Chains submerged in Diesel fuel
#51
Tinker-er
Bikes: 1956 Rudge Sports; 1983 Univega Alpina Uno; 1981 Miyata 610; 1973 Raleigh Twenty; 1994 Breezer Lightning XTR; V4 Yuba Mundo aka "The Schlepper"; 1987 Raleigh "The Edge" Mountain Trials; 1952 R.O. Harrison "Madison"
Quoted: 170 Post(s)
Liked 277 Times
Just a few weeks ago i gave away my 1972 Mercedes 220D. This thread has me missing her.
Likes For PhilFo:
#52
Quoted: 4475 Post(s)
Liked 1,617 Times
I don’t think so.
He said he’s in Europe. He didn’t say where in Europe.
Frankfurt? He can probably get anything we can.
Rural Bulgaria? Maybe not. But you can get diesel pretty much anywhere on earth.
And it will work good enough to cut the old lube and flush enough grit out.
The poster from India who said he was a broke college student? Yep. I recommended flushing his freewheel with diesel.
The things many on BF seem to not understand. Not everyone lives in the USA or has access to the products the US has. Not everything is a drop bar road bike.
I saw some ****ed up houses and villages in the Balkans. That was 20+ years ago, so maybe things are better now, but they might not have access to Phil’s, or their wife might get pissed if they steal the crockpot to wax a chain.
But even in a war zone, you can find diesel. And some equivalent of ATF (5606 or 83282).
#53
Mostly harmless ™
Bikes: Heavy, with friction shifters
Quoted: 1107 Post(s)
Liked 217 Times
According to some of the above posts, it looks that Diesel is not corrosive. Point taken, thanks!
Just to avoid misunderstandings: it is not about using large tanks and quantities of Diesel. It is only about shaking and manipulating small quantities of 200-300 grams from one PET to another, once at 1-3 months (Winter included). Around 20-30 grams are lost every time, together with grit extracted from the chain. It is nothing special and it is not dirty at all, given the simplicity of the process and the small quantities involved. I started to use Diesel because it was easily available and the cost of a few hundred grams wasted per year is not material.
Since “mineral spirit” is suggested here as a better alternative than Diesel, then: How do I identify “Mineral spirit” on the EU market (I assume it is marketed under another name) and what would be its cost?
https://www.bikeforums.net/bicycle-m...an-amazon.html
Went with this one (German Amazon link):
https://www.amazon.de/-/en/dp/B07416...roduct_details
It works OK.
But diesel isn't much worse in terms of cleaning and degreasing.
And is a lot easier to find and a lot cheaper.
Relja BalkansGuy Novović
Likes For Bike Gremlin:
#54
Mad bike riding scientist
Quoted: 6238 Post(s)
Liked 4,246 Times
Your “joke” fell flat. Just accept it. And I said no one thing about toxicity. I was addressing its efficacy.
Stuart Black
Stuart Black
#55
Bikes: 2007 Motobecane Fantom Cross Expert, 2020 Motobecane Omni Strada Pro Disc (700c gravel bike), 2021 Motobecane Elite Adventure with Bafang 500W rear hub drive
Quoted: 174 Post(s)
Liked 143 Times
Kerosene
I use a plastic jug with kerosene to clean chains at end of season, because it's handy and works. I thread an old guitar string (thinnest ones) through the end of each chain, drop chain in jug of kerosene, and let strings hang out over lip before screwing on the top. As the OP stated, it's easy to give the jug an occasional shake and after a few days or weeks all the grit is in the bottom of container.
I pull them out, wipe down with old rag, and hang in greenhouse to dry.
in spring, I melt a pot of paraffin wax, dip chains with guitar strings hanging over edge, and after 5-10 minutes pull them out and hang to dry/harden.
I do about six chains for three bikes, and that's enough since I took up golf and only ride a thousand miles or so annually now. Wax is great lube, lasts about 300 miles, and the bonus is the rear end of the bike, including cassette and derailleur, is non-oily and stays remarkably clean. One ten pound block of wax will last my lifetime.
Best system I've come up with. If a chain starts squeaking and I'm not ready for mid-season swap, I just paint some wax dissolved in clean kerosene onto chain on bike, and it's good for another 100 miles or so.
