How hot is too hot for you to ride?
Old 07-21-19, 09:55 PM
  #76
rosefarts
With a mighty wind
Quoted: 1089 Post(s)
Liked 871 Times in 491 Posts
One of my best finishes when I raced was on a 100+ degree day. I remember dry heaving after the end and being unable to keep food down for the rest of the day.
I suffer well. Far from actually fast, I just kinda stay the same regardless of the day.
Living in Colorado, the obvious answer is to get to high elevation. For my local rides with the kid trailer, they're on hold, I simply can't leave early enough. I don't want to cook my passenger.
rosefarts is offline
Old 07-21-19, 11:17 PM
  #77
Metieval
Metieval's Avatar
Quoted: 1218 Post(s)
Liked 298 Times in 214 Posts
Originally Posted by moto367
With the heat wave approaching our area these next few days around here, with temps expecting high 90's with heat index reaching 110-113, when do you decide not to ride due to the temps? I normally don't have too much of an issue with heat but curious about others.
the hotter it gets makes sitting in 220 A/C better than ever.
btw, that is 2 wheels going 20 mph A/C
Metieval is offline
Old 07-21-19, 11:19 PM
  #78
Metieval
Metieval's Avatar
Originally Posted by Arthur P*****y
I live in Albuquerque, have ridden in 100°, weather I couldn't have comfortably walked or run in, but I have to keep moving. Twice I have had bad falls, had to walk, which was torture. I stopped at a fast-food joint with unlimited soda pop and AC, sat down for a few hours, gotten my 99¢ worth. As soon as I get home, I over-heat terribly, take a cold shower as long as I can stand. Time spent fixing a flat is also terrible. I had to take breaks to walk to cool off.
less sugar will go farther than anything to beat the heat. getting your 99¢ of soda pop, is uh OUCH!!!!
Metieval is offline
Old 07-22-19, 03:09 AM
  #79
tim24k
Bikes: To many to list. I like them all!
Quoted: 60 Post(s)
Liked 43 Times in 32 Posts
The hottest commute ride for me was 103. I just took it slow and drank two bottles of water on the way home.
tim24k is offline
Old 07-22-19, 09:30 AM
  #80
CyclingFever
I got a fever.
CyclingFever's Avatar
Quoted: 48 Post(s)
Liked 23 Times in 16 Posts
Survived the weekend! Biked, hiked, and ran. Just pushed as much as the climate allowed.
CyclingFever is offline
Old 07-22-19, 11:28 AM
  #81
Miele Man
Quoted: 1324 Post(s)
Liked 927 Times in 640 Posts
I ride year round - heat, rain or snow. In the heat and humidity I take LOTS of water and Powerade or add Half 'N' Half to a couple of my water bottles. When It's really hot and humid I take 4 bottles of 710 ml capacity. That's not quite 3 8 ounces cups each which would be 750 ml if it was a full 8 ounces per bottle. I just take it a bit easier on the hills and keep my exertion level lower than it'd be on a regular ride on a day with lower heat and humidity. The thing to remember is that you have to drink BEFORE you feel thirsty. Once you're thirsty it takes quite a bit of time to get the fluids you drink to go to where they're needed. Also, you NEED POTASSIUM in order to utilize the sodium and therefore just adding sodium to water won't do a whole lot of good.
Cheers
Miele Man is offline
Likes For Miele Man:
Old 07-22-19, 11:30 AM
  #82
riverdrifter
riverdrifter's Avatar
Bikes: 1985 Cannondale SR500, 1990 Cannondale ST600, 1993 Cannondale M700
Quoted: 171 Post(s)
Liked 278 Times in 108 Posts
Apparently, at 106 F my tubes explode. So that's what I'm going with. Yep, 106 F is too hot to ride.
riverdrifter is offline
Likes For riverdrifter:
Old 07-22-19, 11:33 AM
  #83
rumrunn6
rumrunn6's Avatar
Quoted: 5224 Post(s)
Liked 3,585 Times in 2,344 Posts
there must be a time/temperature & time of day, equation. my apologies if someone already brought that up. after riding:
- 3.5 hrs in 88 degrees w/ advertised "feels like" temps approx. 100 approx 11am-2:30pm, last Labor Day
- 2 hrs in 89-90 degrees approx 3-5pm, last Friday
I would reflect on these rides, as being my limits
also, after a long hot ride one day, I suggest, at least for myself, not to repeat that the next day. it seems I need time to recover, not from just the miles, but from the heat
rumrunn6 is offline
Old 07-22-19, 12:49 PM
  #84
kvanegas
100 and higher
Anyway avoid UV between 11 am and 4 pm
kvanegas is offline
Old 07-22-19, 01:02 PM
  #85
Steeljag
Bikes: Giant TCR Adv Pro I
Quoted: 28 Post(s)
Central Florida here, and I try to out and pedaling by 7am ! It’s already 80 degrees, glasses fog as soon as I leave the AC, and the humidity is thick enough the bike stands up by itself !
When done, everything on me is dripping wet.....sprayed off with the hose....dropped into the washer.....and I head straight for the pool !
Its Florida and what is to be expected !
Steeljag is offline
Old 07-22-19, 01:11 PM
  #86
dedhed
SE Wis
dedhed's Avatar
Quoted: 2747 Post(s)
Liked 3,401 Times in 2,058 Posts
https://www.bikeforums.net/classic-v...ay-saddle.html
dedhed is offline
Old 07-22-19, 01:24 PM
  #87
freeranger
freeranger's Avatar
Quoted: 427 Post(s)
Liked 700 Times in 436 Posts
I'm a senior, but fairly fit, and the heat doesn't decide IF I ride, so much as where I might ride, and what time of day. If the heat index is way up there, I'll ride earlier in the morning, and perhaps on a more shady section of a local MUP. I made the mistake one year of riding on a very hot and humid day in an area which did not have shade, with a group obviously more fit and ready for heat than I. That was a learning experience. I'm not so dedicated as I feel the need to get a ride in, it's more of a fun thing for me, and if it's not fun, I can wait for a better day to ride. Those that are more heat tolerant and determined to get a ride in, my helmet is off to ya.
freeranger is offline
Old 07-22-19, 01:28 PM
  #88
BadGrandma
Bikes: Surly Cross, Franklin tandem, Culprit Jr., BMX racer
Quoted: 35 Post(s)
Liked 45 Times in 28 Posts
Bruce just got back from the RAIN Ride. The road temp was 110. He laid on the rug as soon as he got in the front door and didn't move for an hour. Me, I'm kind of glad I followed the HIIT program and didn't have enough actual miles to partcipate.
BadGrandma is offline
Old 07-22-19, 01:29 PM
  #89
commo_soulja
commo_soulja's Avatar
Bikes: are fun to ride
Quoted: 33 Post(s)
Liked 35 Times in 23 Posts
The temperatures last week and through the weekend were well above 100* with the heat index. I took the week off and drove to work in an air conditioned car listening to the radio. Those temperatures make cycling 17 miles to/from work dangerous at best.
commo_soulja is offline
  #90
dedhed
SE Wis
dedhed's Avatar
Unfortunately commuting doesn't let one choose where or when you can ride.
The morning commute is usually fine but the 4pm - 5:30 ride home can be brutal. I do notice that when I hit the tree lined riverside stretch on the MUP after the city streets the temperature drops about 10 degrees.
dedhed is offline
Old 07-22-19, 01:52 PM
  #91
nomadmax
Quoted: 1104 Post(s)
Liked 1,825 Times in 878 Posts
I think this fixed your link.
nomadmax is offline
Old 07-22-19, 01:58 PM
  #92
masonv45
Bikes: 2005 Giant OCRc2, 2016 GT Aggressor Expert
Quoted: 41 Post(s)
Liked 63 Times in 33 Posts
Riding here in Memphis - Hot and Humid - I found riding with a long sleeve white UA HeatGear shirt actually keeps me cooler than a standard jersey alone. The white reflects the sun's rays and keeps my skin cooler. The HeatGear shirt slowly wicks the moisture away from my skin so it doesn't evaporate too quickly - losing the cooling affect of evaporation. This was something I learned from motorcycling in Memphis heat. Best description of summer motorcycling in Memphis is "riding into a giant blow dryer".
masonv45 is offline
Old 07-22-19, 02:48 PM
  #93
phillman5
Quoted: 37 Post(s)
Liked 3 Times in 3 Posts
Originally Posted by 2manybikes
It only took me about 50 years to get it right.
After 44 years I am still working on it, problem is as I age the needs change. I look forward to 2025 now.
phillman5 is offline
Old 07-22-19, 02:51 PM
  #94
phillman5
Quoted: 37 Post(s)
Not to try to highjack this thread, but many here have referred to their cycle computer for the temp reading. I found mine to be completely inaccurate, reads high when sunlight hits it for a while.
Old 07-22-19, 03:32 PM
  #95
dkatz1
Quoted: 123 Post(s)
Liked 83 Times in 63 Posts
I'm surprised at how little it bothers me....I tend to do less ambitious rides, but I still go....there was an adviosry here this weekend, was in mid 90's and humid (was supposed to get above 100 but it didn't)...and I rode for an hour and a half and felt fine. When I got home, the minute i went into my house, I realized I was (or became) drenched in sweat (it's weird the way the heat seems to hit you AFTER you're done with it). I'm comfortable riding my bike in tempertures that would make me miserable if I were walking.
dkatz1 is offline
Old 07-22-19, 03:38 PM
  #96
dedhed
SE Wis
dedhed's Avatar
Originally Posted by nomadmax
I this fixed your link.
Thanks, Not sure if you guys are ironmen or just nuts.
dedhed is offline
Likes For dedhed:
Old 07-22-19, 06:13 PM
  #97
switchblade 327
switchblade 327's Avatar
Liked 5 Times in 5 Posts
A number of years ago I was riding The Covered Bridge metric century here in Lancaster Pa.near Shirks Bike Shop and I looked at the temp on my computer it read 102. Body temp wasn't too bad,but boy my feet were roasting.
switchblade 327 is offline
Old 07-22-19, 07:13 PM
  #98
sterlingsam
Quoted: 7 Post(s)
It is currently 124 degrees F in Ross CA (southern Marin County).! That is definitely too hot for me, but I will wait until 7 or 7:30pm, when it cools down (I hope below 100 F). I would bike before work, but I get up quite early as is, and it takes an hour plus to go 16 miles to work, with the traffic!
sterlingsam is offline
Old 07-22-19, 07:19 PM
  #99
Miele Man
When you're riding you're generating heat but moving through the air helps to cool you if only a little bit. When you stop riding you immediately lose that cooling effect of the moving air and therefore your body does heat up a bit more. that's why you feel hotter when you stop riding.
Cheers
Old 07-22-19, 07:34 PM
  #100
Bike Jedi
Quoted: 87 Post(s)
Liked 8 Times in 8 Posts
105+ is too hot for very long hours.
Bike Jedi is offline
