Racer Tech Thread
#4576
**** that
Quoted: 1099 Post(s)
Liked 104 Times
It already has some on it - should I add more?
I guess I'll know if it starts leaking.. but just getting it to hold any air would be a big improvement.
#4577
¯\_(ツ)_/¯
Bikes: aggressive agreement is what I ride.
Quoted: 967 Post(s)
no, I mean at the tube to extender and then at the extender to the valve stem. the presta valve should still work to keep the air inside.
#4578
Bikes: 1979 Raleigh Team 753
Quoted: 3375 Post(s)
Liked 371 Times
It is a good idea to gently hold the valve with pliers so the tube isn't dealing with the torque. It isn't essential, but a good idea.
I have not had leak problems when I properly tightened the valves, so I don't Teflon tape the threads.
Teflon tape is way thinner than electrical tape and can slide through most rim valve step holes and keep the rattle away.
#4580
W**** B*
Bikes: Several
Quoted: 103 Post(s)
Anyone buy a PowerTap GS at $299 via PowerTap's website and get one?
Their website still lists them but everywhere else has them at $500+.
I'd love to buy one via Amazon since I have a boatload of point, but I'm not paying $500+ when it's on the powertap site for $299.
#4581
OMC
Bikes: Specialized Allez Sprint, Look 585, Specialized Allez Comp Race
Quoted: 461 Post(s)
Liked 116 Times
I have three road bikes I ride, two of which have exposed shift cables while the other has internally run cables. The two with exposed shift cables shift cleanly and the cables last quite a while. My Ridley Fenix with enclosed cables shifts okay most of the time...until the cable liners get crud inside them and the cables corrode, requiring replacement every 1-1.5k miles. The issue appears to be the liners, which came with the frameset. Any recommendations for replacement or a workaround? Thanks!
Regards,
Chuck
Demain, on roule!
Regards,
Chuck
Demain, on roule!
#4582
W**** B*
Bikes: Several
Quoted: 103 Post(s)
#4583
commu*ist spy
#4588
Quoted: 1851 Post(s)
Liked 679 Times
I'm putting a new stem on my bike - I am OCD and need stems and bars to match.
The current stem I am running is a +-6. The new stem comes in either a +-10 or +-0. Right now, I have a 20mm spacer under the -6 stem.
So, do I got with a -10, and then maybe add another 10mm of spacers under the stem. Or do I got with a 0 and subtract 10mm of spacer.
I know fewer spacers is better, but a 0 degree stem also looks weird.
#4589
OMC
Quoted: 461 Post(s)
Liked 116 Times
IMO, more spacers look weirder. I'd go with the -0 stem. But then, none of my bars and stems match.
Regards,
Chuck
Demain, on roule!
Regards,
Chuck
Demain, on roule!
#4590
Cat 2
Had that happen in a road race once with the right side garmin Vector2s pedal . Jumped off and threaded it back in as quick as I could, but that was the end of my day...
#4591
Anyone have any experience with the Jagwire link housing? Thinking about getting some and having the LBS install it before spring hits
#4592
However I've been using Nokons for forever, probably 8? years. Great stuff. Able to make sharp curves easily, no flex once you have it dialed in (there's an initial "snuggling in" period where the segments get closer together, you can do this on the stand before riding the bike), super ultra low resistance (1.1 mm gear cable + White Lightning + Nokon's liner = "Crap, I forgot to put the cable in... oh, wait, it's in there."). Never replaced a liner although I've put new liner on when I moved parts from one frame to another.
I got the blue stuff in 2011, also one set of black. Silver and other set of black in 2008. The earlier stuff chipped/corroded, the later stuff is better.
Sprinter della Casa: Equipment - Nokons
"...during the Lance years, being fit became the No. 1 thing. Totally the only thing. It’s a big part of what we do, but fitness is not the only thing. There’s skills, there’s tactics … there’s all kinds of stuff..." Tim Johnson
#4594
I paid $550 for a Cannondale Hollowgram SRM spider with chainrings two summers ago.
Just keep looking on eBay, Paceline, Slowtwitch and Craigslist.
For CL, the trick is to look in other cities. I found my SRM on Craigslist in LA. Exchanged several emails with the guy and chatted with him for about 5 min. on the phone before making the deal. Used PayPal for the purchase to give me protection.
Im not familiar with SRM, what does the PM6 on the back refer to?
#4595
Liked 679 Times
PM6 refers to the version of of SRM. PM7 is the most recent. PM6 is last generation. I believe PM6 was the first wireless one.
And IIRC, Teton told me I was perfectly OK buying a PM6 or PM7.
#4597
Registered User
Quoted: 18 Post(s)
Speaking of SRMs, any good tips on setting up a wired one? Mine will be arriving tomorrow. Already checked the manual so I have a good idea of what to do. Was mostly thinking of how people route the wires and any other little tricks someone might have.
#4598
Tyrannosaurus Rexitis
Bikes: Scott Addict 6870
Quoted: 60 Post(s)
Found crack in seat tube of wife's R3. Mer mer mer.
Gifted her my soloist while we straighten it out so I'm racing on the Emonda ALR. Just threw some aero wheels on but it's got 5800 and round bars which I'm not a fan of.
In other news, 6870 is pretty much equal to 5800 in terms of weight, which is surprising. Once I swap to aero drops I'm likely swapping the di2 over simply because the shift cable situation sucks. So much wind being seen.
#4599
VeloSIRraptor
I use the high-end 3m electrical tape to keep it stuck on the underside of the downtube, and then bring it around and shrink wrap it to brake cables where they come around the head tube.
I put one or two pieces sideways at the bottom and top of the long downtube, given the grit and small movement of the cables, even nice tape loosens.
Make sure you clean the areas really well w/ a solvent/alcohol first, it'll help the tape adhere better.
If you can get an extra set of hands to help, it's ideal to do the downtube run with a continuous strip of tape, but getting it straight, without touching tape-to-tape is quite a bit easier with a bit of help.
it's worked fine on several bikes for me, I'm open to other improvements if anyone else has them?
#4600
Liked 371 Times
Yes. I bought 5. That was several months ago / Aug time frame. They are all in wheels now.