Thank goodness for master links! They make my system easy.
#57
Quoted: 3560 Post(s)
Liked 2,978 Times
#58
Liked 4,246 Times
It’s combustible. Flash point of 120 to 180°F (52 to 82°C). Mineral spirits and kerosene have slightly lower flash points. None of them are what I would classify as “highly flammable”. They will burn but it’s a bit tougher to get them ignited. Kerosene (think of it as #1 diesel) is what is used for all those flames that Hollywood loves so much. It’s also used for fire eating demonstrations.
Stuart Black
Stuart Black
Likes For cyccommute:
#59
Bikes: A Blue One and 2 Green One's, then there's the Yellow one. And oh, yeah, a Black One. Did I mention the Red One?
Quoted: 78 Post(s)
Liked 196 Times
I completely understand bicycle chains, in all of their simple complexity. I understand the variations and levels of bicycles and their uses. And through a lifetime in abuse of the subject, I can even understand OCD in its myriad of complexities. But what I find hard to understand is why someone with a $1k+ bike and the means to afford better things associated with bicycles, fixate on chains.
if a person is worried about chains, buy them a gross at a time and change out the chain every 20 miles or whatever the number is. Even the most expensive chain is relatively cheap in the grand scheme.
diesel fuel?
Sorry to be glib.
Thinking on it a bit more....
Although in 50 years I have never had a chain issue, I'm sure there are reasons for chain worry I don't realize. Sorry if anybody's ears got warm.
diesel fuel?
Sorry to be glib.
#60
Liked 1,617 Times
#62
Liked 4,246 Times
…or a better day job.
Stuart Black
Stuart Black
#63
Liked 1,617 Times
You said no one mentioned toxicity. I mentioned toxicity by saying "worse for your health", which people generally understand to mean that the substance being referenced has some quality that is deleterious to your health. "Toxic" is a word that means "poisonous" or "harmful", and is synonymous with something being "bad for your health".
And then I pointed out that someone that missed that obvious reference to toxic substances may have missed other things in what they were reading, including a facetious suggestion to use a known toxin. This use of facetious or sarcastic language is commonly referred to as a "joke", even if the intended effect wasn't levity and laughter but to make an impression in a way that is more effective than than being entirely direct.
At least, that's the way it works with normal people.
#64
Quoted: 2516 Post(s)
Liked 2,996 Times
cyccommute's offhand remark that kerosene is used by fire-eaters wins this thread.
#65
Liked 4,246 Times
No. Let me explain it to you clearly and explicitly:
Stuart Black
Stuart Black
#68
Quoted: 668 Post(s)
Liked 529 Times
Geez. You guys are gonna wet your panties when you find out I keep a peanut butter jar full of carb cleaner in garage to degrease my chains. I typically smoke a cigar while cleaning them as well.
#70
Quoted: 2613 Post(s)
Liked 1,958 Times
#71
Liked 2,978 Times
The locomotive is a 1941 Vulcan 0-4-0T switch engine. It burns liquid fuel--so anything from diesel to vegetable oil, but usually used crankcase oil. The burner uses a jet of air (and eventually steam, when we have it) to atomize the oil into a fine mist (think lighting hairspray on fire). This mist is ignited by me soaking an old rag or cardboard in diesel (hence my comment), opening the fuel and atomizer valves, igniting the cardboard and throwing it in front of the burner, till the fuel spray ignites.
Likes For smd4:
#72
It works perfectly fine as a degreaser. I would have been horrified if the OP said gasoline as that stuff is carcinogenic.
I would question the need to leaving it soaking in there for that long but if that's where he wants to stash his spare chain have at it
#74
Really, I can't understand why so many people crucify so bad the method with Diesel: it is quite simple, easiest to procure, cheapest and, as I said earlier, a few minutes of smell and a few drops of Diesel on the floor tiles per year are absolutely negligible.
#75
Liked 4,246 Times
It simplifies the process by avoiding one manipulation for storing the chain elsewhere than the PET bottle, it avoids Diesel smell over the whole storing period (the PET is closed with its cap) and the time submerged helps in deeper cleaning without other mechanical actions. Indeed, using paint thinner would do the same, with just a little bit more costs and effort to procure.
Stuart Black
Stuart Black
