Uncle Sixty's Gearing Primer for Newbs
Old 02-27-11, 07:10 PM
Sixty Fiver
Bicycle Repair Man !!!
Sixty Fiver's Avatar
Bikes: See my sig...
Quoted: 67 Post(s)
Liked 129 Times in 96 Posts
So, you just built your first fixed gear or single speed and now you are obsessing over the question we have all asked ourselves... "What gear ratio should I use?".
And then, you start a thread asking the question that has been asked a thousand times.
If you want to calculate gear inches go here:
Sheldon Brown's Gear Inch Calculator
Rabbit Calculator
When you get that number calculated it might not mean a thing to you so maybe this will help.
When you buy a stock bike many companies set them up with a gearing in the high 70's which is what most folks would use if they were riding on the track, if your name is Boonen and have knees and legs of steel you might be running something in the mid to high 80's or the very low 90's.
For the rest of us mortals a gearing of 72 seems to be just about right for healthy individuals as this is low enough that you can tackle reasonable hills, ride into the wind, and still dial it up when you need to haul some ass.
If you want to go fast on a fixed gear you will need to learn how to spin efficiently at higher rpms which will make your knees, heart, and lungs very happy.
If you live in hill country or like to tour on your fixed gear a lower gearing can be preferable and I would suggest running a double stepped hub to give you a couple of gears to play with.
If you ride in the winter something in the high 50 to low 60 gear inch range will allow you to slog through some pretty nasty snow and allow you to do seated skids to keep your weight balanced and prevent wipe outs.
My fixed gear road bike runs a 72/80 and the 72 gets the lions share of use while my winter bike ran a 59, and my vintage club bike has a 69/76.
The cheapest way to change gearing is to change your rear cog and running the largest combination of chain ring and cog to get your desired gearing will make your drive more efficient and reduce drive train wear... and a 52:17 (80 gi) looks pretty badass to boot.
Messengers usually don't run monster gearing... when I did this I ran 76 gear inches in the summer and worked in a pretty flat area.
Sixty Fiver is offline
Old 02-27-11, 07:13 PM
I Have a Bike
Makin it Trizzle
I Have a Bike's Avatar
I smell a new sticky
I Have a Bike is offline
Old 02-27-11, 07:22 PM
Scrodzilla
Your cog is slipping.
Scrodzilla's Avatar
Quoted: 640 Post(s)
Liked 100 Times in 58 Posts
Your nose knows.
Scrodzilla is offline
Old 02-27-11, 07:32 PM
Motopecane
Motopecane's Avatar
Bikes: AWOL, Stache 7, Keirin Pro
Thank you for this.
Motopecane is offline
Old 02-27-11, 07:40 PM
xkillemallx16
a large amount of messengers used geared bikes too.
xkillemallx16 is offline
Old 02-27-11, 07:53 PM
Sixty Fiver
Quoted: 67 Post(s)
I could post a gearing primer for that as well but this is ss/fg and in here we know that multiple gears are for people over 45.
Old 02-27-11, 08:10 PM
Squirrelli
GONE~
I'd like to contribute my little calculation formula without using a program...
Basically, charing (44) divided by cog (17) times tire size in inches (23c or 26.275") = 68 gi
All you have to do is remember the number for your tire and you're good to go. Here's a list of popular tire sizes:
23c - 26.275"
25c - 26.375"
28c - 26.775"
32c - 27"
35c - 27.175"
38c - 27.3"
I find this very useful when I don't have internet handy.
Squirrelli is offline
Old 02-27-11, 09:14 PM
Sixty Fiver
Quoted: 67 Post(s)
Squirelli - The manual calculation works really well... actual diameter will vary depending on tyre sizes and some of us run other wheel sizes on or fg bikes... 26 inch mtb tyres and 20 inch wheels will have greater variance than road tyres due to different tread patterns and the 20 inch tyres on my folder are actually 19.5 since they are low profile, high performance tyres.
Old 02-27-11, 09:54 PM
Ken Cox
King of the Hipsters
Bikes: Realm Cycles Custom
I like Bare Knuckle Brigade's Rabbit Applet for studying gear ratios:
https://software.bareknucklebrigade.c...it.applet.html
Ken Cox is offline
Old 02-27-11, 09:57 PM
Lilcphoto
My name is Alex
Lilcphoto's Avatar
Bikes: Mercier Kilo TT Stripper in RAW, Schwinn Madison 2008 Blue, Leader 725tr, Brassknuckle, Leader 722, Traitor Ruben
Google Chrome Browser doesn't seem to like that one... So I use All-City's
Lilcphoto is offline
Old 02-27-11, 10:12 PM
1nput0utput
Unfortunately that one only allows 622 mm BSD wheels and doesn't account for different crank arm lengths. The other ones have a much larger selection of wheel sizes and variable crank arm lengths.
