Popped a Spoke
Popped a Spoke
Old 03-11-20, 08:40 AM
Drew Eckhardt
Drew Eckhardt's Avatar
Quoted: 550 Post(s)
Liked 325 Times in 226 Posts
Originally Posted by Unca_Sam
Park Tool's IB-3 multi tool includes those on the tire lever/ chain breaker handle. They suck for anything other than sn emergency though.
I bring a 17g black Park SW-0 spoke wrench and 77g CT-5 chain tool. They don't suck, although other riders with Japanese nipples are out of luck.
For a 75 kg rider + bike combination that costs you 4.5 seconds per hour in the mountains which doesn't matter when you're not racing in which case neutral support would make it redundant.
Drew Eckhardt is offline
Old 03-11-20, 08:44 AM
Wilfred Laurier
Señor Member
Wilfred Laurier's Avatar
Quoted: 649 Post(s)
Liked 293 Times in 216 Posts
Originally Posted by rumrunn6
seems to be my specialty. always the rear. & the wheel always go far enough out of true, that I can't ride it home. hoping the last tech, that did the replacement & truing, reviewed all the spokes
As above, bring a spoke wrench or multi-tool with a spoke wrench, and see if you can make it ridable. What have you got to lose?
Wilfred Laurier is offline
Likes For Wilfred Laurier:
Old 03-11-20, 09:12 AM
Unca_Sam
The dropped
Unca_Sam's Avatar
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times in 696 Posts
Oh, I meant the spoke wrenches suck, not the chain tool. It's a handy little thing to have, and I'm generally not counting grams. I happily use the chain tool to size chains in the workshop, but the spoke wrenches are too cumbersome and prone to rounding nipples to replace a dedicated spoke wrench in the workshop.
Unca_Sam is offline
Likes For Unca_Sam:
Old 03-11-20, 01:02 PM
Wilfred Laurier
Señor Member
Quoted: 649 Post(s)
...the spoke wrenches are too cumbersome and prone to rounding nipples to replace a dedicated spoke wrench in the workshop.
This is common to multi-tools IME. I have bought and lost a couple Park spoke wrenches over the years, and learnt my lesson to not rely on the multi-tool ones. The cheap ring-shaped multi-size spoke wrench, though, seems to work fine.
https://www.amazon.ca/Holoras-Bicycl...40302876&psc=1
Old 03-11-20, 01:36 PM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3871 Post(s)
Liked 2,568 Times in 1,579 Posts
If the difference is between getting home and not getting home, crank away on the nearest opposing nipples to pull in the slack! Higher spoke counts help too. I can imagine that a 24 or 28 spoke rear wheel would take more adjustment than the 32 and 36 spoke wheels I ride on. The other tip is to open the brake's QR, but that doesn't help if the wheel is rubbing the frame!
thank you. I've tweaked my kids bikes' wheels, a little, when they weren't perfect. so I've done it, at home, a little, but the cpl times I've "felt" stranded I had bail out options ..
Even better -- you can loosen up the two neighboring spokes a little, and tighten the two outside of those a bit, to spread out the imbalance. That's why it's good practice to build wheels at less than the rim's maximum tension, so you have room to maneuver if need be.
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Likes For ThermionicScott:
