Thread for Specialized Sirrus
#326
Oh BTW, I am going to keep the OEM rims probably put them back on Sirrus. Going to pick up 2018 Roubaix Expert Di2 when they hit the shop and will move the Mavic over.
I was going to pick up the 2017 but I was a little late, all baby size Roubaix were all sold out
I am 5.2" so I ride 49-51 frame size hehehe.
#327
Bikes: Specialized Sirrus Comp Carbon Disc '14
Quoted: 78 Post(s)
#328
Throwing in my 2017 Specialized Sirrus Expert X1 build/upgrades:
- Specialized Anodized Seat Rail Clamp 7+9mm
- Specialized S-Works Phenom Carbon Fiber Saddle - 143mm
- Specialized S-Works Carbon Fiber Overendz Bar Ends
- Specialized Alloy Bar End Plugs
- Specialized S-Works Rib Cage II Carbo Fiber bottle holder
- Ritchey Superlogic Carbon Fiber C260 Stem 90mm
- Ritchey Superlogic Carbon Fiber Flat +/- 5mm Handlebar 680mm
- Ritchey WCS Carbon Fiber Stem Spacers 10mm x 2
- Ritchey WCS Carbon Fiber Stem Cap
- FSA No. 53 10mm Alloy Headset Top Cover
- SRAM PG-1170 Chain
- SRAM Carbon Crank Boots
- SRAM Force 1 Carbon Fiber Cranks 172.5mm
- SRAM Force 1 Rear Derailleur Long Cage
- Shimano XTR PD-M9000 Clipless Pedals
#329
Bikes: I'm a Flatbar Guy
Quoted: 356 Post(s)
Wow, you went right at it, nice bike and upgrades ! Can't tell from the pic, what size is your cassette ? Is it that big or is that the chain guard that makes it look big ? Just wondering...
#330
Quoted: 356 Post(s)
Wow, thats a monster cassette ! Though, I don't know the type of riding you do, but I think you will like the 11/36. I think that 11/42 is more "geared" towards serious MTB riding. Let us know how you like the new gearing.
#334
I guess for the X1 with 1x11 you would need 42 cog for climbing or you will get lactic acid rush
Unless you like suffering
#335
Bikes: 2017 Surly Troll with XT Drive Train, 2017 Merida Big Nine XT Edition, 2016 Giant Toughroad SLR 2, 1995 Trek 830
Quoted: 1916 Post(s)
Liked 312 Times
Once one gets below 30 on that cassette, the cog sizes will probably be the same, so unless the bike isn't shifting well because of the 42 cog, I'm not sure why 11/36 would be an improvement?
#336
Quoted: 356 Post(s)
My thinking is, if you never use the top or lower gear; like the OP seems to be at, why waist a gear ? I changed my new FX gearing, from a front 50/34 to a rear 11/32 to a 46/36 in front and 12/25 in the rear. Where I ride theres not many hills, but plenty of stop and go, but where I notice a difference with the new gears is riding against the wind. I can just "throttle back" one gear and maintain momentum and keep a good cadence. To me, I ts nice to have a bunch of close gear ratios, if of course you ride on mostly flat roads and trails.
#337
Liked 312 Times
Yes, but a 11/36 won't really give you any close gear ratios than a 11/42.
The first 8 or 9 gears will likely be identical.
#338
Quoted: 356 Post(s)
If you get rid of the 42 gear and change to a 36 low gear wouldn't you pick up more "useable" gear ratios ? if you never use the 36 or even the 30 gear why have it ? I'm assuming that the gear ratios would be closer on a 11/36 cassette than a 11/42 cassette ?
I've had a few beers, maybe better to discuss tomorrow with a (more clear?) clearer (?) mind.
#339
Liked 312 Times
I think you would really be surprised how well a close ratio gearing works. I really think it just depends on what type of riding you do.
The SRAM is 11-36: 11,12,13,15,17,19,22,25,28,32,36
The Sunrace 11-42t: 11-13-15-17-19-21-24-28-32-36-42
#340
Quoted: 38 Post(s)
#341
Quoted: 356 Post(s)
Obviously with the caveat of "it depends where and how you ride" but... close ratio gears was a HUGE improvement for me and I'm now looking to go even closer. went from 11/32 to 12/25 (9spd). I mostly ride in the 10mi - 30mi range and a 20mi loop would probably give me 800ft in elevation change - I don't know if that's considered a "a lot" or "a little" bit of hills but I assume it's not too much as I basically live on an island (cape cod)! I don't know what the gradient is but I've never had to dig deeper than a 34x21 for any reason and I've never got off my bike.
#342
Quoted: 38 Post(s)
That's very interesting to me actually I built a chart to show speeds but don't have it I. Front of me. How fast and how slow do you think you could go (mph) with your gear set in the big ring only (46T).
#343
Quoted: 356 Post(s)
I really have no idea, I'm guessing it really depends on the strength of the rider. I just try to average between 16-17 mph and I find my gearing set up works well, I rarely use the 12 or 25 rear gears. I stay in the 46 on long stretches and the 36 in the city doing a lot of stop and go.
#344
new to the scene
Hi,
I live in Chicago and I'm new to this forum and to the bicycle scene. I just picked up a 2017 Sirrus Sport. I plan on using this bike strictly for exercising/fitness purposes. I got sick of running so wanted to switch it up.
I'm hoping to learn a lot from everyone on here.
#346
Bikes: Specialized Sirrus Sport
Quoted: 83 Post(s)
Hello, everyone. I have a 2010 Sirrus Sport with 14mm interior-width rims. I'm curious if anyone has been able to get 38mm tires (or larger) on their Sirrus? I have 32s currently, but would like something bigger to provide a more comfortable ride. Any suggestions? Thanks.
#347
Just read the whole thread. Seems that no one has anything bad to say about the Sirrus. I tried one at my LBS and liked it, but needed to do more research before biting.
What are people's opinions on how well this bike could stand up to a commute which mostly avoids roads (due to heavy traffic / safety concerns) and instead needs to frequently take some bumps at speed (like a sidewalk crossing a road or a root growing under a paved path) and even perhaps jump a standard curb at speed? There are some nice paved paths along the route, so I'd like to be able to get some decent speed on them while still retaining the ability to call audibles when trying to avoid traffic or whatever that may take me over a few feet of less ideal terrain.
Also, does anyone know if there are any fenders available that fit cleanly on this bike at tire sizes larger than 30? I'm not sure what tire size I'd want, but with a limestone path near me for recreational riding I might need to go bigger than the 30 that the Specialized plug and play fenders can fit. I'm also interested in semi-slick tires for occasional corner cutting on grass between two sidewalks.
#348
<Images unfortunately snipped due to forum post count limitations on newbies.>
My new Sport Disc, picked it up over the weekend, rode it around yesterday and to work this morning, really nice ride. It's got the plug and play fenders and I added a Topeak Explorer rack. I spray painted the explorer's bracket arms black so they'd match the bike and because I hate how the unpainted metal on that rack looks. Also, I'd read on some Amazon reviews that Topeak's non-disc rack would fit on the sirrus disc and they were 100% correct - the non-disc rack went on without any problems.
Note that there seems to be a v2 version of the fenders and that is the one that I saw had 30mm requirement. Maybe yours are v1 or something?
#349
Bikes: 0 (working on that)
Quoted: 14 Post(s)
Posted this in another thread, but it's relevant here...
UPDATE: Finally made it to my LBS. Rode the Specialized Sirrus Comp Carbon and the Giant Fastroad Comax 1. Both excellent bikes indeed. I liked the "fit and feel" of the Specialized best but liked the upgraded components and the narrower tire size (30mm on Specialized, 25mm on the Giant). For what it's worth, while the Giant had a supposedly "softer" frame (carbon composite vs. full carbon on the Specialized), I thought the Giant had a "stiffer" feel to it. Perhaps is was the narrower tires but I'm not really sure. I ended up ordering the Specialized Sirrus Expert Carbon (in red), which is basically the Sirrus Comp Carbon with the component level of the Giant Fastroad Comax 1. I'll probably have the LBS swap out the 30mm tires for 25's or maybe 28's.
Ordered my wife the Sirrus Vita Comp Carbon (in blue).
My LBS made me great on ordering both. Scheduled for fitting and pickup in a week. Very anxious to start putting some miles on these new rides.
Many thanks for all the comments, insight and recommendations - very much appreciated.
RLS
RLS
#350
Noob Rider
The fenders are no more "plug and play" than they are made of unicorn horn but once they're on they do look the part. I had to purchase additional hardware to install them, I'd get your LBS to install them if I were you.
