Quick questions and answers
Old 07-07-14, 11:46 PM
  #301
JamesCraps
JamesCraps's Avatar
File Type: jpg
JamesCraps is offline
Old 07-08-14, 12:21 AM
  #302
Scrodzilla
Your cog is slipping.
Scrodzilla's Avatar
Quoted: 640 Post(s)
Liked 100 Times in 58 Posts
Same year. Yes.
Scrodzilla is offline
Old 07-30-14, 02:52 AM
  #303
GENESTARWIND
GENESTARWIND's Avatar
Bikes: purty blue undefeated II 57cm
Quoted: 29 Post(s)
Liked 15 Times in 9 Posts
has anyone here had any experience with kenda kriterium endurance tires? if so how did they fair?
GENESTARWIND is offline
Old 08-07-14, 07:19 AM
  #304
jocke
jocke's Avatar
After a years use my stock Continental Tour Ride tires are getting kinda cracked and worn.
Would I feel much of a difference by getting a pair of 28c tires instead of my current 32c?
jocke is offline
Old 08-07-14, 07:25 AM
  #305
hockeyteeth
hockeyteeth's Avatar
I think you would. 28mm is my favorite commuting width. Feels fast but adequately comfortable and keeps your wheelset happy and true. 32s feel a bit sluggish, IMO. I am currently riding 35s on my commuter because they were free and they totally suck. Can't wait to wear them out and switch back to 28s.
hockeyteeth is offline
Old 08-07-14, 07:31 AM
  #306
jocke
jocke's Avatar
I like the sound of that. Thanks for the help and quick response.
jocke is offline
Old 08-07-14, 07:34 AM
  #307
10 Wheels
Galveston County Texas
10 Wheels's Avatar
Bikes: 02 GTO, 2011 Magnum
Quoted: 1350 Post(s)
Liked 1,245 Times in 623 Posts
Go for the 28's....
Fred "The Real Fred"
10 Wheels is offline
Old 08-18-14, 05:13 AM
  #308
GENESTARWIND
Quoted: 29 Post(s)
who here uses internally routed TT brake lever/s with bullhorns?? how did you install?
Old 08-19-14, 01:02 PM
  #309
bmontgomery87
bmontgomery87's Avatar
Bikes: 2013 leader 721. 2015 leader 725. 2012 fuji feather
im tired of running thickslicks on my bike.
are there any other budget friendly tires that are good for skidding and hold up to some abuse?
I don't really want to drop 100 dollars on tires.
I usually run 25c rear and 23 up front.
bmontgomery87 is offline
Old 08-19-14, 01:07 PM
  #310
Scrodzilla
Scrodzilla's Avatar
Quoted: 640 Post(s)
Use a Zaffiro ($16) up front and a Rando ($30) in back.
Old 08-19-14, 01:24 PM
  #311
bmontgomery87
Thanks man.
I started running a zaffiro up front a couple months ago, definitely like the smaller more racy tire in the front versus a heavy ass thickslick.
Old 08-19-14, 02:38 PM
  #312
RevBike
RevBike's Avatar
Bikes: Big Shot Fixed Gear
So I've been riding fixed gear for about a year now (46 x 16) and its alright, except where I live is REALLY flat -- so I could use a little more power. Would 48 x 16 give me much of a difference? Or should I upgrade to some racing cranks and go 50 or 52?
I don't skid stop (I know I know ... wuss) so I'm not worried about that -- but should I go down to a 15 or up to 17 for other reasons?
RevBike is offline
Old 08-20-14, 07:36 AM
  #313
bmontgomery87
It would be a slight difference. If you live in a flat area, I'd say it would be a good choice. Then you can always go down to 48/15 for a bit more.
Old 08-20-14, 08:22 AM
  #314
RevBike
RevBike's Avatar
SO FLAT. Thanks. I'll give it a shot.
RevBike is offline
Old 08-21-14, 01:57 AM
  #315
europa
Grumpy Old Bugga
europa's Avatar
Bikes: Hillbrick, Malvern Star Oppy S2, Europa (R.I.P.)
Quoted: 370 Post(s)
Liked 8 Times in 6 Posts
Gearing is REALLY personal. I live in a very lumpy area, don't mind spinning like a psycho hamster, have thighs like tree stumps and don't mind sitting on a cadence of 110-120 on the flat. So I use 66gi. Thing is, until a couple of years ago, I was happy using 70gi. Maybe I'm just getting old but whatever the reason, that's what I like ... most of the time. All YOU can do, is buy a few cogs and experiment. Do it with rear cogs at first because it's cheaper. Once you work out where you want to be, and are due a new chainring for whatever reason, use a gear calculator to set up your new system with the same gearing, then experiment some more. The chances are, you'll never get it right and will probably sit up in your coffin crying "I reckon if I try a 17 tooth cog".
europa is offline
Old 08-31-14, 07:11 PM
  #316
tomatsu
Does anyone know of a 104 bcd single speed square taper crankset? I have a 110 bcd already and need to run a smaller chainring.
thanks!
tomatsu is offline
Old 08-31-14, 08:54 PM
  #317
Dannihilator
Still kicking.
Dannihilator's Avatar
Bikes: Bike Count: Rising.
Quoted: 159 Post(s)
Liked 46 Times in 32 Posts
What gearing are you looking for?
Appreciate the old bikes more than the new.
Dannihilator is offline
Old 08-31-14, 09:25 PM
  #318
tomatsu
I need to go down to a 32t or 30t. I'm probably going to end up with a mountain triple, run the ring in the middle and take off the other rings.
tomatsu is offline
Old 08-31-14, 09:28 PM
  #319
Dannihilator
Still kicking.
Quoted: 159 Post(s)
You are not going to have much in terms of choice with 104 bcd with a square tapered bb, highest I've found was Alivio
Old 08-31-14, 09:40 PM
  #320
tomatsu
Thanks, that's what I'm seeing too. Civia makes a single 104, otherwise it's the Alivio, Acera, or SRAM S600 that have detachable rings.
tomatsu is offline
Old 09-06-14, 11:50 PM
  #321
Muffin Man
Muffin Man's Avatar
Bikes: Cannondale CAAD12, Specialized Rockhopper, Norco Fluid FS1
Quoted: 127 Post(s)
Liked 3 Times in 2 Posts
How much should I list my leader for?
$700? $600? I'm not sure how much this thing is worth anymore.
Help me out guise.
Pedalroom link
Muffin Man is offline
Old 09-07-14, 01:21 PM
  #322
Leukybear
THE STUFFED
Leukybear's Avatar
Bikes: R. Sachs Road; EAI Bareknuckle; S-Works Enduro
Quoted: 361 Post(s)
Liked 20 Times in 17 Posts
Help me out guise.
Pedalroom link
Not even close to that... as let's face it, the typical person wants an aventon or throne. Shoot "aero" leaders have long been losing ground in the street cred market.
A $700 722 would have phils front and back, omniums, and a wound up.
Leukybear is offline
Old 09-07-14, 01:25 PM
  #323
Muffin Man
Muffin Man's Avatar
Quoted: 127 Post(s)
Sad day. Oh well. Might just keep it and put new bars on it then.
Old 09-07-14, 01:28 PM
  #324
Leukybear
THE STUFFED
Leukybear's Avatar
Quoted: 361 Post(s)
Good plan. If you really want it gone or to recoup, you should part it out to maximize.
It takes a special person to appreciate steel bikes; worse part is they would want italian or lugged then. >.>
Old 09-07-14, 02:37 PM
  #325
Nagrom_
Fixie Infamous
Nagrom_'s Avatar
Bikes: 2007 CAAD Optimo Track, 2012 Cannondale CAAD10, 1996 GT Force restomod, 2015 Cannondale CAADX
Quoted: 54 Post(s)
Liked 4 Times in 4 Posts
Idk man, I got like 1400 for my kilo.
Nagrom_ is offline
