Groupset tiers a scam?
Likes For Rides4Beer:
#52
I guess calling in a "marketing strategy" would be a more diplomatic thing to call it.
But I just can't see the difference in value or cost of production between say a 105 and Dura Ace groupset.
Sure when you start using Ti (cassettes) or carbon it will cost more to produce, but overall with modern machinery and production methods I can't really see much of a difference.
#53
A lot of the folks (not all) who get the lower tier stuff think the upper tier folks are stupid. Kind of helps justify their decision.
Likes For RShantz:
#54
Parts is parts
I have never taken apart higher end groupsets to compare to a lower end groupset but as an inspector of everything from aircraft to medical devices, nuts, bolts, and things from plastic injection miles, castings, machined parts, familiar with welding, plating, materials etc. There could be so many differences not really visible to the eye that could make a groupset much more expensive. A grade 5 bolt looks very much like a grade 8 bolt for example but for certain installations grade 8 bolts are specified.
Likes For Kite005:
#55
Advocatus Diaboli
Quoted: 4760 Post(s)
Liked 1,542 Times
#56
I notice a definite difference between Shimano 105 and Ultegra; besides the components being lighter, Ultegra stays in adjustment longer and more reliably than 105, and has a more sophisticated "feel". Not sure how Dura-Ace compares, aside from the overall weight difference.
#57
Sunshine
Quoted: 11044 Post(s)
Liked 7,595 Times
2- even if there weren't aesthetic similarities, trickle down can still exist since components are designed internally as well as externally.
The tech in DA can trickle down, even if the cosmetic doesnt.
But go ahead and doubt.
#59
Quoted: 4717 Post(s)
Liked 1,882 Times
Aesthetically they are similar
If you believe that DA and Ultegra are the same, keep buying Ultegra.
You'll never know the difference, as long as you don't mind waiting for the tech to trickle down.
#60
Sunshine
Liked 7,595 Times
I didnt say I believe they are the same. I simply said there is trickle down, which there is. Lower groups receive changes that higher groups already have.
Internal shift cables being an obvious example. High/low limit adjustment being another. Both have moved from high to low(er).
Maybe I missed something or misread something in this thread?
#64
As a former salesman, I don't see a marketing scam.
First, you have to create a need and no one needs Dura Ace.
Second, you have to give folks a reason to upgrade and no one needs Dura Ace.
So after you create a need and give folks a reason to upgrade you price it so that's it's reasonably close to Ultegra and not out of reach to mere mortals.
Dura Ace is out of reach to mere mortals.
Okay I jest but only a little. Look at the MTB line, SLX, XT, XTR. SLX and XT (I think the sweet spot) are fine and will do the job. XTR is just out there, like Pluto man.
Is it a marketing ploy? No, because if you look at specs you can see how different XTR is over SLX.
XTR is also out of reach to mere mortals.
Again, if this were some kind of scam, you'd price this stuff to sell, not sit in some glass case for the peons to gawk at.
When I did my gravel I ran Shimano for a month or so. XTR cranks just did not compute (even though I opted for Praxis carbon which I think was bit less expensive). You price stuff to lure folks into upgrading, you don't price stuff to scare folks away.
Anyways, this is most likely moot as I bet Shimano makes the most cash on groups sold with brand new bicycles; Tiagra, Alfine, Sora, etc. Think of how many groups are sold that way as opposed to individual grouppos. Think about how cheaply you can make that stuff with all the stamped components.
Actually, this may be where the action is!
Spec out the low end groups so they don't match the upper groups. Why does Shimano still sell 8-9 speed groups? That's right! so you have to upgrade. Creating a need.
How much more is 105?
#65
Quoted: 81 Post(s)
Liked 7 Times
Referencing the GCN interview posted above, Shimano straight up stated that there is no performance difference between Ultegra and DA beyond the weight and materials used. The shifting performance between the two are virtually identical, per Shimano. Not sure it gets more reliable than information coming straight from a company representative.
#66
Quoted: 73 Post(s)
Liked 41 Times
Certainly not necessary, but as a famous poet once remarked..
Likes For RedBullFiXX:
#67
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
If anyone wants to conspiracy theorize......look at electronic groupsets. No reason they couldn't have an Ultegra level that's only $150 or so more than the mechanical set. Mass produced Asian electronics and parts on that scale.........not going to be much difference. But the cost difference.......pshhh.
#68
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1326 Post(s)
Liked 1,307 Times
I don't care what someone thinks they feel in terms of difference in performance of the components but there are some. Then again there are people that think all cars are the same because they all accelerate when you step on the throttle and take you somewhere.
Component levels and groups will continue to have a price ledge to fall off. As noted this always goes to help pay for the development. The trickledown is real. Some will always pay for the top. The gap between the top and second tier has grown and will only get larger. Ride what you want. Don't want it then don't get it. Fear of missing out? Then buy it and justify it to yourself all day long after the fact. Who cares.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
