Totally Tubular
#2801
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4372 Post(s)
Liked 3,034 Times
#2802
Bikes: Two Peter Mooney customs, a 1980 Trek 510 townie, a Marin Stelvio set up for TTs.
Quoted: 239 Post(s)
Liked 311 Times
Assuming this is the back of a can of Vitt Mastik One. My one tube (I'm standardized on Conti Aluminium, but I wound up with a tube of Vitt M1 in my kit) has the same warning language, but no application instructions. This looks to me like dryish/wettish (rim) to dryish (base tape). The main things are rim prep before base coat and tire prep before base tape coat. On the other hand, I just watched a video stipulating three heavy base coats prior to the mounting coat. All of my recent mounts are basically according to the Vitt can though I tend to leave less time for the base tape coat to dry. The real question is how is the bond compromised as time passes between the initial rim and base tape glues and the application right before mounting?
#2803
Quoted: 1972 Post(s)
Liked 2,086 Times
I performed the Continental video regimen in the beginning of my tubified riding. If you try that, don’t expect your friends to wait for you while you mount a spare — it an 11 for sure.
#2804
Freewheel Medic
Quoted: 1468 Post(s)
Liked 2,238 Times
I would argue that we want more tubular tire riders (for the simple reason of keeping good tires in the manufacturing pipeline). We don't want tubulars to disappear or become scarce, similar to the Schwinn sized 26" 597mm tires.
For this reason, first-time tubular users (and other riders put off by glue) should consider tape, verses glue. Watch this video.
5 minutes from clean rim to mounted tire, easy peasy, and from my experience, it really works.
Bob
Bob
Likes For pastorbobnlnh:
#2805
Bikes: Eddy Merckx EX & Bob Jackson R:753 tubing
Quoted: 15 Post(s)
Liked 44 Times
Started gluing in the 70's.....first time I used tape never looked back. The time involved with glue does not make sense anymore.
#2806
It's MY mountain
Liked 3,034 Times
I'm trying to develop this into something truly useful rather than just one more thing to argue about... sort of like Sheldon Brown's tire width/rim width chart.
I've got some graphics ideas that will make it easy to understand also.
Likes For DiabloScott:
#2807
If I own it, I ride it
Quoted: 594 Post(s)
Liked 665 Times
Hey PB - please rate your tape adhesion on the DiabloScott tubular glue job security scale.
#2808
Freewheel Medic
Liked 2,238 Times
@DiabloScott I don't know if I'm good test subject or rater. I'm not an aggressive rider and currently my pancake flat, rather straight roads, rarely present a challenge to rolling a tubular. All I can say is in my 7-8 years of riding taped tubulars in the mountains of NH, and now for almost 2 years in GA, I've never had one come off while riding.
Can I call it at least a 7?
Bob
Bob
#2809
It's MY mountain
Liked 3,034 Times
#2810
Liked 2,086 Times
We dont need to go that far. How bout first-time users should consider glue because tape makes it much more expensive than clinchers.
Likes For Classtime:
#2811
Freewheel Medic
Liked 2,238 Times
But is it "much more expensive than clinchers"? Comparing tubular tires to clincher tires on a simple cost basis is similar to comparing the cost differences between--- let's say a Mercedes SUV and a Kia SUV (of the same size and weight).
Many factors go into the costs of the clincher tires which are purchased: Wired bead verses folding bead. Tubed verses tubeless. Latex tubes verses butyl tubes. Supple lightweight casing verses puncture protection, etc. As most of us are aware, some high-performance clinchers can be comparable in cost to similar performance tubulars. And--- to be fair--- Rally, Giro, and Yellow Jersey tubulars, can cost about the same as moderately priced clinchers.
Getting back to the tape cost vs. gluing cost:
I don't know how much glue is needed per rim and tire. @Classtime suggests maybe $2-4 +/- worth of glue by the time all the layers are added to two rims and two tires (if I'm wrong please correct and I'll update this post with accurate information).
The price of effetto mariposa tape (which I use) is approximately $10 +/- per wheel. For many first-time tubular riders, the extra expense combined with the simplicity and time saving of mounting with tape could be worth the extra cost.
Bob
Bob
#2812
Death fork? Naaaah!!
