Looking For Chain Lube Recommendations
Despite comments to the contrary, chain-L has the LEAST odor of anything I have used. I do not notice anything when I apply it. I do not notice it in a small confined space, like putting the bike in a car or van. I DO notice the smell of tri-flow, clean ride, chainsaw bar oil and most other lubricants that I may or may not use on a chain.
Maybe I better stuff some up my nose to see what you guys are talking about.
-SP
-SP
Quoted: 5793 Post(s)
Liked 2,595 Times
That's scary.
FB
Chain-L site
FB
Chain-L site
Liked 2,595 Times
It was fun for a while, and was OK in the USA, but when I started shipping to Europe where the trademark laws weren't as friendly to parody, I opted to avoid the risk of a suit and dropped the No5.
FB
Chain-L site
FB
Chain-L site
Quoted: 981 Post(s)
Liked 584 Times
Agreed!
It would be great if someone would market a chain lube in a dispenser that could deliver a fixed, small quantity for each "squeeze". Say, 10 microliters per shot would be plenty, and a container would last forever! I've used a number of lubes over the years, most recently ProGold ProLink. I've been fairly happy with its performance, but it's really hard to control during application.
Steve
Steve
Boeshield T-9, especially for dirt/gravel paths. Lubricates well, repels dirt, keeps chain clean, and rust protection.
Liked 2,595 Times
Agreed!
Steve
Steve
The drop size is harder to control because it's inherent to the product itself and depends on viscosity and surface tension. For example, it's nearly impossible to drip a small drop of CHAIN-L, but very easy to squeeze out a very thin steady stream, which can be run down the chain while back pedaling. Other products can also be applied with running a thin stream if you use some touch.
Metering doesn't work that well anyway because everybody has his own preference about how to apply. I for, one would hate to give up my very quick steady stream method to apply drop by drop.
FB
Chain-L site
FB
Chain-L site
Quoted: 981 Post(s)
Liked 584 Times
I think "Corrosion Block" might be a good chain lube, especially in hostile conditions. I've been using this for years on the quick-disconnects of the pedals on my folding bike, and it seems to prevent rust especially in the winter.
I see (just now) they also make a corrosion-blocking grease... I wonder if this is like "marine" grease.
BlockCorrosion.com Homepage
Steve
Steve
I use a wax type lube, like this one WHITE LIGHTNING | Clean Ride White Lightning | Prescott Valley Bike Works Never noticed a smell, and it's MUCH cleaner in general than oil/grease based lubes. One bottle lasts eons!
Dan
Dan
Liked 2,595 Times
It's about balancing various factors to find the best for specific purpose or user.
Factors include conditions, ie, wet, dry, dusty, snow, ice and road salt, ambient temperature range, etc. There's also the working conditions, ie. strong rider and/or steep climbs, vs. light conditions like level ground at 15mph or so, spinner or masher, etc.
Then there's user priorities, best lubrication, lowest parasitic drag, ease of use, service interval, smooth/quiet running, clean, ultra clean/dry, etc.
Many of these are trade offs, ie the product with the best lubrication may require frequent application, or may be dirtier.
So, in the end, every person needs to find what works best for him, which may be very different than what works for someone else. This is why many companies offer a variety of very different products, ie, dry teflon, wax, wet oil.
So, don't think "best" think "best suits my needs and preferences"
FB
Chain-L site
FB
Chain-L site
Optically Corrected
One of my riding buddies says Chain-L smells, to him, like "dinosaur farts".
(Pretty sure that he was just kidding as he now uses nothing but Chain-L as well!)
Mmmmmmm "sulphury"... (now with hints of rosemary!)
Grumpy Old Bugga
Bikes: Hillbrick, Malvern Star Oppy S2, Europa (R.I.P.)
Quoted: 370 Post(s)
Liked 8 Times
Dan
Dan
Grumpy Old Bugga
Quoted: 370 Post(s)
Liked 8 Times
Hmm, this thread's been up for three days and it's only on its second page. This question usually starts wars! Is it losing it's potency? (oh that's right, it has to compete with disc brake and electric shifter threads these days)
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,433 Times
Agreed, I also got pretty skilled at making very small drops to avoid waste, but nowadays I just keep my out-of-rotation chain in a ziploc bag with a couple tsp of Chain-L. Coiled up flat, getting flipped every month or two, the lube penetrates everywhere just fine.
My favorite way of dispensing Chain-L is to pour it into a "Boston Round" LDPE bottle with a conical "Yorker" tip. You can find them at kitchen stores (or Walmart), intended for dispensing oils and condiments. The 2 or 4oz sizes work pretty well. It's easy to control the drop size, and easy to keep the tip clean, though the little red snap cap isn't the most secure and can leak if the bottle falls over. I've seen Chain-L packaged in this style for the little 1/2 oz sample bottles, though I can understand why they don't use it for the larger bottles, given the insecurity of the cap. The normal flip cap bottle isn't too bad, I just find the Yorker tip a little easier.
IMHO you can't really drip oils this thick onto the chain without getting a gigantic drop. You sort of squeeze the bottle until a blob forms at the tip, then touch it to the roller. Much easier to control this way. If I just want a quick touch-up of Chain-L before a long ride, without removing the chain or making a mess I just use a very light touch to leave a tiny dot on the gap between the roller and side plate. When doing a clean and relube with the chain off the bike, I use a bigger blob.
Quoted: 72 Post(s)
Dan
Dan
There essentially are two types of chain lubes: dry and wet, rather Wax based or oil based. Oil based lubes will stick to the chain through sleet, puddles, splashes, mud and snow. However they also attract grime, grit and chain and ring and cog killing filth. Theoretically a wet oil lube lasts much longer than a dry wax lube. However, the chain gets so dirty and is such an attractant to grime and grit (the opposite of a clean well lubes chain) it's effectiveness on the drivetrain becomes deleterious. With an oil based or wet lube you need to constantly clean the chain of the gunk, grit and grime that will wear the chain and eat rings/cogs. However, wax dry lubes don't last nearly as long as wet oil lubes. In fact for very long rides 100k + is about the reapply interval. The chain will stay clean but the wax dry lube just doesn't last in ideal conditions. It's worthless in the wet/rain/snow/muck. The oil wet lube will last long past the point where it's collected so much grit/grime it's starting to eat the drivetrain.
The real question is what conditions do you ride in? Also whether you like reapplying dry wax lube constantly or completely cleaning and relubing your chain almost as often.
I bike in the PNW in less than ideal weather, and have not found this to be the case. Nor have I had to reapply the wax with great frequency.
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1298 Post(s)
Liked 940 Times
I've tried several types of lube; Dumonde, Chain-L, Sachs and Tri-Flow and I think Finish Line Dry is the best. It goes on easy, isn't expensive, doesn't stink and has just the right viscosity for summer riding. Finish Line Wet for winter.
I am used to wiping down and lubing my chain after each long ride. It gives me an opportunity to monitor the chain by feel as well as sight, which is something I consider a critical aspect of maintenance. I might not lube it every time, but I'll wipe it down, at least.
Unless you climb the rungs strategically, you’re not going to build the muscle you need to stay at the top.
Liked 2,595 Times
FB
Chain-L site
FB
Chain-L site
