I can even do a stand with it, despite its long wheelbase. I can't fathom how you guys can't on normal bikes. You can't go, say, 2mph without weaving? Not even up steep hills?
Liked 1,470 Times
https://www.rohloff.de/en/service/handbook/faqs
If you can easily ride at 2 mph, you are probably the only one.
Quoted: 356 Post(s)
Liked 323 Times
Your ratio is 1.77, Rohloff sets a minimum of 1.9 for most cyclists. I hope you do not need any warranty work on your Rohloff. Click on it where it says - Smallest permittable sprocket ratios
I find that very odd, to put it mildly.
EDIT: I just looked, and it is not actually a 22T I have (for some reason I thought it was). I can see from looking up my order that it is actually a 19T on the back. And the one on the front is 46. I have no idea why I thought it was 39/22. So not quite as high strung.
I dunno, but I used a 39/26 with a 12-28 for a tour on the Southern Tier. It worked out fine for me with an ultralight camping load. FWIW, the 39/26 was a triple with the big ring removed. It was on an old 1990 Cannondale crit race bike that I decided to tour on. I had other choices including a dedicated touring bike, but I chose the Cannondale and enjoyed it.
It had a range of about 25-88 gear inches.
Quidam Bike Super Hero
Bikes: 1995 Trek 800 Sport, aka, "CamelTrek"
Quoted: 331 Post(s)
Liked 415 Times
Let me tell you my views and what works for me. I have tripple at the front 42-32-22 and 14-34 at the back. I have 26 inch wheels. My gear inches are both low at low and high end i.e. 16.8 to 78. I mostly ride on 32 and 14 combination in the flatland. I spin a lot and my speed is 20 km/h. I am loaded and have panniers. I find this low speed ok. I find that the aerodynamics is the biggest issue to the bike with bags. I simply can't pedal faster than this on extended tours. I just finished 216 km (135 miles) in a day. I had descents but I never used 42 at the front. And I never use it on the flat while loaded. But that is because my descents aren't huge and I mostly coast on mine due to safety reasons. I know many people will say I'm silly. It all depends on the terrain your riding and your riding style and preference. Perhaps, if I were you, I'd go triple at the front just to have more versatility for long descent where you want to spin if you frequently encounter them. I use my granny gear of 22 when climbing. It's important to have low gear for climbing. I don't understand new touring bikes that have low gear inches above 22 for example. That isn't low enough for a touring machine in mountains. So you have around 21 gear inches at the low (24 teeth/32 teeth (assumed casette) *28 wheel size) so I assume you will be fine for climbing. Also with 34 front and 11 or 12 at the back I would be totally ok but some people would need a bigger ring at the front.
Likes For Digger Goreman:
Liked 1,470 Times
It's fine.
Nah, It's just that I don't find it difficult at all. Maybe because I used to bike trials? But, really, you can't even do 2 mph up a steep hill without weaving on a normal wheelbase bike? Or even 3?
46/19, no warranty problem, that is a 2.42 ratio that is within Rohloff specifications. For touring, my ratio is 2.25 and for riding near home 2.75. Your ratio with 26 inch tires puts you in between the ratios I use.
If you pedal your bike at a cadence of 39 in your lowest gear, that is 2 mph.
Likes For Tourist in MSN:
Quoted: 356 Post(s)
Liked 323 Times
3 mph, not a problem but is not very smooth. 2 mph, no.
Anyway, I really have no idea why I thought the 39/22. I think I have that on my other cargo bike (chainrings), or I may have just calculated it at some point, and it somehow stuck in my head.
I know for a fact that sliding dropouts can be used with a 22T sprocket and in principle a 16T sprocket without swapping the belt too (there's room either way for it to slide in place).
My 26n bike with 44/32/22 and 11-34 works just dandy for touring. Having the 44 and the 11 gives a 104 gear inch top gear which I spin up to a bit over 50kph or 30mph, but of course have descended on this bike up to about 80k or 50mph, but pannier wind resistance generally keeps top speeds to 60, 70k.
The really only downside to my setup is that if unloaded, or lightly loaded, I sometimes have to change between the 32 and 44 more often, but generally with any touring load, it works really really well. A 700 wheeled bike would give you a bit higher gearing, which would be nice lots of times, but to repeat myself, after a number of years using this bike on tours, I am really happy with the setup and its great to have for any short or long steep hills. The 22 ring is fantastic for this and once in a while I think to change the 11-34 to a 12-27 or whatever to have closer shifts, but invariably there are some short steep little bugger of climbs where Im just plain glad to have the 11-34 on all the time.
Quoted: 11 Post(s)
Liked 9 Times
On my gravel bike with 650B X 47mm tires, I run 1X11 shifting with a 34T chainring and a 10X42 cassette. Even unloaded, I only spin out on a fast descent and can pedal on flats up to 22-23 mph.
Not sure why the text size ended up enlarged
To prevent overstraining the hub, a minimum sprocket ratio of 1.9 must be used. With the available sprockets these minumum possible sprocket ratios are:
chainring/sprocket: ~40/21, ~36/19, ~34/18, ~32/17, ~30/16, ~28/15, ~28/14, ~26/13 (ratio 1,9)
belt sprocket: 39/19, 39/20, 42/22, 46/24 (ratio 1,9).
This resembles a derailleur transmission of 20/40. Larger chainrings can be used without exceptions.
I decided the 34/18 would suit my needs bestThanks for the link
Behold my avatar:
Bikes: 2019 Gorilla Monsoon, 2013 Surly Krampus, Brompton folder
Quoted: 6941 Post(s)
Liked 444 Times
I seem to choose exceedingly hilly areas for touring and I neeeed a low low gear, So I wont compromise that.
First, I found that with a little higher gear (39/12) than that on one tour I just spun it up to a real high rpm at the top of the descents and coasted. I found that to be just about as fast as pedaling all the way down at a normal cadence in a higher gear. In any case it wasn't a big deal since it is a tour not a race. I still made a number of 100+ mile days that tour and average decent mileage.
Second, on another tour (800 miles, lots of short climbs, 1 mountain pass) I had a more laid back approach and for no apparent reason just rode in the middle ring (34t) for the whole tour. That was with before I went UL and was with a moderate load. It was just fine. That was with an 11-32 cassette.
Liked 1,470 Times
Quoted: 2236 Post(s)
Liked 1,314 Times
Funny to read this discussion today, as I am currently debating a build decision regarding gears.
A few years ago I began building a serious hill climber out of a rigid mtb that eventually uses a 42/32/22 with an 8 sp 11-40 cassette. The top end doesn't really bother me as it was more of a heavily loaded touring bike and my aim was to go as low as I could go (I have a higher geared light touring rig). Now it has a suspension fork and is used as a geared 26r mtb but is mostly redundant as I have a low geared fatbike for that same purpose. Another converted mtb build has 42/24 with an 11-36 cassette and it turns out that frame fits me just a bit better so I am now turning it into my loaded touring bike, as a winter project.
Decision: whether to swap the triple drive train over, that may require swapping the BB as well (a pita) - or just the rear end, making it an 42/24 by 11-40. How much will I miss that middle ring?
First world problems...
As you say, 1st world but hey, we always like a gearing discussion don't we?
I think the issue of missing the 32 is more about riders, you're clearly a stocky legged Massey Ferguson engined sort of guy. I'm a two stroke engine sort of guy and from experience, I'd both miss the 32 and find the 42 just too tall a lot.
but that's me
but that's me
Behold my avatar:
Liked 444 Times
That isn't necessarily a huge deal though. Two anecdotal experiences...
This might seem crazy to some people, but when I toured Japan on my Brompton I had a 22 - 66 gear-inch range using the Brompton 6spd system. Worked fine for me.
Liked 1,314 Times
but that's me
but that's me
I know I'm going to do it but not looking forward to tearing both bikes apart because I already like the way both perform; but the triple mtb is redundant and I am committed to reducing my fleet (a bit).
Was thinking of renting the Haldron collider for an hour or two and seeing what happens when I send both bikes through... maybe a tandem with really low gearing!
It'll probably work for you, but the 18t jump is a lot. I used 16t jump a lot but it was annoying at times.
guess try it and see.
