Let's Discuss Frame Geometry
#51
Quoted: 321 Post(s)
Liked 263 Times
However - I believe that the engineers were able to use lighter and slightly thinner tubing to their advantage to make a frame thats obviously still stiff, yet light. Like i mentioned somewhere earlier, I weighed my entire bike in at 21LB. I think that;s pretty darn impressive for a fully equipped XL hardtail. But the ride is stiff. Punishingly stiff. After I mounted my shock absorbing seatpost, I have to admit that the stiffness of the frame feels alot better now.
From the perspective of a bike which can comfortably do everything, I am picturing a relatively slack head tube angle to make up for the wider handlebars (About 71 degrees) and a fairly aggressive fork rake. I think this way, we can comfortably balance handling on both ends of the spectrum from a speed/terrain perspective, so long as the fork rake isn't anything too extreme.I understand that gravel and road bikes are suited to smoother terrain and tend to maintain a higher average speed. Considering that most of them are fitted with dropbars which sort of numb overall response, I guess this is why manufacturers dial up the head tube angle pretty aggressively.on these sort of bikes.
Obviously, the stem shape, and even the way it is forged also plays a rather big role in terms of steering response. I assume that a longer stem would be more ideal for higher speed riding, and probably for climbing hills, since it allows you to lean forward over the handlebars a bit more for better power transfer? I do like the feel of a short stem though. I don't have to lean forward so much and it really helps emphasize on the accuracy of a longer handlebar without making it feel too slow and sluggish.
So if you were able to build your own frames (For road, gravel and singletrack respectively) what would be the distinctive characteristics in design between the three? And what sort of material would you prefer to use? Me personally, I love the ride quality of steel, cromoly, hi tensile etc. Its wonderfully smooth and really seems to make up for the added weight. I know that Titanium is difficult to work on, but I think that is what i'd want to focus on. My understanding is that the Down Tube and Chainstays, particularly at the weld points take the most stress from riding and consequently need to be the strongest area, while the area where the seat tube and top tube intersect is usually a different shape to offer a little bit of compliance for the rider. I'm sure you can make a comfortable aluminum frame though.
I am soon going to be starting on a winter 26" soft-roader go-anywhere build (because I have a 90s Claude Butler MTB with a bent frame that is going to donate its components) so haven't decided what geometry to use. I've already made the fork with fairly conventional rake so it won't be anything too outlandish. Probably similar to the Claude Butler as that rides real nice. The 90s 26" MTB is actually a really nice bike that you don't really get any more. I think most of them did have about 71 degree HA, reasonably long CS, and I will probably go with a bit more BB drop. I don't really know what difference stem length makes. I tend to try to fit the bike to the rider with an average stem so then they can go forward or back if they change their mind about what they like.
Likes For guy153:
#52
Expired Member
Quoted: 3674 Post(s)
Liked 5,437 Times
Here it is
Seriously, look at the posted pic of the stock GT and try a stem/bar configuration that doesn't deviate far from that. It may not be comfortable at first but your body should adapt. You seem happy with the handling now, try it with a correct set up and you'll be over the moon.
#53
Quoted: 321 Post(s)
Liked 263 Times
lmao
So what sort of insane bike frame size/shape would I need which fits me comfortably? This frame measures at 23inches from the top of the seat tube to the center of the bottom bracket. I understand that stack/reach are far more important measurements when determining the fit of a bike, but my point is, hard to come across something which will fit me comfortably without looking into sometihng custom.. I have a 34" inseam, which i'm sure is not the longest in the bike world.
#54
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
Where can I have the honour of viewing the contender for first place?
You should have seen my setup before this. I didn't realize how gargantuan I feel on these bikes. I was using a 30mm stem mounted backwards, on top of my stem riser. It sort of worked OK.. well, better than having it on forwards at least. Except it was totally inept going up any hills. Not enough weight over the handlebars.
Lower the angle on the stem, and rotate the bar bar so the ends sweep back slightly. It looks like you’ got them completely vertical.
Have to admit, it looks all around purposeful. Let me guess, is this Cannondale Volvo your bike? It looks like it can't decide between XC and gravel trail duty, but in a good way. I like how it has some sort of shock absorption below the head tube. How capable do you reckon a good fixed front fork would be on more technical stuff?
The front end is Cannondale’s proprietary Headshok suspension fork, with a single shock inside the head tube. In this example, it’s an 80mm air/oil unit. It was lighter and more precise than other forks like the Manitou/2 and the MAG-21.
A rigid fork would be better than a cheap, flexy suspension fork, but it will be slower, and demand more skill from the rider. Whether it’s better for you would depend greatly on where and how you ride.
#55
Quoted: 18422 Post(s)
Liked 15,570 Times
#57
Le Crocodile
Quoted: 370 Post(s)
Liked 787 Times
Basically the "correct" fit for a XC hardtail. You have a window to work with that is balanced, and it will vary somewhat dependent on geometry. This is my racebike.
Likes For Erzulis Boat:
#58
Liked 15,570 Times
Likes For indyfabz:
#60
Drip, Drip.
Bikes: Trek Verve E bike, Felt Doctrine 4 XC, Opus Horizon Apex 1
Quoted: 1034 Post(s)
Liked 193 Times
Here it is
Based on the extremely tall and close handlebar setup, and that you seem to feel the ride is too violent, even on pavement, without a sprung seat post, I’d say that you’re trying to ride in a very upright position, almost too upright, even. You should be leaning forward slightly, with some of your weight on your hands and feet, as well as the saddle.
No, it’s definitely an XC bike. The Cannondale F-1000 was the basis for multiple XC championship winning team bikes, in the 90s, and that’s what a fast MTB looked like.
i don't see how my stem setup would cause the handling to be rougher tho. With the GT's having an extra weld point at the top tube, it makes the frame extremely stiff, right where you'd ideally want a bit of compliance.
the front fork on that cannondale looks fantastic. I bet it works great. I'd take that over most new XC bikes. Is it yours?
How on earth is that even rideable?
#61
Liked 15,570 Times
How much money did you allegedly waste, including money spent on different wheels (I see different vale stem types), creating your abomination shown farther up from what's pictured immediately above, or are you just trolling?
#63
Liked 15,570 Times
Likes For indyfabz:
#64
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
This should tell you that the bike doesn't fit you. If you have to expose that much seatpost out of the frame and resort to eight inches of spacers, extenders, a hinged stem, and a riser bar just to be comfortable, you're either on the wrong kind of bike or one that is woefully the wrong size. If it works for you, that's great, but you're effectively nullifying whatever "geometry" the bike was designed around, and it's not going to handle in any way, shape, or form like it's supposed to.
#65
Drip, Drip.
Liked 193 Times
I have a 34" inseam. Unless I want to ride a cruiser, I'm not going to feel comfortable on the bike. The 170mm cranks are definetely part of the issue.
Unless your handlebars are at or above the same level as your saddle, then we can safely say, that this entire camp of people is riding a bike which does not fit them, at all, and probably think that the geometry and ride is great . Unless that's just how they like to ride - with evidently too much weight over the front axle.
For somebody with a shorter inseam and not quite as tall, im sure that the geometry of this bike will feel much better.
#66
Drip, Drip.
Liked 193 Times
As for the triple triangle design, I feel like with the seatstays being so closely mounted into the top tube/downtube instead helps give the wheelbase gives this rear biased feel by using a relatively long chainstay without a huge wheelbase.
It also changes the angle of the the seat stays too. Its a unique feeling. And definitely not in a bad way. I highly doubt anyone who dismisses the quality of the aluminum in these rare US- made frames has actually ridden one himself. My friend has a Taiwanese made GT aggressor in a large size which fits him much better, its very stable pushed to its limits i saw him go full speed into a gravel turn; the front tire dug in perfectly, with the rear tire gently breaking loose, scrambling for traction in a perfect drift. But the aluminum used here feels heavier and inferior. The welds aren't as perfect. The two frames are otherwise pretty much the same in terms of geometry.
#68
Liked 15,570 Times
#69
Guest
Liked 3,270 Times
Unless your handlebars are at or above the same level as your saddle, then we can safely say, that this entire camp of people is riding a bike which does not fit them, at all ... Unless that's just how they like to ride - with evidently too much weight over the front axle.
A correctly-sized bike (especially a 29er) would handle like it's supposed to, while affording you enough comfort to ride it. I imagine you'd still use some spacers, a tall stem, and a riser bar, but you'd at least be able to forego the towering stem contraption.
#70
Quoted: 67 Post(s)
Liked 83 Times
You are going to break your face if you try to ride that monstrosity off road. It's not going to matter to anyone here, but there is probably someone who will be sad when you break your face. I can guarantee you are going to hate it, if nothing else. The amount of leverage you are exerting on the front end, plus the multiple failure points should keep you riding sedately on paved rail trails, if at all.
#71
With a mighty wind
Quoted: 1088 Post(s)
Liked 862 Times
My Zaskar LE and my Xziang of the same era were incredible bikes. I should have never sold the Xz, it was so friggin cool.
However, they ride like road bikes. Or flat bar gravel bikes at least. Not particularly good at super technical stuff. Certainly not as well pinned to the ground uphill. Overall, less stable. What those bikes could do was cruise across town on pavement, not much slower than on a road bike.
I'd drop some coin if the right one fell in my lap but not because it's faster.
There is absolutely no physical reason that 42 year old me can ride harder stuff, cleaner, and faster than 20 year old me. It really is the bike.
I've just got a plain old Trek Xcaliber, imagine what an actual nice bike can do.
Likes For rosefarts:
#72
Quoted: 1581 Post(s)
Liked 1,189 Times
Likes For badger1:
#73
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
This is how I bought the bike. Its a pretty good stem, but I didnt like the handling at all. I felt like i was leaning forward way too much and dreaded being on the bike for more than 10 minutes.
I do really like that super upright seating position, but I have to do some really ridiculous stuff with the stem to get it to where i like it. Even with my current setup, I lean forward just slightly, and i feel like it really compromises frknt tire traction when im really thrashing it around turns.
Weight on the front wheel is how you get the traction to make turns. Unless you’re riding in loose sand or deep mud; That’s the physics. That’s how it works.
The “punishingly stiff” ride you experience is because you insist on sitting bolt-upright, you have no way but to put all you weight dead on your ass. That, and you’re probably running your tires pressure too high.
It doesn’t have a thing to do with aluminum or triple triangles; those bikes weren’t designed to be comfortable, they were designed to be fast, which means stiff. I ride a vintage Cannondale, a couple, actually, road and MTB, and that stiffness is what they’re known for.
You’re admittedly new to this, so if you really want to get into MTB, get some more trail miles in, get more comfortable on the bike, and get the book I suggested. Take the advice that’s been offered , and get some practice; you don’t have re-invent the wheel.
Likes For Ironfish653:
#74
Quoted: 7652 Post(s)
Liked 3,479 Times
I am sort of mystified, after reading your glowing review of your Zaskar and then seeing what you claim is the actual bike. That bike in the picture is suitable for sub-10mph parking-lot cruises and not much else. Sitting up that high with all the weight in the back .... you would be on your backside at the first serious hill, and the issue with sitting upright is that you have zero shock absorption.
When walking (which most of us do upright) the legs and hips take up most of the shock. If you are seated, that shock is delivered directly into the spine, which is Not evolved to take shocks vertically. You will beat up your lower back, crush your kidneys, and eventually rupture all your discs.
Leaning forward uses the muscles of the lower back and abdomen to stabilize the upper body, using the hips as a hinge, and if you ride correctly, with some actual pressure on the pedals, this takes a lot of the impact off the spine.
Your set-up is basically a fat-tire version of a 1960s Sting Ray---a bike horribly designed to do anything but sprint up to home-made jumps and cruise in parades.
You and I are about the same size with the same inseam. here is a proper 26" MTB: Sorry for the low-quality pic but it should give you an idea.
Yes, I lean forward, and the weight gives the front end bite---with no weight on the front end the tire will just wash out laterally with any kind of speed ro anything but hardpacked earth or pavement.
It's a 30-pound full-suspension bike with a 1132 mm WB, 483 mm top tube, and 68.5/ 72.5 head- and seat tube angles. Chain stays are 425 mm. The FOX Float RL fork offers 140 mm of travel and still feels tighter, stiffer, and more responsive than the 80 mm I had on my Univega (which was more of a classic NORBA set-up.) I still love the idea of an XC race bike but the skill required to get the most out of one on technical trails ./.... nah. I like what i have.
I am not convinced you are serious about your bike, but if you are .... over time you will go through the same process as most other riders and bike designers. The original Repack bikes (first US MTBs) were old balloon-tire Schwinn cruisers with sprung seats and riser bars. (In fact one of the old Repack riders is a contributor to this site--quite an honor for us, IMO.) Over time, stems go shorter, bars got wider, BBs got higher, front suspension forks were stolen from scooters, then rear shocks, and so onward ....
Eventually, assuming you really want to ride off-road, you will discover that the proper tool for the job is the sort of bike shown in the various photos .... Not yours (sorry.) Of course, you can ride whatever you like, and ride however you like .... and hopefully enjoy it a ton, which to me is the point of the exercise ... but if you really want to get rolling off-road you will need to build some fitness, strengthen your core, drop your handlebars to be within shouting distance of the frame, and use your bke the way it was meant to be used.
You might not have the fitness or technique to do it now, but over time .... it is great to have goals, and great that you are liking the process of getting there .... but believe, you are only an egg.
#75
Drip, Drip.
Liked 193 Times
I think that a lot of people who are only familiar with inexpensive ‘ATB’ style mountain bikes don’t realize that there were high-performance 26” MTBs.
Ill probably buy a comfortable cruiser next season with the upright position, and convert this zaskar back to what its intended to be used for.
In its current circumstances, with the stem contraption and bent fork, I will definetely NOT engage in any serious trail riding at all, for the time being. By the way, any suggestions on what sort of fork I should get for my bike? I'll probably have to look for a 60mm. Or maybe a fixed fork. Do you mind helping?
[TE=Maelochs;21733885]I am sort of mystified, after reading your glowing review of your Zaskar and then seeing what you claim is the actual bike. That bike in the picture is suitable for sub-10mph parking-lot cruises and not much else. Sitting up that high with all the weight in the back .... you would be on your backside at the first serious hill, and the issue with sitting upright is that you have zero shock absorption.
You might not have the fitness or technique to do it now, but over time .... it is great to have goals, and great that you are liking the process of getting there .... but believe, you are only an egg.[/QUOTE]
Other than replacing that fork with the correct size, I assume I'll have to remove that stem riser. Or would straightening out my adjustable stem to like 20 degrees work fine?
Truthfully, I dont ride the trails much. I have it set up right now for sedate pavement riding and occasional fast gravel use. In its current state, i dont feel comfortable doing anything more than light trail riding..
I'm in very good physical shape. I weigh 220lb and my body fat is sub 15 percent. I used to be a personal trainer. I have decent experience with trail riding but obviously still lots of room for improvement in that regard.
