A Tire Pressure Thread
Quoted: 41 Post(s)
I just put Continental Gatorskin 700x28 tires on. Their web site says the tire pressure range is 95-116psi.
What relationship is there between tire pressure, weight carrying and comfort?
Note: Some folks run some really low pressures. But, finally pinned down they confess to weighing very little.
Just a person on bike
Bikes: 2015 Trek 1.1, 2021 Specialized Roubaix, 2022 Tern HSD S+
Quoted: 132 Post(s)
Liked 86 Times
How is the ride? I weigh about 140 lbs and run about 100 psi on 700x25s. The ride is fairly comfortable.
The value of your life doesn't change based on the way you travel. - Dawn Schellenberg (SDOT)
Have bike, will travel
Quoted: 910 Post(s)
Liked 288 Times
I weight 220 lbs and use 90 psi in the front and 105 psi inflation at the rear with a tire that size. A tire should deflect 10 to 15%. Less than this reduces traction and more than this increases rolling resistance.
Remember to split the Front/Rear wheel load 45%/55% for Road Bikes
The Professor
Bikes: Alex Moulton Double Pylon, Surly Big Dummy, Alex Moulton GT, AZUB TiFly
Liked 6 Times
I was going to post a similar chart to FlatSix911. I might add that it is my experience that inflating a tire close to the maximum rated pressure will lead to significantly more flat tires. Of course under-inflating will lead to pinch flats and you risk damaging the rim.
Quoted: 1071 Post(s)
Liked 804 Times
Registered User
Bikes: Too many
205lb rider plus 17lb bike puts me at around 100 kilos all in. 85 psi rear 75 psi front when riding Challenge Parigi-Roubaix. 100/85 when riding Schwab One 700x25 and 95/80 when running Vittoria CX EVO iii 700x25. Latex tubes.
Life is too short to run cheap rubber. Never had a pinch flat.
Bikes: Volagi, daVinci Joint Venture
190 lbs, 85/90 front/rear when running my Hutchinson Sector 28mm tubeless. Not pinch flats of course
I weight 385 pounds and inflate the tires to 250 psi.
Momento mori, amor fati.
Quoted: 5234 Post(s)
Liked 3,609 Times
I'm 224lbs and I pump my tires to 115psi front & rear but some escapes when I take the chuck off, so maybe 110 or 105psi is left in the tires?
I too read the article that produced FlatSix's chart several years ago and reduced my pressure. My wife and I both ride at about 60 PSI on 28mm tires and haven't had flats in more than a year. The ride is also a bit more comfortable than would occur at higher pressure.
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
I pump mine up to the max, which is only 100 psi on the 25mm I have now, so that I have longer before having to pump them up again.
If I had to choose a set pressure it would be 80/90 front/back. Total weight is about 175.
The chart says 70/85 psi but that just seems weird. It might be right though for all I know.
Bikes: Lynskey Twisted Helix Di2 Ti, 1987 Orbea steel single speed/fixie, Orbea Avant M30, Trek Fuel EX9.8 29, Trek Madone 5 series, Specialized Epic Carbon Comp 29er, Trek 7.1F
Quoted: 12 Post(s)
I am 215lbs and ride on 100lbs 700x23. No problems and comfy ride.
Quoted: 523 Post(s)
Liked 231 Times
High pressure more speed - Lower pressure more comfort
There certainly is a relationship between tire pressure, speed, and comfort. The relationship between pressure and speed is direct and between pressure and comfort is indirect. I bought a recumbent racing trike that came with Schwalbe Ultremo ZX 406 tires. The rated pressure is 85 to 160 PSI. If you run them at the highest pressure, you might as well be running solid rubber tires. The ride is incredibly harsh. The ride is faster though. I dumped them almost immediately for a set of Tioga PowerBlock tires rated at 35 to 80 psi. Much more comfortable at the rated pressure but slower. I don't like running Schwalbe tires much below the maximum pressure because of bad experience with premature sidewall failure. The sidewalls flex more at the lower end of the rated pressure range. It may mean a shorter life for the tire.
Bikes: Nashbar Road
Liked 341 Times
Bikes: Surly Long Haul Trucker, Gary Fisher Hoo Koo E Koo, Dahon Mu P 24 , Ritchey Breakaway Cross, Rodriguez Tandem, Wheeler MTB
Quoted: 32 Post(s)
It makes a difference, try it and decide for you.
just keep riding
Quoted: 173 Post(s)
Liked 33 Times
I like to go as low as I can without risking pinch flats. I run about 70f and 80r in the Pasela TG 28s on my Casseroll and about 85f and 95r on the Turbo Pro 23s on my Roubaix. Sometimes lower. EDIT - I weigh about 170 lbs.
Another factor to consider is whether you ride light or heavy. Riders who stand up over RR crossings and rough spots, who know how to make a bike float over bumps, can go with lower pressure than those who keep their butts planted on the saddle in all situations.
aka Phil Jungels
I run my Marathon Supremes at 92 PSI, (35s and 40s) because, for me, that's where they roll the best. Not 85, and not 95, but 92. Everyone is different in their wants and needs.
Quoted: 1572 Post(s)
Liked 644 Times
Over the years I've slowly gravitated to using wider tires and less air pressure. The big "Aha" for me was when I went from using 120 psi to 100/110 psi with 28 mm tires on our tandem. We never pinch flatted, seemed to go about the same speed, but felt a lot smoother. I used to top up my tire pressure before every ride. Today I can't remember for sure the last time I pumped up my tires. I just squeeze them with my fingers and, if they don't feel "too" soft, I just ride. Subjectively I don't feel slower or that I'm having to work harder but, honestly, I don't fret about those things anymore.
I weigh 193 lbs. and am 71. I recently changed tire size of my GP4000s from 700x23 to 700x25. I used to run 110 rear and 100 fronts. I now run 105 rear and 95 fronts. I have never had a pinch flat on either size and have used these tires for better than 30,000 miles. They are ridden pretty hard with yesterdays ride hitting 45 mph. Some of the roads are fairly rough, especially on some mountain descents.
Quoted: 1806 Post(s)
Liked 1,331 Times
Don't know how this might fit in but I weigh 182 lbs and my bike weighs 18 lbs. I run 700X25 at 100 psi front and 110 psi rear. Rolls well and is comfortable.
rebmeM roineS
Quoted: 653 Post(s)
Liked 348 Times
I have bought into the 15% tire drop line of thinking (https://www.bikequarterly.com/images/TireDrop.pdf) and currently run my long wheelbase 'bent (30/70 Front/Rear weight) at 50/80 psi with 32 mm tires. Looking at the chart again, I could probably go lower at both ends. (225 lbs me+bike)
