Need a quiet helmet. Pretty important.
Bikes: Bianchi Ti Megatube; Colnago Competition; Planet-X EC-130E; Klein Pulse; Amp Research B4; Litespeed Catalyst; Trek Y11
Quoted: 605 Post(s)
Liked 480 Times
For many, their hearing is quite important. If this sort of noise is a problem, you can't get an easier, less expensive, more effective or simple solution, than 50 pairs of earplugs for a tenner.
Quoted: 4560 Post(s)
Liked 2,802 Times
Try a helmet cover. There's probably one out there that fits snugly enough to be aero (maybe even improve aerodynamics a bit) yet still allow head heat and vapor to escape. It'll also cut down on turbulence from the vents. With cooler weather approaching it's a good time to experiment.
Wind noise is unavoidable with vented helmets. When I mount my video camera on the helmets the bottom mounted mic picks up mostly wind noise from helmet turbulence. Whenever I tip my head downward the noise quiets and I pick up mostly ambient sound.
If I mount it on the handlebar it's much quieter -- varies depending on proximity to cables and other stuff that produces turbulence.
Heck, I might try the cover trick myself for the winter. Both my helmets kick up a lot of turbulence. I've already lost a lot of high frequency in my left ear, although that's mostly due to age and noise from military training, even with hearing protection. Sometimes I have to turn my head a bit to hear some things clearly.
Fax Transport Specialist
cyclingtips did an interesting article on wind noise while cycling.
Apparently, the db is amazingly loud and with the lengthy duration, hearing loss could become a factor.
they discuss quiet helmet options as well
Quoted: 1067 Post(s)
Liked 259 Times
"Unimportant", until you realize you're deaf - all because you didn't wear earplugs.
Quoted: 605 Post(s)
Liked 480 Times
You may find this article interesting. https://cyclingtips.com/2017/08/list...-hearing-loss/