1nput0utput is offline
Old 02-27-11, 11:02 PM
Sixty Fiver
Quoted: 67 Post(s)
This is also a very good application and will add the link to the OP.
Crank length has nothing to do with calculating gear inches and is only a factor if you are calculating gain ratios... for as much as I loved Sheldon his preference for this and prediction that an inch based measurement would fade away, I still prefer gear inches.
Old 02-28-11, 01:21 AM
puppypilgrim
Bikes: Brodie Force w/ Xtracycle, Dahon Helios, Merida Folding, Pacific Carryme, Softride Classic
I prefer Gear Inches too! Currently 72 on my road bike and 66 on my folding bike. SS\FG riders (not hipsters) march to the beat of a different drum I guess.
puppypilgrim is offline
Old 02-28-11, 09:08 AM
markaitch
finally...
a thread that i think is really helpful...glad it got made into a sticky!
anyway, i am never completely happy with the gear ratio (or gear inches) i have on my road bike at any given moment.
yeah, i know that's part of fg/ss riding, but i still have plenty of q's on this subject & hope that you guys will bear with me if i come back here on occasion with some of them.
markaitch is offline
Old 02-28-11, 10:57 AM
Sixty Fiver
Quoted: 67 Post(s)
mark - There are many helpful threads here... the sticky guide is full of them.
Old 02-28-11, 02:03 PM
Decepticondc5
I am ill
Decepticondc5's Avatar
Bikes: 2020 Vilano POS
noob question:
would a persons weight affect what gear ratio they should select?
Decepticondc5 is offline
Old 02-28-11, 02:25 PM
Squirrelli
GONE~
Not necessarily, it depends on the person's ability to use that ratio.
For example:
Chris Hoy, 200lbs, claimed to ride 52/14 ratio in all his races.
Compared to Eddy Merckx during his Hour Record:
He is only about 170lbs or so but he is able to push a 53/11 gear to set the record.
In summation, a riders weight does not necessarily affect the ability of the rider to use the gear to the fullest, quite the contrary, a lot of track riders are pretty massive like:
Kevin Sireau
Theo Bos
Gregory Bauge
But there are skinny road riders that could push a huge gear as well:
Alberto Contador:
Andy Schleck
All in all, weight doesn't matter much, it's the strength of the rider that counts.
Old 02-28-11, 02:44 PM
funkycharms
Choo Choo!
funkycharms's Avatar
Bikes: SE Lager SS/FG
just the thread I was looking for, thanks!
funkycharms is offline
Old 02-28-11, 02:55 PM
Decepticondc5
I am ill
thank you squirrelli
Old 02-28-11, 04:28 PM
famous amos
BTW OP, 52x17 isn't 72gi, its more like 80.
famous amos is offline
Old 02-28-11, 04:41 PM
caloso
caloso's Avatar
Quoted: 2952 Post(s)
Liked 3,106 Times in 1,417 Posts
Very nice.
FWIW, I ran a 52-15 for a flat 10 mile TT last summer. I was 30 seconds faster than the previous year on my geared bike, but that was probably due to the aero helmet and shoe covers.
caloso is offline
Old 02-28-11, 04:43 PM
Sixty Fiver
Quoted: 67 Post(s)
Thanks !
Got my numbers swapped... my 52 with a 17 /19 is a 72/80 gearing.
Used to rock a single gearing of 83 gear inches and that was my daily driver for 5000 miles... dropped that back to 76 after that and just found that I could go even faster.
In the old days, time trialists would run a 76 inch gear to do a sub hour 40 (25 miles) and this was also the gearing road racers used for much of their spring training.
I f'd up my back some years ago and the resulting nerve damage affects my left leg which makes it hard for me to mash as big a gear and usually find myself running that 72 which I can spin like a gerbil on crack.
Old 02-28-11, 08:17 PM
1nput0utput
… spin like a gerbil on crack.
Excellent mental image.
Old 02-28-11, 11:17 PM
NikZak
Bike Hoarder
NikZak's Avatar
Bikes: 80's Graecross Courier Fixie, 2010 Bauer Suburban, 1988 Thruster 300 Volt BMX
i think this thread should be subtitled:
"Now noobs have no excuse to post new threads about gear inches every three days"
NikZak is offline
Old 03-21-11, 03:25 PM
revelstone
Bikes: centurions (lemans and sports dlx both 1981)
exceptions to every rule
now now lets not write anything in stone. i ride a ss/fg, 700 wheels, 44/16 gearing. and i like it more than my 21 speed mountain bike that's spending most of march and the rest of summer and most of it not all of fall in the shed. same as last year. i'll be 55 on my next birthday.
revelstone is offline
Likes For revelstone:
