What HRM do you use and/or recommend?
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4430 Post(s)
Liked 3,058 Times
Perceptual Dullard
Quoted: 950 Post(s)
Liked 1,213 Times
Yeah, I don't think the OH1 reports respiration rate directly. Garmin apparently has some software that looks at HRV to estimate respiration. Although Garmin doesn't lost OH1 as a supported monitor, I can attest that the Garmin Edge 830 displays respiration when I use the OH1.
From Garmin Connect website:
As an aside, your respiration data seem to have a lot of drop-outs. Do you also see drop-outs in HR, or is this only for the respiration data?
climber has-been
Quoted: 3540 Post(s)
Liked 3,695 Times
The corresponding breathing rate graph:
I suspect Garmin's algorithm for respiration rate may be a bit "hokey" (technical term).
Perceptual Dullard
Quoted: 950 Post(s)
Liked 1,213 Times
My eyeball calculator makes me think that HR is smoothed but that resp rate may be less smoothed. Places where there are resp rate drop-outs seem very roughly correlated with transitory drops in HR. What's happening to power at the places where HR dips?
climber has-been
Liked 3,695 Times
Bikes: yes, i have one
Quoted: 1151 Post(s)
Liked 1,193 Times
Polar OH1+ optical monitor.
I wear it on my upper arm. It rarely senses weird rates or drops out.
When paired with a Garmin head unit, you can track respiration rate.
edit: never mind. i just need to read the thread more. you need the raw data to make a good comparison of dropouts when the grapsh are applying any sort of filtering.
Zircon Encrusted Tweezers
Quoted: 261 Post(s)
Liked 137 Times
For the tightwads in the group, I have been using this cheap chest strap with my Garmin for about a year now, and it's been flawless for basic HR data. It's not compatible with any HRV apps, though.
https://www.amazon.com/GEOID-Monitor...ustomerReviews
Perceptual Dullard
Quoted: 950 Post(s)
Liked 1,213 Times
Quoted: 528 Post(s)
Liked 230 Times
Polar H10, in use since April 2020 and still going strong. Only weak point is the battery, it has to be replaced a couple times a year. Though that also depends on the quality of the battery.
I use both my Garmin Fenix 7 and also the regular Garmin chest strap. I’d say the chest strap is better overall if you are looking for the best accuracy but the Fenix is just more convenient as it’s already always on the wrist.
I just tried riding Zwift with my Wahoo Tickr and it wouldn't read properly for the first half of the ride, then was OK. I've had that same problem doing outdoor rides except those are usually much longer so I'm only missing a small portion of the ride. I tried licking it, applying some sort of gel, moving it around, rubbing it against my skin and nothing worked, until suddenly it just did. I had a Garmin one that did the exact same thing that the Wahoo was to replace. I've had enough of that so I've ordered a Polar OH1 that was on sale directly from them for $48. It's a different reading process and on the arm. I've never really liked the chest strap.
I tried the Polar OH1 I just bought and it read correctly as soon as I turned it on. When I went up to the trainer to do a ride though the battery died as it didn't have any charge on it so I put on the Wahoo again and again the same problem. I had to skip today on the trainer so I'll get to check it out tomorrow.
I thought about buying an Apple watch but couldn't see the need for it. I'd never use it otherwise.
I switched to the TICKR Fit armband / optical heart monitor after growing tired of the fiddly battery doors of the regular TICKR and Garmin HRM-Dual and the frustration of always having to wet the sensors before starting my ride.
The TICKR Fit is rechargeable (no need to replace batteries) and it has an on/off switch, so it solved both problems. The only "downside" with the TICKR Fit (and it's a small one) is the approximate 20-25hr. battery life before needing to recharge it. As someone who does ultra-endurance events longer than 25hrs. the TICKR Fit doesn't get the job done. For these longer events I use a regular TICKR or a Garmin HRM-Dual.
My CooSpo lasted just over 696 hours before it died. I'm currently using a Magene H303 with over 549 hours. I switched to a Magene because CooSpo wasn't available at the time.
I got on the bike and the Polar performed as expected, but the laptop running Zwift didn't. It too needed a good charge. Even plugged in that laptop throttles itself when the battery is low. I put music on and it ground to a halt. 1984 - Van Halen.
Liked 1,193 Times
https://www.amazon.com/Heart-Rate-Mo...s%2C293&sr=8-3
what i like about it is that it unhooks, not unsnaps like the wahoo strap. pretty sure that is what killed it. so far it has outlasted teh wahoo version by 2x.
I've always used classic chest straps, among which I have tended to prefer the Wahoo Tickr. Lately, I've found it quite frustrating though - many times (though not consistently), it gives bad data for the first 5-15 minutes of a workout. I can't quite figure out why. Fresh battery doesn't help. Neither does making sure the chest strap is tight and in the right place. Nor does electrode gel prevent the phenom.
So maybe I should read this thread carefully and find something better. I'd much prefer a chest strap, as I like my plain analog wristwatch just find and don't want to discard it..
just another gosling
Quoted: 3917 Post(s)
Liked 1,971 Times
I figure my breathing is either below VT1, between VT1 and VT2, or over VT2. I can tell those breakpoints pretty accurately and don't think I need to know more than that.
Before I got a pacemaker, I took my morning resting and standing resting HR as well as my HRV both lying and standing for many years. I don't think the HRV told me anything more than did my HRs. However my standing HF power was something I watched closely. "Lower HF power is correlated with stress, panic, anxiety, or worry." https://www.ncbi.nlm.nih.gov/pmc/articles/PMC5624990/ Also correlates with Polymyalgia Rheumatica (PMR) as I discovered.
Results matter
Results matter
Liked 3,058 Times
Oh crap. I just got back from a business trip and I left my TICKR in the hotel room. Hotel hasn't seen it, though maybe they will find it and ship it back to me. So now I probably need a new one. Given issues I ahd with the TICKR (mostly posted about it in that other thread, I think), I might try a POLAR....
I've been using my Polar OH1 for 2 months now without a single issue. It tracks perfectly right from the start without the frustration of getting a chest strap to pick up.
climber has-been
Liked 3,695 Times
Same for me, except I've been using a Polar OH1 since 2019. Zero problems.
Quoted: 4554 Post(s)
Liked 5,074 Times
Liked 1,971 Times
I'm not sure HRV metrics are currently reliable enough to use as an indicator of any kind of threshold (which was the promise or goal of several HRV apps). I paid top dollar for a Polar H10 chest strap because of the prospects for HRV but if I knew then what I know now, I probably would go tightwad.
My practice, ever since my morning resting HR stopped being a good indicator of training stress (age did that), has been taking my morning resting and standing-resting HRs and HRV with both my Polar V800 and the Elite HRV app. It takes me about 20 minutes do both tests with both devices, but I found it helpful, especially the standing HRV. I keep the data in a spreadsheet.
I assume by threshold you mean ventilatory or lactate, etc. AFAIK HRV won't help with that.
Results matter
Results matter
Perceptual Dullard
Quoted: 950 Post(s)
Liked 1,213 Times
Likes For RChung:
