Can lighter and stiffer bike make climbing significantly faster
Old 03-31-21, 03:52 AM
utoner34
Quoted: 126 Post(s)
Liked 11 Times in 9 Posts
Currently I own ~ 10.5kg aluminum xc bike. I like to train on uphill roads (average 8-9% of gradients or so)
Lets say I buy a crabon frame ~8kg bike. Will this make my times significantly faster?
utoner34 is offline
Old 03-31-21, 05:14 AM
shelbyfv
Expired Member
shelbyfv's Avatar
Quoted: 3781 Post(s)
Liked 5,758 Times in 2,905 Posts
Define significant.
shelbyfv is offline
Likes For shelbyfv:
Old 03-31-21, 05:39 AM
GrainBrain
GrainBrain's Avatar
Quoted: 1228 Post(s)
Liked 638 Times in 478 Posts
I have a hard time believing carbon would be "stiffer" then the aluminum frame. Are these paved or unpaved? I'd be playing with wheel/tire/pressure choices first.
GrainBrain is offline
Old 03-31-21, 10:58 AM
utoner34
Quoted: 126 Post(s)
Originally Posted by shelbyfv
Define significant.
I dont know, I guess if its going to justify a purchase price, the answer is definitely no. But I am just wondering about the possible difference.
I am talking about paved roads.
utoner34 is offline
Old 03-31-21, 11:00 AM
utoner34
Quoted: 126 Post(s)
I though carbon flexes less under pedal pressure than alu frame?
utoner34 is offline
Likes For utoner34:
Old 03-31-21, 11:15 AM
blacknbluebikes
blacknbluebikes's Avatar
Bikes: two blacks, a blue and a white.
Quoted: 446 Post(s)
Liked 849 Times in 411 Posts
You're the engine, so remember that as the "first factor" regardless of what's under you. Second, weight is a bigger factor than stiffness. I'd rather climb with a 15lb aluminum bike than a 23lb carbon bike any day. Third, it's easier for me to lose 3lbs than it is to make a 23lb bike become a 20lb bike (cheaper, too). Fourth, I only hear sprinters fussing about stiffness, rarely climbers.
blacknbluebikes is offline
Likes For blacknbluebikes:
Old 03-31-21, 11:17 AM
Pratt
Quoted: 426 Post(s)
Liked 512 Times in 305 Posts
Yes, if you religiously do intervals up those climbs.
The difference in weight is probably about 3% of the bike and rider.
Pratt is offline
Old 03-31-21, 11:21 AM
Drew Eckhardt
Drew Eckhardt's Avatar
Quoted: 550 Post(s)
Liked 326 Times in 226 Posts
Climbing speed is inversely proportional to total weight.
Assuming you weigh 70kg, dropping that 2.5 kg of bike weight will make speed 80.5 / 78 kg = 1.032 times what it was before; or save 2.5/80.5 x 3600 = 112 seconds per hour.
Drew Eckhardt is offline
Likes For Drew Eckhardt:
Old 03-31-21, 11:31 AM
utoner34
Quoted: 126 Post(s)
You could explain why would you "rather climb with a 15lb aluminum bike than a 23lb carbon bike any day" ?
But isnt bike weight different that rider weight? For example, lighter wheels means you ride faster, dont they? Or you are saying if I ride 5kg bike and weight 70kg, I will ride as fast as if I ride 10kg bike and weight 65kg?
utoner34 is offline
Likes For utoner34:
Old 03-31-21, 11:48 AM
Drew Eckhardt
Quoted: 550 Post(s)
Not at steady speed.
Wheel weight difference doubles accelerating as you move from axle center to road surface although it's not enough to matter unless you're contesting a sprint finish.
Accelerating an extra 500g at the road surface from 0 to 20 MPH only costs you the energy it takes covering 12 feet.
Yes.
Old 03-31-21, 12:13 PM
tomato coupe
Quoted: 4012 Post(s)
Liked 7,523 Times in 3,028 Posts
Can lighter and stiffer bike make climbing significantly faster?
Nothing you can buy will make you significantly faster.
tomato coupe is offline
Old 03-31-21, 01:43 PM
utoner34
Quoted: 126 Post(s)
And if you ride a mellowly gravel bike vs stiff race bike, there is still no significant difference when climbing and getting in and out of saddle constantly?
utoner34 is offline
Old 03-31-21, 01:55 PM
Atlas Shrugged
Quoted: 1276 Post(s)
Liked 1,378 Times in 700 Posts
Correct.
Atlas Shrugged is online now
Old 03-31-21, 02:00 PM
HTupolev
Quoted: 1981 Post(s)
Liked 1,299 Times in 630 Posts
Depends on how much lighter, and what "significantly" means.
If the bike+rider system is 80kg, and you slash this by 2kg, that's a 2.5% reduction in gravitational drag. When you're moving slowly up a steep hill, this might actually give you close to a 2.5% improvement in climbing speed for the same effort.
"Stiffer" is more complex. As much as "stiffness" gets talked up, power transfer losses in rigid frames usually aren't all that significant, even with frames that by modern standards are considered very flexible. There's some evidence that differences in frame stiffness can result in tangible rider power output differences due to how their pedaling interacts with that flex, but this might not be quite as simple as stiffer=better.
HTupolev is offline
Old 03-31-21, 02:10 PM
AdkMtnMonster
Airplanes, bikes, beer.
Bikes: Road bikes, mountain bikes, a cx bike, a gravel bike…
Quoted: 398 Post(s)
Liked 788 Times in 339 Posts
Thats not entirely true, now, is it? Hashtag WADA
AdkMtnMonster is offline
Likes For AdkMtnMonster:
Old 03-31-21, 02:12 PM
Phil_gretz
Zip tie Karen
Phil_gretz's Avatar
Quoted: 1465 Post(s)
Liked 1,542 Times in 806 Posts
Of course, we're talking watts per kilogram.
On the one hand, we have J.J. Watt. Then, there's Charlie Watts. On whom would you place your uphill bet? Discuss.
Phil_gretz is offline
Likes For Phil_gretz:
Old 03-31-21, 03:52 PM
Retro Grouch
Retro Grouch's Avatar
Quoted: 1572 Post(s)
Liked 644 Times in 365 Posts
How fast do you ride now?
Once you exceed about 15 MPH, aero drag surpasses all the other factors combined that are holding you back. If you want to become significantly faster, work on your aerodynamic form and, of course, the motor. Everything else is small potatoes.
Retro Grouch is offline
Likes For Retro Grouch:
Old 03-31-21, 05:45 PM
Maelochs
Maelochs's Avatar
Quoted: 7693 Post(s)
Liked 3,593 Times in 1,895 Posts
"Significant" defined how?
As for less weight .... How many minutes do you spend climbing on your favorite (or least favorite) climbs? How would you be willing to spend to save three seconds on a ten-minute climb? How many seconds on a ten-minute climb would you consider "significant"?
Pretty sure any losses due to frame flexibility are not significant except to the really anal nitpickers and the guys who still use slide rules. Biggest thing with stiffness with modern frames is when sprinters can actually warp the frame enough to have stuff rubbing ... but unless you are cranking out 1600 watts .....
And as far as carbon fiber .... CF is different, not better. A CF frame is not inherently better than any other. There are engineering reasons for using CF in certain applications ... but I ride an 17-lb CF wunderbike and a 27-pound Al working bike up the same hills at about the same speed. The engine is really all that matters.
Maelochs is offline
Old 03-31-21, 06:00 PM
101stairborne
101stairborne's Avatar
Bikes: Lynskey Backroad; Lynkey Cooper CX
Quoted: 14 Post(s)
Liked 18 Times in 9 Posts
Anyone got proof that frame stiffness is faster?
Jan Heine in his new book The All Road Bike Revolution would disagree. Page 58 for those interested.
101stairborne is offline
Old 03-31-21, 06:19 PM
CAT7RDR
Quoted: 833 Post(s)
Liked 1,976 Times in 953 Posts
If you are going to convince yourself you can buy speed, go for it. The first few times on that carbon climber, you will be faster because psychologically, you will give a bigger effort to confirm your choice. Afterwards, not so much.
CAT7RDR is offline
Likes For CAT7RDR:
Old 03-31-21, 07:47 PM
Camilo
Quoted: 1147 Post(s)
Liked 1,249 Times in 792 Posts
You would probably be a bit faster, but would only really notice an observable difference by riding with other people you've ridden with before. If you could not keep up with them before, you will probably notice an improvement with a lighter bike. For example, you might not lag as far behind, might actually keep up with them, but I doubt you'll go faster than someone you couldn't keep up with on the old bike. Only fitness plus good equipment will do that.
No, there's world class stiff aluminum frames. High quality aluminum racing frames are as stiff as you'd be able to use or need.
It's more fun because it probably feels more responsive and faster. See my above comment as to whether it actually matters in practical terms.
Like others have said, only when accelerating. OTOH, in a normal ride, especially with others, you do accelerate a bit a lot of times. Lighter wheels will feel more responsive probably. See above whether it matters.
Agree but it can "feel" faster, might actually be a little bit faster, but probably be more fun.
I have absolutely no problem with people buying whatever they can afford in quality, lightweight bike products. In my experience as an aging "enthusiast" with mediocre fitness and natural ability, I really enjoy the top tier stuff I've managed to cobble together in a way that's affordable to me. It's just fun and not a horrible way to spend money.
Camilo is offline
Likes For Camilo:
Old 03-31-21, 08:22 PM
ofajen
Cheerfully low end
ofajen's Avatar
Quoted: 648 Post(s)
Liked 1,059 Times in 675 Posts
Just noting that while the gravity term will dominate, there will be rolling friction and air friction terms when climbing. If I climb a 5% grade at 12 mph, the gravity term will be about 250-260W and the other terms will be about 60W. The weight difference would make a proportional change in the gravity term but not affect the other terms.
Otto
ofajen is offline
Old 03-31-21, 09:52 PM
Fahrenheit531
52psi
Fahrenheit531's Avatar
Quoted: 790 Post(s)
Liked 803 Times in 392 Posts
Drummers are all about endurance and controlled substances. Charlie Watts easy.
Fahrenheit531 is offline
Likes For Fahrenheit531:
Old 03-31-21, 10:01 PM
HerrKaLeun
Bikes: Giant Toughroad SLR1 and Motobecane Sturgis NX
Quoted: 900 Post(s)
Liked 231 Times in 168 Posts
You said you are training. So do you want to train less with a lighter bike?
Do you also buy light weight dumbbells?
I heard they make CF dumbbells now....
HerrKaLeun is offline
Likes For HerrKaLeun:
Old 03-31-21, 10:55 PM
Rolla
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times in 1,439 Posts
Like a famous local racer once told me: until you're missing the podium by less than a minute, the bike isn't going to make a difference.
Rolla is offline
Likes For Rolla:
