Summer Base Layer?
Summer Base Layer?
Old 01-05-16, 05:55 PM
TimothyH
- Soli Deo Gloria -
Liked 738 Times in 469 Posts
Summer Base Layer?
It's only another six or seven weeks before the daffodils bloom here in the the ATL. Easter will be here before you know it and then the May charity rides.
So, do those summer base layers really keep you cooler? Not talking about "arm coolers" but the light shirts that go under a jersey and wick the sweat away.
Rapha Pro Team? Assos SkinFoil? Something cheaper? Recommendations?
TimothyH is offline
Old 01-05-16, 06:01 PM
Elvo
Liked 369 Times in 206 Posts
Baselayer - Men
Elvo is offline
Old 01-05-16, 06:14 PM
Doge
Doge's Avatar
Bikes: 1979 Raleigh Team 753
Liked 380 Times in 259 Posts
The Nike and other brand compression wear. Long sleeve, white if summer.
Doge is offline
Old 01-05-16, 08:26 PM
TimothyH
- Soli Deo Gloria -
Perhaps I should have been clearer. I'm sorry. Maybe people are busy.
Do they actually work?
What brands have you tried?
What do you like about the brands your recommend over other brands?
Thanks.
TimothyH is offline
Old 01-05-16, 08:51 PM
Carbonfiberboy
just another gosling
Carbonfiberboy's Avatar
Liked 2,132 Times in 1,509 Posts
I tried a UA long sleeve shirt on a hot day in the mountains with long slow climbs. Total disaster. I dehydrated like crazy without realizing it. IMO they work at keeping one cool by holding one's sweat in the garment, and using the evaporation to cool. However the evaporation and thus cooling only happens if you're moving fast enough to get that box fan-like wind. Otherwise they're just an insulator which increases body temperature and thus causes increased sweating. So for flat short rides, probably they work fine. For long hot rides in the mountains, not so much.
I pulled off the soaking wet undershirt and hung out in the shade and drank for about 20 minutes and was then able to continue up to the pass. Unzipped SS jersey with nothing under was the way to go.
Results matter
Carbonfiberboy is offline
Old 01-05-16, 08:54 PM
surgeonstone
surgeonstone's Avatar
Bikes: 1976 FRESCHI, 2004 Crumpton.
Liked 21 Times in 10 Posts
No need, silly idea.
surgeonstone is offline
Old 01-05-16, 09:39 PM
gregf83
Liked 289 Times in 177 Posts
You cool yourself when sweat you release evaporates. Sweat more you'll cool more. I think in the best case a baselayer will not interfere with the sweat making it to the jersey and evaporating. I don't see how it can cool you more than a skin tight jersey. Maybe it works better if your jersey isn't tight? I see a few tour riders using a base layer on the hottest days but not many. Around here it's not hot enough to make a difference.
gregf83 is offline
Old 01-05-16, 09:58 PM
Doge
Doge's Avatar
Thanks.
Yes - they work. I use Nike and Under Armor and can't much tell the difference. If I can find long sleeve compression without tags on them - I buy for price.
Doge is offline
Old 01-05-16, 10:59 PM
milkbaby
blah blah blah
milkbaby's Avatar
For hot days I prefer an open mesh base layer. Since it's open mesh, it's not insulating, but the material the mesh is made of wicks sweat and increases the effective surface area for evaporative cooling.
milkbaby is offline
Old 01-05-16, 11:16 PM
woodcraft
woodcraft's Avatar
Liked 923 Times in 569 Posts
https://www.bikeforums.net/road-cycli...ng-summer.html
woodcraft is offline
Old 01-06-16, 11:52 AM
SpeshulEd
SpeshulEd's Avatar
Liked 5 Times in 5 Posts
This. I tried a couple of different versions in the Phoenix heat and prefer to ride without them. That said, while mountain biking in the summer with a lose shirt over the top of a baselayer, I did find some benefit, but with a tight/race fit road jersey, there's really no need.
Hey guys, lets go play bikes! Strava
SpeshulEd is offline
Old 01-06-16, 12:02 PM
Robius
Robius's Avatar
Bikes: Felt AR2 Di2
Liked 13 Times in 5 Posts
Review: Castelli Seamless Sleeveless base layer | road.cc
I'm using this castelli base layer and if route is flat they are really good at keeping you dry even if it's like 40 celcius. While climbing i think they add a little warmth but they still wick sweat away.
I like it so much now i own 4 of these.
Robius is offline
Old 01-06-16, 12:21 PM
Seattle Forrest
Seattle Forrest's Avatar
Liked 10,647 Times in 6,055 Posts
Thin (like 100 grams per square meter) merino wool base layer all summer. I'm cooler and more comfortable with it than without. The sleeves offer some UV protection too.
Seattle Forrest is offline
Old 01-06-16, 12:26 PM
grolby
grolby's Avatar
Liked 93 Times in 64 Posts
It's highly unlikely that a baselayer will keep you cooler than no baselayer at all. But it may well help you feel drier and more comfortable.
grolby is offline
Old 01-06-16, 12:31 PM
dalava
Bikes: Moots Vamoots, Colnago C60, Santa Cruz Stigmata CC, and too many other bikes I don't ride
Liked 7 Times in 6 Posts
Originally Posted by Elvo
The Mesh SuperLight is the thing to get... yes they keep you cool by wicking away the moisture
dalava is offline
Old 01-06-16, 01:51 PM
mprelaw
mprelaw's Avatar
I dunno, when I watch a mountain stage on TV, what I see of the pros is a lot of unzipped jerseys and bare chests, and very few base layers, on the climbs. Of course, most of us aren't riding 150 km with a couple of cat1 climbs and one HC climb, so YMMV. In really hot, humid weather, I've worn light compression jerseys, and I've worn my jersey alone. I really don't notice any appreciable difference. Most of the times, in the areas where I most often ride, there's plenty of wind to accelerate evaporational cooling.
IMO the less laundry I have to do, the better.
mprelaw is offline
Old 01-06-16, 02:43 PM
Nachoman
well hello there
Nachoman's Avatar
Liked 344 Times in 212 Posts
I subscribe to that theory.
Nachoman is offline
Old 01-06-16, 05:00 PM
kpotier16
More insulation will never make you cooler.
kpotier16 is offline
Old 01-06-16, 06:23 PM
bleui
is the Mesh close-fitting enough? or do I need to size down?
bleui is offline
Old 01-06-16, 08:16 PM
TimothyH
- Soli Deo Gloria -
Thanks for this. Lazyass's comment about wearing a base layer in the army was interesting.
I wasn't postulating a theory but asking a question. Not really sure what you are trying to say.
TimothyH is offline
Old 01-06-16, 08:42 PM
jamesdak
Liked 6,528 Times in 2,052 Posts
Yeah, but in uniform the standard when I was in was a cotton tee shirt. What a disaster under your BDUs which didn't breath at all anyway. So of course a wicking product is going to be better. But under a bike jersey that's already designed to move the sweat and keep you cool it just makes no sense to me. Just my 2 cents...
Steel is real...and comfy.
jamesdak is offline
Old 01-07-16, 12:06 PM
dalava
One size down. Craft fits bigger.
dalava is offline
Old 01-07-16, 12:09 PM
dalava
Depends on the bike jersey, some are better wicking than others. I find the dedicated baselayer does keep me dryer which leads to cooler feel during summer. In fact, I only wear summer baselayer like the Craft Mesh SuperLight when it's really hot (>90 degrees); otherwise, I just wear the jersey only. YMMV
dalava is offline
Old 01-07-16, 01:44 PM
Seattle Forrest
That's why people don't run across Death Valley in August wearing down jackets. But a base layer's job isn't to insulate you, it's to deal with your sweat. The constant evaporation is what cools you. Maybe the UV shielding too.
Old 01-07-16, 02:01 PM
woodcraft
woodcraft's Avatar
Well this is just not true.
Insulation ******* movement of heat from a warmer point to a colder one.
When it's hot outside, being inside an insulated building keeps you cooler.
This applies as well to clothing in extreme conditions.
(opposite of 'accelerates')
