UAE On Rim Brakes
Quoted: 741 Post(s)
Liked 412 Times
UAE On Rim Brakes
UAE chose rim brake bikes for today’s stage in the Tour. One of the descents is the one that Sagan crashed on in 2018. A very technical drop, which makes their choice interesting. The team must feel the slightly lighter bike outweighs the advantage discs have over rims in braking. My next frame is going to be a rim brake only because it is a warranty replacement and Trek won’t replace it with the disc frame. Of course, all those guys descend better than I do so it is probably less critical.
Likes For colnago62:
On Your Left
Quoted: 3004 Post(s)
Liked 2,434 Times
Wouldn't you have to then buy a new groupset for disc brakes if they gave you a disc frame?
Likes For GlennR:
Quoted: 3261 Post(s)
Liked 2,578 Times
If there's a big difference in feel/performance between the two, I would think going back and between systems would be more of a concern than using one or the other. I guess it's not a problem.
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4435 Post(s)
Liked 3,064 Times
Got a screen cap?
A more general question: when pro teams run rim brakes, do they pair them with wheels that have aluminum rim tracks?
Pizzaiolo Americano
The UCI weight min of 6.8kg on bikes means that there is no weight penalty at the pro level. You can easily get disc bikes below that limit...
Likes For Pizzaiolo Americano:
Liked 2,578 Times
Liked 3,064 Times
I wonder if it's different in the rain.
I have two disc brake frames with Campy 160mm rotors and Juin-Tech GT four piston calipers that are operated by rim brake force axs levers. Works great.
Quoted: 1067 Post(s)
Liked 259 Times
Examples of such bikes?
Also Pro's use fairly regular components for reliability and sponsorship reasons. So they are not weight weenie builds.
Likes For Dean V:
Liked 3,064 Times
Quoted: 741 Post(s)
Liked 412 Times
My guess is that the team felt this was a critical stage and wanted to be able to have the riders be able to give Pogacar a wheel if needed. It is much faster with quick release wheels than disc wheels.
Pizzaiolo Americano
https://www.trekbikes.com/nlelectra/...e=bluedark_red
The top spec Tarmac SL 7 is about the same weight too although Specialized (annoyingly) doesn’t publish their bike weights.
And I would say that most pro bikes absolutely qualify as weight weenie builds within the parameters set by the UCI…
Quoted: 741 Post(s)
Liked 412 Times
Here is an off the shelf Trek that is under the UCI limit...
Quoted: 4560 Post(s)
Liked 2,804 Times
Might have been the quicker wheel swap factor already mentioned.
Froome has continued to be somewhat critical of disc brakes on his team bike, midway through the TdF, mostly due to the overheating and noise problem on longer descents. Apparently the Israel Start-Up Nation team mechanic is trying other disc units, rather than swapping to bikes with rim brakes.
Quoted: 3326 Post(s)
Liked 2,171 Times
In my experience, one bike with 105 disc, another with 105 rim, theres no noticeable difference. I would not be upgrading a road bike to get better braking performance from disc brakes, I would understand upgrading to disc plus carbon rims, plus thru axle, mostly as its more future proof.
Likes For Steve B.:
Quoted: 4018 Post(s)
Liked 7,530 Times
I remember when some tennis pros were against the change from white to yellow balls.
Likes For tomato coupe:
Likes For DaveSSS:
Pizzaiolo Americano
Official UCI Rule:
ARTICLE 1.3.019
“The weight of the bicycle cannot be less than 6.8 kilograms.”
The minimum weight of the bicycle (in working order) is 6.800 kg, considered without on-board accessories in place, that is to say those items that may be removed during the event. The bottles,
on-board computers and GPS systems must be removed during the weight check. However, the bottle cages, fixture systems and clipped-on extensions are part of the bicycle and stay in place during the weighing.
Advocatus Diaboli
Quoted: 4795 Post(s)
Liked 1,547 Times
Likes For Sy Reene:
Liked 3,064 Times
Canyon Ultimate Evo Disc at 6 kg even.
You can add your pedals and bottle cages and still need to add weight to meet the UCI limit.
On Your Left
Liked 2,434 Times
https://www.youtube.com/watch?v=eT-Nr8pErCs
It's easy to get under the UCI minimum on a ready to ride bike.
weight as pictured.
Liked 2,578 Times
Likes For seypat:
