For the love of English 3 speeds...
bentrider
Bikes: Trek R200, Bike Friday NWT, Radius Hornet 2, Cruzbike Sofrider, Vision R-40 BF/ R-42, Actionbent Litespeed/ Jetstream, Bacchetta Giro (20 and 26), Tern Verge P9, Ryan Vanguard, Burley Limbo, Rans Stratus/ Wave/ V-Rex, Dahon Helios, others...
Quoted: 14 Post(s)
I got this one yesterday and already got it running perfectly after replacing a spoke and making adjustments to almost everything. It was really dirty and had lots of grease on it. Sturmey works great as do the the brakes... suprisingly after proper setup.
bentrider
Quoted: 14 Post(s)
Bikes: '68 Raleigh Suberbe, '92 (German) Centurion Equipe, '85 Schwinn Peloton, 1983ish Zunow Road Racer project, '69 Squanch Super Tourer, 1980 Bianchi Super Corsa, '82 Austro-Daimler Vent Noir, '89 Miyata 914 project, 1982ish Bianchi Rallye
Quoted: 294 Post(s)
Liked 9 Times
Very pretty. Looks a lot like my '68 and is similarly without pump pegs. Same guy must have brazed on the pegs for both lines and was on sabbatical.
Totally unrelated: Does anyone know why only some (otherwise identical) bikes have the whiting on the rear mudguard? Country regulation?
Abuse Magnet
Bikes: '91 Mtn Tek Vertical, '74 Raleigh Sports, '72 Raleigh Twenty, '84 Univega Gran Turismo, '09 Surly Karate Monkey, '92 Burley Rock-n-Roll, '86 Miyata 310, '76 Raleigh Shopper
Quoted: 151 Post(s)
Liked 175 Times
@arex - pictures or it didn't happen. I'm glad I could help out. How much more work until it's rideable?
I pretty much have all the bits to start reassembling the bike. I built a new front wheel a few nights ago, but even though it's only a smidge wobbly, I want to take it to the LBS to true and tension it, I don't trust myself to do it right.
I need to rebuild the AW hub, mostly just to regrease the bearings...it seems to work fine otherwise. Then I'll build a new wheel around it; I already have the rim and spokes.
I still need to fabricate a spacer for the headset before I reassemble that end of things.
Quoted: 1299 Post(s)
Liked 103 Times
Old Boy
Quoted: 984 Post(s)
Liked 1,715 Times
Quoted: 294 Post(s)
Liked 9 Times
I just have to repost @DQRiders sweet find he put in the Are You Looking For thread:
1964 AMF/Raleigh Hercules
Not our usual fare here, but I found this on my Sunday morning peruse of CL:
Asking price is $75, and the thing is nearly immaculate.
https://minneapolis.craigslist.org/a...523187393.html[/QUOTE]
Old Boy
Quoted: 984 Post(s)
Liked 1,715 Times
Abuse Magnet
Quoted: 151 Post(s)
Liked 175 Times
What year is it, do you know?
Here is the Robin Hood I fixed up for the Lady:
The "barstool" seat might have to go eventually, but i've tried it myself and it is pretty comfy
Liked 103 Times
These saddles look the part, but they are unusable for me. I put it on for the picture.
I saw this somewhere online and decided to try it. Raleigh Twenty folding bikes have notoriously long brake caliper arms which are flexy upon braking. I used a zip tie between the fork and the brake caliper arm to decrease the flex and it actually seems to work. I'm waiting for it to rain again so I can take it out and get the wheels wet and see how much of a difference it makes. It's not pretty. Heck, maybe I could get some Carradice leather straps and use those instead of zip ties!
Zip Tie on Brake Caliper by velocivixen, on Flickr
Raleigh Twenty Zip Tie Brakes by velocivixen, on Flickr
I have a bad feeling about this, to quote Indiana Jones.
Just cleaned out and lubed the SA hub on my 1979 Tourist. I've disassembled and reassembled the hub three times now because the index rod is not protruding from the axle by the one millimeter prescribed by all hallowed Sheldon Brown without unthreading the rod until barely a single turn of threading is mated to the cross bar in the gear housing.
In addition to this indignity I have to thread the gear cable adjusting sleeve almost all the way off the threaded rod with precious little thread connecting the cable to the chain after adjusting the wheel far enough back to get a reasonable amount of chain tension. Third gear is very touchy now, jumping before it catches and occasionally freewheeling entirely.
I should have noted these relationships when I took it all apart but I failed to do so. Are these extreme ends of adjustment the norm with old Sturmey Archer hubs?
Liked 103 Times
You do have some more adjustment by moving the fulcrum clip on the top tube. You can get the adjuster barrel closer to the chain by moving the clip toward the seat a bit.
Liked 103 Times
Yeah, they were popular. They look nice. Too bad they're such crappy saddles. I knew Raleigh used them on the kids bikes like the Colt and Space Rider, but I never thought they used them on Sports models until I saw this old catalog. Apparently, not all Sports models were DL-22s. There was a cheaper model, S22 that used these very same saddles. Your bike is inspiring me to put white walls on the Scot.
https://www.sheldonbrown.com/retroral...talog-1962.pdf
As BigChief says, screw the adjuster barrel, say, half way up the end of the chain/pin, then loosen and adjust the fulcrum clip rearward to give you more slack on the cable. I hope that makes sense. If not someone can come along and clarify.
Did this hub work prior to your disassembly? The indicator pin screws in finger tight only so as not to strip the tiny threads, then back it off so the chain makes a smooth transition to where you attatch the adjusting barrel.
This fellow does an excellent tear down & reassemble of an AW hub. He has two other videos where shows more detail about the gear ring sub-assembly and the planet cage sub-assembly in great detail. When in doubt I always watch these videos.
https://m.youtube.com/watch?v=ea6krXSs-lc
Liked 103 Times
I'll try to take some pics tonight.
Liked 103 Times
Melting brown eyes? Gimme a break...it's the roadster.
The truth behind Sir Paul McCartney's rise to the top of the charts * | Daily Mail Online
Abuse Magnet
Quoted: 151 Post(s)
Liked 175 Times
I don't know that it's a work-around, so much as accepting the situation and hoping it'll do for the long term. I'll check the cups regularly and tighten as necessary...short of putting in a different bottom bracket, I can't think of anything else to do.
@peppep, you don't need to replace your shift cable, and you're better off not doing it. That damage looks minimal and inconsequential.
And you haven't mentioned why you want to replace your brake cables. Maybe you don't have to do that, either. You can't get cables that are as well-made as the originals, so stick with them if you can.
Liked 103 Times
Can't replace the casing without cutting the cable. Even the plain end brake cable will be chewed up by the pinch bolt. The way I figure it, if the cable has broken strands or is choked up with rust and is still feeling crunchy even after oiling, I replace em. If they still run smoothly, I leave em.
Roger. Ok. Thanks for the hand-holding on this one.
