Would a 10 speed rear derailleur work on a 7 speed cassette?
its only a temporary solution until my groupset comes next week, i have a 10s tiagra rear derailleur hanging around tho, would that work on my 7s cassette, 7s tourney sti?
Yes.
Which version of Tiagra 10 speed derailleur? Do you have an indexed shifter? A Tiagra 4700 derailleur will not work with a 7 speed indexed shifter. A Tiagra 4600 will. If you have a friction shifter, either will work
A 10sp dérailleur might not fit the wider 7sp chain.
This site: https://en.wikibooks.org/wiki/Bicycl...ing_Dimensions implies that Shimano derailleurs all have the same motion ratio. If that is true, the index clicks ought to work, but I'm not a Shimano expert.
The rear derailleur moves continuously in (cable pull) and out (return spring)
between the stroke limit screw settings [high normal type]
"speeds" is the number count of the stack of cogs on the rear wheel..
Sunshine
Liked 8,064 Times
Cycleway town
There are varying Shimano derailleur swing ratios, i cannot use my classy polished Tiagra derailleur with my 10sp XT shifter, because the XT is Dyna-Sys and the Tiagra is not. So i have to use the yobbo XT derailleur.