Top
Likes For top506:
#2813
Paramount Fan
Bikes: Paramounts, Raleigh Pros, Colnago, DeRosa, Gios, Masis, Pinarello, R. Sachs, Look, D. Moulton, Witcomb, Motobecane, Bianchis, Fat City, Frejus, Follis, Waterford, Litespeed, d'Autremont, others, mostly '70s-'80s
Quoted: 125 Post(s)
Liked 260 Times
I have been riding sewups since 1973. These days not so much because I think they are a great technology--I don't--but because I have so many sewup rims and dealing with their foibles and overhead have become rote. I haven't used tape in decades, but completely understand why some people do, especially considering how much better modern tapes are than the ones I experimented with in the 1970s. I use Continental glue because it is one of the least expensive options when purchased by the can and it works very well while not embarrassing you when you get some on the sidewalls. There was no hiding your incompetence with the old Clement red glue: you wore that badge of shame. My protocol has been to 'reasonably' clean the rim, sand it if it's shiny, apply a medium thickness layer to the rim, apply the same layer to the basetape, wait a few minutes (varies depending on what I can find to putter with, but seldom longer than an hour), apply another layer to the rim, and then stretch the tire on. I leave it at least overnight to cure.
I have never rolled a tire. I also no longer try to see how fast I can take a turn. I feel a crash will ruin any level of fun and stay within my sweet spot of keeping it interesting yet not returning home as a passenger. Applying the tire removal rating scale, a few years ago I flatted and realized that I had a spare in my bag but no tire levers (sewups, so why would I need them?) I have a good, strong grip, but for the life of me I could not get that tire to come off the rim. Eventually another rider came along and graciously loaned me her tire levers to get the darned thing started. This sort of thing never happened in the days of Tubasti. I don't always have that much trouble getting the tire removal started, but it's a sign to me that my technique is working as well as I need it to.
While we're talking tubulars, after moaning for many years about the extinction of the Campionato del Mundo Seta, it is wonderful to have 27 mm sewups return to Capistrano.
Likes For sbarner:
#2814
Bikes: 1980 Dawes Super Galaxy + 1981 Lotus Classique + 1986 Bianchi Sport SX + 2005 Van Dessel Project WR + 2021 Zizzo Liberté
Quoted: 147 Post(s)
Liked 488 Times
Granted, this is correct when comparing one method of mounting tubulars verses the other. Tape is more expensive than mastic/glue, which in turn adds to the total costs of riding on tubulars.
I don't know how much glue is needed per rim and tire, so my guess is maybe $10 +/- worth by the time all the layers are added to two rims and two tires (this would be in what it costs to purchase glue today, but if I'm wrong about this guess, please correct and I'll update this post with accurate information).
If the Challenge CX tires on the used Mavic wheels I bought hadn't been completely shot already, I might have experimented with plain old
Likes For EVlove:
#2815
Liked 2,086 Times
$23.44 shipped from CC today for a can of Mastic. I don't know how many tubulars I have installed with the can that is sitting on my shelf which is a little less than half full--maybe 7-8?
A clincher tube puncture can be repaired at negligible cost. I have never used tape and don't know how practical it is to remove the tape from the tire to get at the tube and repair a puncture, but I suspect the user needs a new roll of tape. If the user depends on sealant to repair all punctures, and either bins or sends to Tire Alert any tire that cannot be sealed, that requires additional cost.
Nice tubulars cost as much as nice clinchers--think Vittoria Corsa and RH.
I just think that a new user should do the C&V thing and perform due diligence. Suggesting that the glue learning curve is too steep and discourages tubular use is like suggesting DT shifting discourages cycling and new riders should go brifters or e-bike.
#2816
Quoted: 239 Post(s)
Liked 311 Times
I think one of the problems here is that what constitutes good gluing is somewhat context dependent. The most demanding users also have team mechanics, tire sponsors, and that puncture repair means a wheel swap from the follow car. If you're riding alone out there with just a spare under your seat and a pump or CO2 cartridge, and if you mean to milk all the value out of your $100+ tires, your notion of best glue job might be just a bit different. I do wonder if ex-pros and pros at home might want less tenacious glue jobs assuming they are still on sew-ups at all. Here's a fun video:
#2817
Freewheel Medic
Liked 2,238 Times
...Suggesting that the glue learning curve is too steep and discourages tubular use....
I'm not suggesting learning how to glue a tubular is too challenging for some riders. Just that taping a tubular is an appropriate alternative, and which a first-time tubular rider could find to be less complicated and less messy, even if there is an added expense.
I'm also not suggesting taping is superior to gluing or vice versa. Nor am I arguing against gluing. And finally, I'm not debating about the differences between clinchers, tubeless, and tubulars.
Bob
Bob
#2818
Quoted: 2385 Post(s)
Liked 2,922 Times
I am facing glue or tape decision very soon (if I can get the rear wheel radial good, with out destroying the lateral, the disk and spoke eveness.... I just think patience grasshopper)
I have done both tape and gluing
My first tubies were Tufo and I used tufo tape...pretty simple. I did note when I removed those tires a) really hard to remove and b) tire was pretty messed up.
the hint for leaving a gap in the tape opposite the stem is well noted
has anyone used both the tufo and the effrotro mariposo tape? how did they compare at removal and tire condition afterward
At this point I am tending to gluing as the tires are FMB so I don't want goof them up if I have to swap a spare in. I could be over thinking (as is not unusual)
I think it is more important that we are riding Tubies, than how we glue
Life is too short not to ride the best bike you have, as much as you can.
#2819
Quoted: 4870 Post(s)
Liked 4,030 Times
Good think about tubbies - if you cannot get all the hump out of that radial, just pull the tubbie a little tighter over the hump portion. It will neck down. With practice you ought to be able to get the tread running perfect over a badly humped wheel. of Take your pick.
#2820
Freewheel Medic
Liked 2,238 Times
@squirtdad I've used Tufo tape in the past, but I've not needed to demount the tires yet.
I do have experience demounting from an effetto mariposa taped tubular and did not find it difficult. I didn't leave a gap on the opposite side of the valve stem. I followed their video and mounted to a clean and old glue-free rim. Take a look at the technical details on their website and they address how their tape adheres to the rim and base tape.
Bob
Bob
#2821
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Rivendell Clem Smith Jr., Libertas mixte
Quoted: 423 Post(s)
Liked 997 Times
I used glue in the '70s. In the '20s, I'm using tape.
In the '70s, before YouTube videos and the elaborate, 3-day Continental process (which no doubt works superbly), I just figured out gluing for myself, like most everybody else, and it worked fine. Never left a gap in the glue for removal, never had removal problems, always rode with a spare, and used it a few times without hassle. My spare was always a used tire, often one I had just repaired, which most everybody also did themselves.
Having mastered the old-school way, I see no need to continue it, and welcome tape for the supreme hassle-saver that it is. Haven't had to deal with any flat that sealant wouldn't fix, yet. One flat is on a tire without a removable valve core, however. If it ever gets fixed, it will become my spare.
Likes For Fredo76:
#2822
Quoted: 239 Post(s)
Liked 311 Times
Guys! Read that method on the back of the Vittoria Mastik One can shown earlier. It's not rocket science, and if you use an acid brush, it's really not that messy, and you get plenty of glue where you need it. I'd say the main issue is not dripping glue down the eyelet holes. Unless you're doing Alpine descents, criteriums, or going into TT corners around 50kph (see below), you'll do fine. I suspect the main audience in C&V is not writing off to their national governing body for a race license, and I just don't see tape as anything but additional expense for not that much labor saving.
Step to 2:46 please. Why doesn't BF append the t=166s parameter? Why why why!?!?!
Last edited by MooneyBloke; 04-02-23 at 03:20 AM. Reason: BF doesn't handle time offsets for youtube embedded videos correctly.
Likes For MooneyBloke:
#2823
The Wheezing Geezer
Quoted: 423 Post(s)
Liked 997 Times
That's a mechanic's error, alright, and a pretty big one, too. I wonder what the error was? No glue at all? Done 15 minutes earlier and still wet? Cleaned the rims with gasoline?
#2824
Steel is real
Bikes: 1992Giant Tourer,1992MeridaAlbon,1996Scapin,1998KonaKilaueua,1993Peugeot Prestige,1991RaleighTeamZ(to be upgraded),1998 Jamis Dragon,1992CTWallis(to be built),1998VettaTeam(to be built),1995Coppi(to be built),1993Grandis(to be built)
Quoted: 688 Post(s)
Liked 1,012 Times
https://www.youtube.com/watch?v=-4ufHfCZGN4&t=166s
#2825
Quoted: 239 Post(s)
Liked 311 Times
I definitely like watching the old races a bit more than the current ones. The only drawback is that most are from fuzzy VHS tapes. These days, it seems it's more about how many watts can you mash at, and the finesse seems to have evaporated. "Bring back the elegance!" ATMO.
P.S. the professional race bikes were nicer looking too.
