A 1950s frame waiting for a build.
Quoted: 26 Post(s)
Liked 113 Times
Apologies for the quality of the photographs:
1. From page 19 of the 1953 Campagnolo catalogue: part numbers 611/1 and 600/1 appear to be the braze ons.
2 & 3. Non drive side views
4. Including a bottom bracket interior view showing the mitering and a pin in the bottom of the seat tube (all the tubes in the bb area are pinned as I stupidly found out).
The inside of the headtube has previously had two holes - I guess for a metal headbadge - sadly they are now closed up and flush with the tube - I would love to find an original head badge: https://www.classiclightweights.co.uk...wakefield3.JPG
Thanks,
Tom
Thanks,
Tom
Likes For avecReynolds531:
Quoted: 26 Post(s)
Liked 113 Times
Your point about the lightness of the frame is consistent with my experience: the early 50s frames I own (R.O. Harrison 1951 and JRJ [later Bob Jackson] date not sure, but definitely 50s) are the lightest ones I have in a comparable size. It's those pencil-thin stays, and lug thinning! And scrupulous construction, I think.
One possible reason that the frame doesn't take a 27.2 mm seat post is that the seat tube might be double-butted; in Reynolds 531, the seat post was typically butted only on the bottom end.
This seems consistent with two frames (one from the late 1940s) known to be built with Accles and Pollock Kromo. Does anyone have experience of a Kromo frame and what to expect of the ride characteristics please?
Thanks again for the inspiration and knowledge shared previously.
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
A small update: thanks to Charles Wahl for the above - I was thinking about this & finally got round to weighing the frame. The painted frame is 1875g/ 4.13 pounds, painted fork is 695g/ 1.53 pounds. That's for dimensions of a 22 inch top tube (centre to centre) and 22inch seat tube (centre to top), the seat post size appears to be 27.0mm.
I can't say anything about the ride. I'm just not sensitive to subtleties in how a frame rides. Frame geometry and setup have a much bigger impact on the ride than the frame tubing, at least at my weight. There are plenty of forum members who perceive differences that they atribute to frame tubing, but I definitely do not.
Likes For rhm:
Quoted: 7353 Post(s)
Liked 2,480 Times
2,570 grams for frame and fork sound pretty darned light. Fantastic. And I agree with Rudi: the frame builder had a ride quality in mind and created it using the materials and the design. Or the frame builder stumbled upon a combination that worked without knowing how or why. When we attribute a bike's ride to the materials alone, it is probably more of a placebo effect. We don't know how the builder achieved it, but it's fair to describe what you experience.
Likes For noglider:
