Addiction LXXVIII
#5551
VFL For Life
Bikes: Velo Volmobile
Quoted: 28678 Post(s)
Liked 1,863 Times
#5552
Quoted: 10241 Post(s)
Liked 5,194 Times
#5553
VFL For Life
Liked 1,863 Times
#5555
Custom User Title
Bikes: Fuji Roubaix Pro & Quintana Roo Kilo
Quoted: 2863 Post(s)
Liked 31 Times
I moved and just was never able to get back into it at the new location. I can't just ride for a couple minutes and then be on a near zero traffic country road here. It's all busy suburbs and poorly laid out trail systems. I don't really enjoy the urban cycling experience. I just kind of ended up running more and more.
#5556
Mostly Harmless
Bikes: Have two wheels
Quoted: 13730 Post(s)
Liked 4,541 Times
Likes For RPK79:
#5558
Fat n slow
Quoted: 3259 Post(s)
Liked 2,086 Times
Must just be my crappy luck whenever I fly out of here instead of Logan. I swear every flight I’ve ever been on landing here is always super bumpy compared to other places.
Were you here for longer than a quick stop?
Likes For RPK79:
#5560
Mostly Harmless
Liked 4,541 Times
I'm surprised you have anything more than tundra there, TBH.
Raisin bran is kind of sugary, but so good. #GuiltyPleasures
#5561
Liked 5,194 Times
I had a four hour sit, so we went to the hotel. I fly back to philly now, then come back to albany around 730pm tonight and leave tomorrow.
#5562
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
I have no idea how y'all keep it so low - I'm happy when Garmin reports an overnight RHR of ~55. During the day it hardly dips under 60.
#5563
Should Be More Popular
Quoted: 22638 Post(s)
Liked 8,953 Times
That said, if you notice YOUR usual RHR is increased, that's a sign of overtraining or other issues. So compare to yourself, not others.
#5564
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
#5565
Mostly Harmless
Liked 4,541 Times
Good luck.
#5566
Mostly Harmless
Liked 4,541 Times
#5567
Liked 5,194 Times
#5568
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
Before I bought the GTi I test drove an ‘07 Si and it was a sad sad thing.
#5569
Couldn't find any obstructions in there. I did another run with the upper assembly removed entirely, just to see the volume coming out at the junction - I'm not sure that there's enough volume/pressure there, so I'll look for blockages in that area. Also not sure of the pump arrangement - I would assume one pump running both upper and lower jets, but the pressure on the lower seems fine and steady, whereas the pressure on the upper isn't as high and it's pulsing rather than steady.
Likes For TassR700:
#5570
Quoted: 20810 Post(s)
Liked 9,456 Times
#5572
Fat n slow
Liked 2,086 Times
Audi is blowing out eTrons right now depending on where you look. Buddy of mine just bought one for his wife for their 15th anniversary. MSRP was 85, he got it for 62 before tax credit (another 10k) delivered to his house on a flat bed from Cape Cod. Ultimatey that car will cost him less than a top level Honda Pilot when you factor in gas savings.
#5573
VFL For Life
Liked 1,863 Times
#5574
Liked 9,456 Times
Interesting, thanks. I did check the screen and filter and I was surprised by how clean they were. I also pulled out the flat tube that feeds the upper assembly, as well. No discernible blockage, but when I put it all back together, it wasn't surging any more and the pressure was better. I don't know if it's where it's supposed to be or not, but it is better. The upper still isn't spinning worth a damn, though. The blades don't seem to be well balanced, either - it definitely cants towards one side and I'm wondering if this is enough to make it bind and not spin; there's obviously no bearing of any kind, it's just plastic on plastic and there is some visible wear. If I can't think of anything better to do, I might just order a new upper assembly and see how it goes.
#5575
Liked 9,456 Times
